Broken documentantion links for Bookworm DuetPi 64-bit images
The Bookworm DuetPi 64-bit images links in the section for the SBC-Setup are not working.
The links for the 32-bit images are working fine. -
@MaxGyver in the short term I would recommend using the pi imager as the duet images, both 32bit and 64bit are listed there if you need them
@droftarts one for you
@MaxGyver said in Broken documentantion links for Bookworm DuetPi 64-bit images:
Strange, they're working for me. Clicking on "http://pkg.duet3d.com/DuetPi-arm64.zip" prompts to download "image_2024-09-19-DuetPi-arm64.zip"
Strange indeed, but it seems to be limited to Brave Browser. I have tried it again with Firefox where it works fine.
undefined MaxGyver marked this topic as a question
undefined MaxGyver has marked this topic as solved
@MaxGyver It may be related to Chrome. @jay_s_uk says it's not working for him either, running Chrome. One for @chrishamm to check, please!
If you're after the latest version, see https://forum.duet3d.com/topic/37011/duetpi-bookworm-2024-11-27-now-available
@MaxGyver @droftarts Looks like Chromium-based browsers don't like plain http links, I replaced them again with https and that appears to fix it.
