    Serial SCARA firmware support, please!
    Config Tool
    • tonybillieundefined
      tonybillie
      Hi there,
      Currently in the early phases of a serial SCARA build and I notice the firmware config tool doesn’t support scara kinematics. I’m wondering why this is so/wishing for it to one day support scara builds.
      To my understanding, I’ll have to manually edit the firmware code to have the board (6xd in my case) recognize the scara kinematics. I’d generate a firmware code for a Cartesian printer, accounting for my motors/drivers/sensors/axes in the config tool, then switch out the M669 code to tell it scara instead.
      Obviously none of this is “it’s that simple”… but what am I missing here, other than M669 and assigning new values for the geometry of the build?
      Is there any hope for a configuration tool that supports serial SCARAs?
      Thanks yall 🙃
      jay_s_ukundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @tonybillie
        @tonybillie have you seen https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_SCARA
        tonybillieundefined 1 Reply Last reply Reply Quote 0
          tonybillie @jay_s_uk
          @jay_s_uk yes I have, thanks for sharing
          jay_s_ukundefined 1 Reply Last reply Reply Quote 1
            @tonybillie one for @chrishamm then to add to the config tool
            • T3P3Tonyundefined T3P3Tony moved this topic from Firmware wishlist
            • chrishammundefined
              chrishamm administrators @tonybillie
              @tonybillie The RRF object model does not hold enough information about serial SCARA setups yet, so saving the required information using the configtool isn't really possible yet. I've logged this FR here: https://github.com/Duet3D/RepRapFirmware/issues/1093
              chrishamm created this issue in Duet3D/RepRapFirmware
              open [FeatureRequest]: Provide more information about different kinematics in the object model #1093
              Duet software engineer
                tonybillie @chrishamm
                @chrishamm thank you!
