    Sensor Open Circuit, only when E0, E1, and bed fire at once
    209
    • VasDraftsundefined
      VasDrafts
      To make a fairly long story short, we have a Modix Big-60 printer with dual extruders and an AC powered heatbed.
      Duet 2 wifi board with duex expansion, firmware 3.4.5
      The modix comes standard with the ac bed heater attached to it's own temp control. I changed this to use the SSR that the stock temp control was firing, to be fired from the duet board. The stock silicone bed uses a K sensor, so I also added the thermocouple daughter board.
      If I have extruder 0 and 1 on standby, set to a temp of 100c, and the bed set to 60c, I will get a sensor open circuit fault on the bed k sensor. If I turn off Either extruder, the open circuit fault won't return. It doesn't make a difference what I set the standby temps too, just that all 3 heaters are firing at once.
      I originally ran a 4 conductor shielded cable down for the bed heater and sensor, but have since changed that to 2x 2 conductor shielded cables to omit the possibility of noise messing something up. The shielding is grounded to the ground pin on the duex for the duex's temp daughterboard(not installed)
      Does anyone have any thoughts beyond a loose wire? Is this indicative of a loose/overheating/inadequate ground? Last year I had to replace the duet 2 board as it had failed, so i did have to redo all of the wiring. The printer has since printed many prints successfully, but with the problems I've outlined above.
      Thanks for any assistance or thoughts anyone can give me on this. Hope I included enough info.
      ; Modix Big-60, Duex Expansion, IDEX
      ; Configuration file for Duet WiFi (firmware version 3.4.5)
      ; Generated by Modix - Version 3.4.5 Config C
      global config_version = "Version 3.4.5 Config C"
      global generation = 4 											; generation 4 printer
      global printhead  = 1 											; Griffin printhead
      global expansion = 1 											; Duex expansion board is installed
      global pausetime = 0											; record pauzing time
      global fan_0_speed = 0 											; Used to store the fan0 speed
      global fan_1_speed = 0 											; Used to store the fan1 speed
      global filamentswitch = 0 										; filament switch disabled (edited)
      global printheads = 2											; dual extruder
      global changer_count = 0 										; Counter for tool changer continous.
      global idex = 1																;idex setup
      global toolstate = 0											; used to define active tool
      global errorfix = 0.300
      ; General preferences_________________________________________________________
      G90																; send absolute coordinates...
      M83																; ...but relative extruder moves
      M555 P2															; Set output to look like Marlin
      M575 P1 B57600 S1												; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      ; Network_____________________________________________________________________
      M550 P"Big 60 V4 - IDEX"										; set printer name
      ;M551 P"MODIX3D"												; Set password (optional)
      M98 P"config_networking.g"										; enable network
      G4 P300															; wait 300ms
      ;M552 P0.0.0.0													; Uncomment this command for using Duet Ethernet board
      ; Drives_________________________________________________________________________
      ;Main board______________________________________________________________________
      M569 P0 S1														; Physical drive 0. X-B-M
      M569 P1 S0														; Physical drive 1. X-F-M
      M569 P2 S0														; Physical drive 2. U Secondary
      M569 P3 S1                                                  	; Physical drive 3. E0-Extruder.
      M569 P4 S0                                                 		; Physical drive 4. E1-Extruder.
