    Gcode for test BlTouch
    13.8k
    • peirofundefined
      peirof
      I suspect that the problem may be in the file bed.g, which makes me think that:
      A- The BlTouch sensor, now, seems to work correctly, when I turn on the printer it does the initial test
      B- If you send the gcode G30 S-1 via a console, it seems to execute it well.
      So….
      When by DWI, you send the autocalibrate order ... it is supposed to make the orders contained in bed.g. Do not?
      When you send the order to use the mesh compensation ... It does not depend on what you put in bed.g, but on order M557 in config.g. DO NOT?
      Someone, that have a Delta and uses BlTouch, can post his [c]bed.g[/c]
      • peirofundefined
        peirof
        News….
        I try to make a [c]bedcompesation[/c], and partial works, with the next behavoir:
        1- Nozzle go down, a bit slow, but go down….
        2- With Nozzle is near bed, aprox 30 mm, slow, VERY SLOW.
        3- With BlTouch, reach bed... MAGIC, WORKS. Retract, and Nozzle go up.
        4- Go to the next point... and here start the problems, de BlTouch, NO re Deploy.
        Why?
        And why bed compenstation works, or semi works, and calibration NO works, nothing?
        Ideas?
        • peirofundefined
          peirof
          eeee…..
          i think i have it.... not sure.
          Dc42.... if someone, has put the files deployprobe.g and retractprobe.g.... in dir [c]\macro[/c]…. maybe.... and only maybe, can be the cause of behavoir descrived in previous post?
