    SZP for bed level in 3.6-RC1
    Firmware installation
    837
    • jltxundefined
      jltx
      I just rebuilt my printer with CAN using Roto Toolboard with SZP. Everything appears to be working correctly again, except for the bed level.
      this is a Voron trident with the microswitch bed probe for Z home and offset. What I changed in bed.g is right after the Z home, I move the coil just over the bed near the microswitch since I know approximately where that portion of the bed is located in height so known to be safe. I do a M558.1 calibration for the SZP probe.
      Then I go to probe the three bed points for leveling using the normal M558 commands using the SZP probe: M558 K1 H15:5 F1000 T15000
      The first point seems to probe ok but I think I'm just getting lucky that the bed is an equal height there. At the second probe point the bed is a little higher and the nozzle runs into the bed during the probe dive so I abort. I also notice that neither probe point seems to be honoring the H parameter because it looks like it's starting ~5mm high.
      What are good steps to debug. The M558.2 and M558.1 by themselves seem to do the right thing. Do I need more parameters for the M558 probe command?
        droftarts administrators @jltx
        @jltx I've tested using H15:5 in 3.6.0-rc.1+2, and it works correctly, moving up 15mm before moving to the next probe point, while subsequent probes at the same point are done at 5mm. But I'm using a 'normal' probe rather than SZP. Could you test to see if this firmware version resolves the issue? Find it here: https://www.dropbox.com/scl/fo/y03luwmbypirbxncla3rk/AAJFLPFsVdFylemyhkXsAac?rlkey=7cq4svp4rzl2ztdffpzq2ghjk&dl=0
        jltxundefined 1 Reply Last reply Reply Quote 0
        • jltxundefined
          jltx @droftarts
          @droftarts Yes, this same code (except the M558.1) was used when I had a P8 probe and it worked fine. When I switched to P11 is when it changed behavior.
          I don't think the dive height is the main problem though because the probe starts well above the trigger point. It just doesn't see it when lowering on the second probe point. Is there a way I can monitor the values live?
          I will try the firmware above if I can figure out how to install on my SBC+Mini5+RR. I also need to figure out why my DWC did not update with the rest of the firmware when I did M997 S2.
          • jltxundefined
            jltx @jltx
            @droftarts I can't get that firmware to load with my SBC. Maybe I'm doing it wrong. I don't see any sbc file. I may have to wait for official release to try.
            jltxundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
            • jltxundefined
              jltx @jltx
              I missed the note that said 15 is typical current. My M558.2 came up with 22. So I lowered it to 15 and I see some more normal behavior (I think). Is 99999 mean it has triggered or overflowed? The values rise as I get closer to the bed and then suddenly jump to 99999. The DWC status shows normal, yellow, then red during the probe dive. But it doesn't stop at red, it keeps going. The first probe point finally stops right before impacting the bed but had already jumped to 99999. The second probe point does similar but impacts the bed and I have to reset machine.
                Phaedrux Moderator @jltx
                @jltx said in SZP for bed level in 3.6-RC1:
                See here for updating your firmware with an SBC.
                https://docs.duet3d.com/User_manual/Machine_configuration/SBC_setup#update-firmware
                • jltxundefined
                  jltx @Phaedrux
                  @Phaedrux said in SZP for bed level in 3.6-RC1:
                  I know how to do that when the firmware is via a depot but this is from a dropbox so I assume there is a manual procedure. Do I need to sftp them over?
                  • jltxundefined
                    jltx
                    so I played around with the drive current more. I cannot find a setting that works all the way from the bed to infinity. The best I can do, using 16, is get a non-99999 value from about 2mm over the bed to infinity. If I drop Z lower it jumps to 9999, but I can boost the current and get a good reading but then it instead jumps to 99999 at higher Z. It seems very finicky. This is all with a cold bed for now. I haven't tried heated.
                    • jltxundefined
                      jltx
                      I did this repeatability test after running a M558.1:
                      G1 Z5 F3000
                      G30 K1 P0 Z-9999
                      G30 K1 P1 Z-9999
                      G30 K1 P2 Z-9999
                      G30 K1 P3 Z-9999
                      G30 K1 P4 Z-9999
                      G30 K1 P5 Z-9999
                      G30 K1 P6 Z-9999
                      G30 K1 P7 Z-9999
                      G30 K1 P8 Z-9999
                      G30 K1 P9 Z-9999 S-1
                      G1 Z5
                      and it works! The RMS error seems largish but it works.
                      So G30 works but M558 does not. Am I just missing a parameter?
                        Are you already on the unstable branch? If so, you should be able to upload the bin file and send M997 to flash to it. See here for parameter details for M997 in SBC mode.
                        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m997-perform-in-application-firmware-update
                        • jltxundefined
                          jltx @Phaedrux
                          @Phaedrux I must be reading that wrong because it looks like the P parameter only works in standalone mode. For SBC only a feed is supported, stable or unstable. That is how I got to 3.6-rc1. I can try it later today. I assume I have to do the CAN board separately.
                            @jltx You can still send M997 S0 to flash the firmware if you've uploaded it. And you can use P to refer to the file name directly if it isn't the default.
                            • jltxundefined
                              jltx @Phaedrux
                              • jltxundefined
                                jltx
                                The dive height is still not correct. And the trigger does not appear to work. I can see it turn red on DWC but the Z keeps decreasing until it hits the bed and keeps going until I reset.