      ;Duex5 board_____________________________________________________________________
      M569 P5 S0														; Physical drive 5. Y
      M569 P6 S1														; Physical drive 6. Z-Back-Left (ZBL)
      M569 P7 S1														; Physical drive 7. Z-Front-Left (ZFL)
      M569 P8 S1														; Physical drive 8. Z-Front-Right (ZFR)
      M569 P9 S1														; Physical drive 9. Z-Back-Right (ZBR)
      ;Settings_________________________________________________________
      M584 X0:1 Y5 U2 Z6:7:8:9 E3:4 P4								; Driver mapping
      M671 X-185:-185:668:668 Y668:-46:-46:668 S30    				; Anticlockwise
      ;___________________________________________________________________
      M350 X16 Y16 Z16 U16 E16:16 I1									; Configure microstepping with interpolation
      M92 X80 Y80 U80 Z2000 E400:400									; Set steps per mm
      M566 X500 Y500 U500 Z30 E2500:2500 P1 							; Set maximum instantaneous speed changes (mm/min)
      M203 X18000 Y18000 U18000 Z400 E6000:6000 						; Set maximum speeds (mm/min)
      M201 X3000 Y3000 U3000 Z240 E1000:1000 							; Set accelerations (mm/s^2)
      M204 P1000 T3000 												; Set print and travel accelerations  (mm/s^2)
      M906 X1800 Y1800 U1800 Z1800 E1000:1000 I50						; Set motor currents (mA) and motor idle factor in per cent
      M84 S100														; Set idle timeout - 100 seconds
      M208 X0 Y0 U0 Z-2 S1                               				; set axis minima
      M208 X600 Y600 Z600 S0                          				; set axis maxima
      M98 P"config_probe_offset_U.g"									; Load secondary axis offsets
      M574 X1 S1 P"duex.e5stop + duex.e6stop"							; configure switch-type (e.g. microswitch) endstop for low end on X via pin e5stop + e6stop
      M574 Y1 S1 P"duex.e4stop"										; configure switch-type (e.g. microswitch) endstop for low end on Y via pin e4stop
      M574 U2 S1 P"duex.e3stop"										; configure switch-type (e.g. microswitch) endstop for low end on Secondary via pin e3stop
      ; Automatic Z Offset Calibration____________________________________
      M574 Z1 S1 P"!duex.e2stop"										; configure switch-type for Automatic z-offset
      M558 P9 C"zprobe.in" H4 F180 T12000 A1 R0.5						; BLTouch probing settings
      M950 S0 C"duex.pwm5"											; sets the BLTouch probe
      M376 H10			                							; Height (mm) over which to taper off the bed compensation
      G31 P500 X0 Y32.4												; BLTouch X and Y offset
      M557 X{move.axes[0].min + sensors.probes[0].offsets[0] + 35, move.axes[0].max + sensors.probes[0].offsets[0] - 35} Y{move.axes[1].min + sensors.probes[0].offsets[1] + 35, move.axes[1].max + sensors.probes[0].offsets[1] - 35} P9:9
      																; The M557 is used to define the mesh grid area. It uses the P parameter to set the amount of probing points. P10:10 would be a 10x10 grid. Supports up to a 21x21 grid.
      M98 P"config_probe.g"											; Load the Z-offset from the config_probe.g file
      																; The Z_offset value is now set in config_probe.g, not in config.g
      																; Adjust the values there, do not adjust anything here.
      ; Heaters___________________________________________________________
      ;M140 H-1                                       					; disable heated bed (overrides default heater mapping)
      M308 S12 P"spi.cs2" Y"thermocouple-max31856" A"Bed Temp" F60	; enables pt1000 bed temp sensor on pin bedtemp
      M950 H2 C"bedheat" T12 Q1; create bed heater output on bedheat and map it to sensor 12
      M307 H2 R0.264 K0.231:0.000 D2.90 E1.35 S1.00 B0  ; enable pwm mode with these settings
      M140 H2 ; map heated bed to heater 2
      M143 H2 S120 ; set temperature limit for heater 0 to 120C
      ;E0_________________________________________________________________
      ;M308 S0 P"e0temp" Y"thermistor" T100000 B4725   				; configure sensor 0 as thermistor on pin e0temp
      ;M308 S0 P"spi.cs1" Y"rtd-max31865"								; Configure sensor 0 as PT100 via the daughterboard
      M308 S0 P"e0temp" Y"pt1000"										; Configure sensor 0 as PT1000 on pin e0temp
      M950 H0 C"e0heat" T0                            				; create nozzle heater output on e0heat and map it to sensor 0
      M98 P"PID_tune_E0.g" R1										; PID calibration
      M143 H0 S300                                    				; set temperature limit for heater 0 to 285C
      ;E1_________________________________________________________________
      ;M308 S1 P"e1temp" Y"thermistor" T100000 B4725   				; configure sensor 1 as thermistor on pin e1temp
      ;M308 S1 P"spi.cs2" Y"rtd-max31865"								; Configure sensor 1 as PT100 via the daughterboard
      M308 S1 P"e1temp" Y"pt1000"										; Configure sensor 1 as PT1000 on pin e1temp
      M950 H1 C"e1heat" T1                            				; create nozzle heater output on e1heat and map it to sensor 1
      M98 P"PID_tune_E1.g" R1											; PID calibration
      M143 H1 S300                                    				; set temperature limit for heater 1 to 285C
      ;DHT Sensor on Temperature Daughterboard SPI CS6 pin
