What was once silent is now loud..
I used to have the printer running silently until I changed something in the firmware. Might've been current draw..
I don't recall what it was but suggestions would be greatly appreciated!
Please post your config.g file.
[[language]] ; Configuration file for Duet WiFi (firmware version 1.17 to 1.19) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Sun Nov 05 2017 22:28:13 GMT-0500 (Eastern Standard Time) ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M555 P2 ; Set firmware compatibility to look like Marlin M665 R157 L397.1073 B175 H517 ; Set delta radius, diagonal rod length, printable radius and homed height M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them M208 Z0 S1 ; Set minimum Z ; Endstops M574 X2 Y2 Z2 S1 ; Define active high microswitches M558 P1 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the probe + travel speeds G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height M557 R270 S20 ; Define mesh grid ; Drives M569 P0 S1 ; Drive 0 goes forwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S0 ; Drive 3 goes forwards M350 X16 Y16 Z16 E16 I0 ; Configure microstepping without interpolation M92 X80 Y80 Z80 E80 ; Set steps per mm M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min) M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min) M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2) M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Heaters M143 S260 ; Set maximum heater temperature to 260C M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning) M305 P0 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M307 H1 A1400.8 C122.4 D5.3 B0 ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C ; Network M550 PTLM _Duet ; Set machine name M552 S1 ; Enable network M587 S"C170512D5CFB" P"9053393116" ; Configure access point. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Fans M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
Looks like micro-stepping interpolation is turned off - try turning it back on (use I1 in M350 instead of I0)
Don't feel bad, I did the exact same thing after updating my firmware from 1.16(-ish…) to the current release version, and was scratching my head for a bit before finding the flipped bit in the Interpolation config line.
This might have been a change implemented in the changes, and buried somewhere in the release notes?
@deckingman and @Hey_Allen are correct!
Made the suggested change and it's running silently again! Thank you!!!
What's are the benefits of enabling micrtostepping with interpolation other than keeping the noise down?
On delta printers, you may also get less moire. On other types of printer, probably no advantage.