                                • jltxundefined
                                  jltx
                                  no, wait! it works. I had made an experimental edit (I was sure it wouldn't help) yesterday out of desperation. But then I forgot to revert it. I just did and now I can ABL again!
                                  I guess I need to tune the current more because I am getting bigger rms error than the threshold I am using for ABL.
                                  • jltxundefined
                                    jltx
                                    spoke too soon. I ran it again and it made odd adjustments to the Z motors and then the head crashed into the bed pretty bad. I also noticed that it only does the first dive, not the second, e.g. 15 but not 5.
                                    ; Clear any bed transform
                                    M561
                                    ; Turn off noisy Extruder motor
                                    M84 E0
                                    ; Lower currents, speed & accel
                                    M98 P"/macros/print_scripts/setup_probing.g"
                                    ;if !move.axes[2].homed
                                      ; Home all axes
                                      G28
                                      G1 Y240 Z6      ; move coil over bed and higher than trigger point
                                      M558.1 K1 S1.5  ; calibrate height coeff
                                      ; Probe the bed at 3 points, x3 for more precision
                                      M558 K1 H15:5 F800 T15000; increase the depth range, gets the gantry mostly level immediately
                                      M98 P"/sys/bed_probe_points.g"
                                      M558 K1 H4:2 F400 T15000  ; reduce depth range, probe slower for better repeatability
                                      ; last attempt will be auto-repeated
                                    M558 K1 H1 F60 T15000   ; reduce depth range, probe slower for better repeatability
                                    while move.calibration.initial.deviation > 0.01 ; 0.003
                                      if iterations > 3
                                        abort "Too many leveling attempts! Canceling print."
                                      echo "Current deviation: " ^ move.calibration.initial.deviation ^ "mm"
                                    echo "Leveling complete"
                                    ;use mechanical instead? G30 S-2 ; Z=0
                                    ; Restore high currents, speed & accel
                                    M98 P"/macros/print_scripts/setup_printing.g"
                                    • jltxundefined
                                      jltx
                                      I think the fundamental problem is there is no drive current for the SZP that covers the range necessary for bed leveling. If I dial in the drive current for near the bed then it is pre-triggered at the initial dive heights necessary for a possibly tilted bed (more than a few mm). Alternatively I can find a drive current that works at a higher height but then overflows before the trigger point near the bed.
                                      Here is the probe set up I am using to go with the bed.g posted above:
                                      ; Scanning Z probe
                                      M558 K1 P11 C"121.i2c.ldc1612" F36000 T36000    ; configure SZP as probe 1, type 11, on CAN address 120
                                      M308 A"SZP coil" S10 Y"thermistor" P"121.temp2" ; thermistor on SZP coil
                                      G31 K1 Z2 Y36                                   ; define probe 1 offsets and trigger height
                                      M558.2 K1 S16 R115897                         ; set drive current and reading offset
                                      Every day I run M558.2 K1 S-1 (for debug) and I get a different answer, 16, 22, 18. There is a span of about 5 around these that will work over some Z range and outside of that it is always overflowed. It's also hard to debug because in DWC the Z trigger is always red. sometimes that seems ok and other times it says it is pre-triggered.
                                      • jltxundefined
                                        jltx
                                        I think my printer is monitoring this thread. So suddenly, without changes, the Z probe stopped being red.
                                        So I tried again and now I get a completed ABL.
                                        However, it is not repeating any probes as requested, i.e. second dive at reduced height. Is that expected with SZP?
                                        • jltxundefined
                                          jltx
                                          I hate to jinx it but it seems to be working now, repeatedly. I think the key was having the z value not red (whatever that indicates). I don't know what flipped it. I only made one change to protect against bad currents. Since I added this statement in bed.g everything started working and this statement has never triggered. But I wonder if somehow sampling the value cleared something and now it works (not red)?
                                           if sensors.probes[1].value[0] = 99999
                                              abort "wrong current"
                                          • jltxundefined jltx referenced this topic
                                          • gloomyandyundefined
                                            gloomyandy @jltx
                                            @jltx I'm glad you have it working. I was in the process of typing up the following reply. You may find some of it of use...
                                            What height from your nozzle (or other z=0 point) do you have the coil mounted? You may find that mounting it higher gives you a better working range. At the moment you are setting the trigger height to 2mm in your G31 command and are calibrating with M558.1 over a range of +/-1.5mm this means you will need the probe to provide valid readings with the nozzle 0.5mm above the bed and all points from there to above your dive height of 15mm. This may not be possible.
                                            You may be able to make it work by setting the trigger height to a higher point. I'd try increasing that to say 3 or 4mm. Try changing the G31 Z parameter to 4 and then re-run the coil drive calibration with the nozzle at Z=2.5, then check that you still get valid readings at z=17.5. If all of that looks ok, then rerun M558.1 which should now calibrate at a height of 4mm rather than 2mm.
                                            What amount of bed tilt are you looking to handle, so how far above/below Z=0 do you need to measure for a tilted bed? The szp is not really good at handling a wide range of heights when used in "scanning mode", probably only a range of a few millimetres.
                                            The probe will be triggered (red in DWC) if the coil is ever in a position in which it is closer to the bed than its height above the bed when you calibrated the threshold using M558.1. You have set your trigger height to be 2mm using G31 so the probe will show as triggered if the nozzle is below 2mm above the bed. It will also show red (and display 99999) if the coil is too high/low for the drive current you have set.
                                            To have the probe, probe multiple times you need to set the A parameter in M558 I can't see you doing that. You may also need to set the S parameter.