      ;M308 S10 P"0.spi.cs6" Y"dht22" A"Chamber Temp" ; define DHT22 temperature sensor
      ;M308 S11 P"S10.1" Y"dht-humidity" A"Chamber Hum[%]" ; Attach DHT22 humidity sensor to secondary output of temperature sensor
      ; Fans______________________________________________________________
      M950 F0 C"fan0" Q500                            				; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1 C"Primary blower fan"							; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                            				; create fan 1 on pin fan1 and set its frequency
      M106 P1 S0 H-1 C"Secondary blower fan"							; set fan 1 value. Thermostatic control is turned on
      M950 F3 C"duex.fan5" Q500                       				; create fan 3 on pin fan5 and set its frequency
      M106 P3 S255 H0 T45                             				; set fan 3 value. Thermostatic control is turned on
      M950 F4 C"duex.fan6" Q500                       				; create fan 4 on pin fan6 and set its frequency
      M106 P4 S255 H1 T45                             				; set fan 4 value. Thermostatic control is turned on
      ; LED______________________________________________________________
      M950 F2 C"duex.fan7" Q500                            			; create LED on pin fan7 and set its frequency
      M106 P2 S0 H-1 C"LED Primary"                            		; Disable fan channel for LED
      M950 F5 C"duex.fan8" Q500                            			; create LED ENC on pin fan8 and set its frequency
      M106 P5 S0 H-1 C"LED ENC"                              			; Disable fan channel for LED
      M950 F6 C"duex.fan4" Q500                            			; create LED Secondary on pin fan4 and set its frequency
      M106 P6 S0 H-1 C"LED Secondary"                              	; Disable fan channel for LED
      M106 P5 S255													; Enclosure LED on by default
      M106 P2 S255													; Secondary LED on by default
      M106 P6 S255													; Primary LED on by default
      ; Tools______________________________________________________________
      ;T0_________________________________________________________________
      M563 P0 S"E0 Primary" D0 H0 F0 	                				; define tool 0
      G10 P0 X0 Y0 Z0                                 				; set tool 0 axis offsets
      G10 P0 S210 R180                                  				; set initial tool 0 active and standby temperatures to 210 and 180c by default
      ;T1_________________________________________________________________
      M563 P1 S"E1 Secondary" D1 H1 F1 Y3               				; define tool 1
      G10 P1 X0 Y0 Z-3                              					; set tool 1 axis offsets
      M98 P"config_probe_secondary.g"									; Set secondary Z-Offset
      M98 P"config_probe_offset_X.g"									; Set secondary Z-Offset
      G10 P1 S210 R180                                    			; set initial tool 1 active and standby temperatures to 210 and 180c by default
      ; Automatic power saving____________________________________________
      M911 S22.0 R23.5 P"M913 X0 Y0 U0 G91 M83 G1 Z3 E-5 F1000"     		; Set voltage thresholds and actions to run on power loss. Power Failure Pause
      ; Primary hotend Clog detector__________________________________________________
      M591 D0 P7 C"e0stop" S1 L3.33 E15 R08:400						; Clog Detector E0 [Add-On]
      ;Secondary hotend Clog detector__________________________________________________
      M591 D1 P7 C"e1stop" S1 L3.33 E15 R08:400						; Clog Detector E1 [Add-On]
      ; Crash detector__________________________________________________
      M950 J2 C"zstop" 												; create Input Pin 2 on pin E4 to for M581 Command.
      M581 P2 T0 S0 R0												; Crash Detector   [Add-On]
      ; Emergency stop button__________________________________________________
      M950 J3 C"ystop" 												; create Input Pin 2 on pin ystop to for M581 Command.
      M950 J4 C"xstop" 												; create Input Pin 2 on pin xstop to for M581 Command.
      M581 P3 T0 S1 R0 												; Emergency stop [Add-On]
      M581 P4 T0 S1 R0												; Emergency stop,  [Add-On]
      ; Enable Logging__________________________________________________
      M929 P"eventlog.txt" S1 ; start logging warnings to file eventlog.txt
      M501
        droftarts administrators @VasDrafts
        @VasDrafts Do you actually see the temperature reported by the bed temperature sensor change before the fault is reported, or does it seem stable? What is the exact error message (check the console)?
        It's worth checking the GND cable between the Duet and Duex, as this needs to be well-specified and connected to avoid transients on the ribbon cable GND wire between the Duet and Duex. See https://docs.duet3d.com/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#power-wiring
        That you have connected the thermocouple shielding to the GND on the TEMP_DB of the Duex may also be an issue, particularly if the ground wire between the Duet and Duex is not effective. Try connecting it directly to the Duet. I think any GND pin should be fine.
