    Duet 3 3HC - Controlling an Electro magnet
    This topic was forked from Duet 3 3HC - Controlling an Electro magnet to switch filament droftarts
    • dwuk3dundefined
      dwuk3d
      Thought it best to post against this old post - rather than create a new one.
      I'm trying to create a automatically deployable XYZ ball probe - as per attached picture.
      At present it is working with a 50kg Magnet to hold it in place on the bed
      To make it automatically deployable I am thinking of replacing this with an 18kg electro magnet - like this one
      Controlled from a fan output, via one of these
      Will then use a fairly powerful servo to swing the probe out when needed, and retract it back when not in use.
      Any thoughts appreciated.
      For further background info see my 'Sovol SV08 Multiple Motion System Upgrade' thread.
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @dwuk3d
        @dwuk i've used 24v electromagnets connected to heater outputs before without issue
        dwuk3dundefined 1 Reply Last reply Reply Quote 0
        • dwuk3dundefined
          dwuk3d @jay_s_uk
          @jay_s_uk Thanks - that was my initial thought too - but the post above from 'a former user' about inductive load issues worried me a bit.
          I suppose with those Motor Driver boards I could probably even drive it from an IO.out pin too.
          Will look further into the heater option before purchasing the driver boards.
          dc42undefined 1 Reply Last reply Reply Quote 1
            droftarts administrators @dwuk3d
            @dwuk said in Duet 3 3HC - Controlling an Electro magnet to switch filament:
            Rather than necro-post, create a new thread but add a link to the old thread.
              dc42 administrators @dwuk3d
              The heater outputs on the 3HC have built-in flyback diodes to protect them when used with inductive loads.
              • dwuk3dundefined
                dwuk3d @dc42
                @dc42 thanks for the confirmation - will go ahead without the motor driver boards then.
                Ordered one of these
                Doesn't look like it needs much power
