    Need help moving one Z-axis motor extruder driver
    • eca77
      eca77 last edited by
      I know it should be simple, and has been done, but I can't seem to find the info on how to define where the Z motors are controlled from. I would like to set up my BigBox so I can do the leveling and correction feature. I put one of the Z steppers on E1 as E0 is my extruder (I have a dual, but only use the one side until I do the IDEX upgrade). Any help would be greatly appreciated.
      • whosrdaddy
        whosrdaddy last edited by
        Did you read the guide?
        https://www.duet3d.com/wiki/Bed_levelling_using_multiple_independent_Z_motors
        • eca77
          I read the guide, but I'm not sure if that is also the way to direct the Duet to use the E1 controller for the second Z-axis not just for the leveling feature.
          I just got back to the machine after about a year of letting it sit due to time constraints (new baby and college). Now I want to get it running again with the change.
          • Martin_S
            Martin_S last edited by
            This post might help you out:
            https://betrue3d.dk/duet-wifieth-use-m584-to-autolevel-or-sync-z-axis-using-2-or-more-motors/
            If it ain't broke, fix it till it is =)
              @eca77:
              Yes that is also the way to drive multiple Z motors from separate drivers. Look up M584 in the gcodes wiki page.