        Possibly also check the AC SSR that is controlling the bed. This needs to be a zero-crossing SSR, to avoid voltage spikes. See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_bed#mains-voltage-ac-bed-heater
        I note that you have is the bed switching at 1Hz (ie switching once per second) with the M950 H2 ... Q1 parameter, which I would have though would be low enough not to cause interference. It may also help to change the switching frequency of the extruder heaters, though they should be at the normal frequency of 250Hz. Send M950 H# to check.
        It may be worth experimenting with changing the heater fault detection, specifically the M570 R parameter. It may be that having all three heaters on causes a spike in the voltage, particularly when the bed is switched on or off, and causes the thermocouple to report more than three consecutive temperature reading failures. Try increasing the R parameter.
        VasDraftsundefined 1 Reply Last reply Reply Quote 0
          VasDrafts @droftarts
          @droftarts
          • I do. Temp is holding steady at 65C, but randomly spikes to 2000c once I have both extruders warming up/firing. It definitely happens less often (but still multiple times a minute) after changing the bed to 1hz.
          • M308 S12 returns: Sensor 12 (Bed Temp) type Thermocouple (MAX31856) using pin spi.cs2, reading 53.1, last error: sensor short to other wiring, thermocouple type K, reject 60Hz
          I will go double check the ground between duet and duex and also move the shielded cables ground. I wish there was a ground bar included by the manufacturer of this printer, as adding and maintaining grounds is quite annoying with how tight everything is. Anytime I've had electrical gremlins with my cars, it seems to always be a ground, so that's definitely on my mind. I will report back after I mess with the grounds. I guess checking continuity between parts of frame and ac ground would be beneficial as well?
          The SSR I'm using is a FOTEK KSR-40 DAE and should be zero-crossing. This was the SSR that Modix used along with their independent temp controller so I am hoping it is not a counterfeit.
          After I check on the ground situation, if still present, I will try increasing the R parameter. I have had my eye on the voltage as well. The printer shipped with a 340W meanwell PSU, but I have seen the voltage sag to 23.2V in the webui.
          Appreciate your assistance on this. I will report back once I experiment with the grounds.
            VasDrafts
            Changing the shielding ground pin made zero difference. In fact, not grounding the shielding has zero affect from what I can tell. I checked all of my connections I made and everything seems good there.
            Then this morning I decided to move the temp daughterboard to the duex instead of off of the duet. It appears that my open circuit is gone now but I will have to do additional testing when I get the time to do so. This is a machine I run at my 9-5 so I don't always get time to put into it depending on my workload.
            Will update this thread with any additional information I get.
            VasDraftsundefined 1 Reply Last reply Reply Quote 1
              VasDrafts @VasDrafts
              Unfortunately, the open circuit remains.
              Strange though, before I moved the daughter board, it would immediately give me open circuit warnings as soon as the 3 heaters fired at once.
              Now it took 5 to 10 minutes, until the machine heated up the bed to 60c and started cycling, and then the extruders to full temp. Only after that did I start getting the open circuit fault. The machine continues to run, but it shows random spikes to 2000c on the bed temp graph.
              Could a faulty K sensor be the culprit? The K sensor was already present and was originally wired to the separate temp controller that came on the modix. Maybe I should try a new K sensor and see if that solves it.
              Any thoughts?
                Have you been in touch with Modix support yet?
                @VasDrafts said in Sensor Open Circuit, only when E0, E1, and bed fire at once:
                This makes it sound like interference, or possibly a faulty or intermitent sensor/wire.
                  VasDrafts @Phaedrux
                  @Phaedrux
                  At this point, I suppose I should reach out to them. I'm sure the modification to have the duet control the bed heater is unsupported by them though.
                  I might try changing the k sensor to my own before reaching out. This sensor I'm attaching to now came already embedded in the silicone heater that the modix shipped with. The separate temp controller was set to k sensor in it's config but I know nothing more about that sensor that I connected to.
                  All I wanted was to be able to have long prints continue into the weekend and then have the bed heater turn off when completed. Having a completely separate bed heater control is a pain in the butt when the machine is not accessible outside of office hours.
                  Appreciate your thoughts and time on this.
                    dc42 administrators @VasDrafts
                    @VasDrafts check that the wires coming out of each thermocouple are isolated from the casing of the thermocouple, and therefore isolated from whatever metal parts the thermocouples are attached to. The MAX31856 requires the thermocouple connections to be isolated; but some thermocouples don't isolate the junction from the casing.
