Heated Bed wiring on out 0
Hello all,
I am trying to get my heated bed working.
I am using a SSR and controlling it using the out0 port. I have not given any power to the input of out0.
My heated bed shows up on the DWC but it does not heat up.
My question is whether I need to supply power to input of out0 for the heater bed to work ?
Thank you
Below is my config file
; General G90 ; absolute coordinates M83 ; relative extruder moves M550 P"Duet 3" ; set hostname ; Network M552 P0.0.0.0 S1 ; configure Ethernet adapter M586 P0 S1 ; configure HTTP ; Smart Drivers M569 P0.0 S0 D2 ; driver 0.0 goes forwards (X axis) M569 P0.1 S0 D2 ; driver 0.1 goes forwards (Y axis) M569 P0.2 S1 D2 ; driver 0.2 goes forwards (Z axis) M569 P0.3 S1 D2 ; driver 0.3 goes forwards (Z axis) M569 P0.4 S1 D2 ; driver 0.4 goes forwards (Z axis) M569 P0.5 S0 D2 ; driver 0.5 goes forwards (extruder 0) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1 Z0.2:0.3:0.4 ; set axis mapping M350 X16 Y16 Z16 I1 ; configure microstepping with interpolation M906 X800 Y800 Z800 ; set axis driver currents M92 X80 Y80 Z400 ; configure steps per mm M208 X0:500 Y0:500 Z0:500 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Extruders M584 E0.5 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1000 ; set extruder driver currents M92 E420 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2) ; Kinematics M669 K1 ; configure CoreXY kinematics ; Probes M558 K0 P5 C"io2.in" H5 F120 T6000 ; configure digital probe via slot #0 G31 P500 X-28.1 Y-14.95 Z1.35 ; set Z probe trigger value, offset and trigger height ; Endstops M574 X1 P"io0.in" S1 ; configure X axis endstop M574 Y2 P"io1.in" S1 ; configure Y axis endstop M574 Z1 S2 ; configure Z axis endstop ; Sensors M308 S0 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"temp0" Y"thermistor" A"Heated bed" T100000 B4725 C7.06e-8 ; configure sensor #1 ; Heaters M950 H0 C"out1" T0 ; create heater #0 M143 H0 P0 T0 C0 S285 A0 ; configure heater monitor #0 for heater #0 M307 H0 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #0 M950 H1 C"out0" T1 ; create heater #1 M143 H1 P0 T1 C0 S140 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 ; Heated beds M140 P0 H1 ; configure heated bed #0 ; Fans M950 F0 C"out4+out4.tach" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"out2" ; create fan #1 M106 P1 S0 B0.1 H0 T45 ; configure fan #1 ; Tools M563 P0 D0 H0 F0 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C ; bed leveling stuff M584 X0.0 Y0.1 Z0.2:0.3:0.4 E0.5 ; three Z motors connected to driver 2 (front left), driver 3 (rear middle) and driver 4 (front right) M671 X-46:250:551 Y-11:557:-11 S0.5 ; position of leadscrew/bed pivot point at front left, rear middle and front right M208 X0:500 Y0:500 ; X carriage moves from 0 to 500, Y bed goes from 0 to 500
@Hussain I assume this is a 6HC? You need to supply voltage to the out0 power in screw terminals. SSRs usually work on between 3.3V and 32V.
See https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Mainboard_6HC_Hardware_Overview#vin-input-voltage-from-psu and https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_bed#bed-heater-driven-using-a-solid-state-relay
Yes my board is the duet3 MB 6HC.
Thank you for your comments.
I plan to use the same power source for my heater bed as well just with a SSR which will control the AC power
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
