    Connecting a thermistor directly to the expansion port (Duet2)
    • rbjam83undefined
      rbjam83
      Hello everyone,
      I have a Duet 2 Ethernet (without the Duex expansion board) and would like to connect an extra thermistor to monitor chamber temperature. Since I'm already using all 3 of the thermistor ports I'm trying to connect the thermistor to pin exp.39 and exp.40 on the expansion connector, but I get crazy high temperature readings with a lot of noise too.
      Do I need to add a resistor in between the thermistor wires? If so, what value?
      Thanks!
      jay_s_ukundefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @rbjam83
        @rbjam83 you can't just add a thermistor like that.
        If you look at the schematic, you need a connection to VSSA (3.3v) as a reference voltage and then a voltage divider.
        It may be easier to add an SPI daughter board for the max31865 and convert your hotend to a PT1000, then you'll have a spare port
        • T3P3Tonyundefined
          T3P3Tony administrators @rbjam83
          @rbjam83 as @jay_s_uk says adding a spi expansion board may be easier. If you do want to use a thermistor the follow the circuit in the duex5 :
          https://github.com/Duet3D/Duet-2-Hardware/blob/master/Duet_Expansion/Duex5v0.11/Duex_Schematic_v0.11.pdf
          Specifically you need a 2K2 0.1% pullup to ADVREF, and connect the thermistor between the thermistor pin and VSSA.
          www.duet3d.com
          rbjam83undefined 1 Reply Last reply Reply Quote 1
          • rbjam83undefined
            rbjam83 @T3P3Tony
            @T3P3Tony Thanks.
            After a quick search online, looks like it will indeed be difficult to do this. Can't find such precise resistors near me.
              dc42 administrators @rbjam83
              @rbjam83 you can use a 1% resistor, it may just reduce the accuracy a little.
              • rbjam83undefined
                rbjam83 @dc42
                @dc42 I'll give it a try.
                Thanks!
