Bed Leveling Daedalus/Railcore Printer -from Project R3D
I'm trying to sort out issues leveling the best on a daedalus 3d printer from Project R3d. From what I can tell it is mostly a RTP Railcore. It is a printer I inherited at work. It runs on a Duet3 board. Post is short because longer was not allowed by the forum.
The current heightmap shows a range from -2.989 to +2.080 mm. I've moved the print nozzle to the 4 corners as a test, and the deviation I find is only about 0.3 to 0.4 mm. I have ran G32 multiple times and the results never really get better, just different.
Can you post an image of your heightmap and the bed.g and config.g files so we can see what it's actually doing?
@Phaedrux
This unit came with a Ez-abl inductive bed sensor. Originally it was probing the bed on a 9 point grid. I changed that to 16 in hopes that it would be better. I was trying to avoid the magnets a bit more. This 16 point grid is what is currently active, but the 9 point grid is commented out in config.g.Here is a screen shot of the bed level -
The front left is 2.080, the rear right is -2.989Comment: I manually moved the bed to check height at all 4 corners. The difference was about 0.3 to 0.5mm, not 5 mm. Regardless of how many times I run the G32, the values virtually never changes.
Here is the config.g
G21 ;Work in millimetres
G90 ;Send absolute coordinates...
M83 ;...but relative extruder moves; Axis and motor configuration
M569 P0 S1 ;Drive 0 X / Rear
M569 P1 S1 ;Drive 1 Y / Front
M569 P2 S1 ;Drive 2 Z Front Left
M569 P3 S1 ;Drive 3 Z Rear Left
M569 P4 S1 ;Drive 4 Z Right
M569 P5 S0 ;Drive 5 Extruder
M667 S1 ;corexy modeM584 X0 Y1 Z2:3:4 E5 ; Map X to drive 0 Y to drive 1, Z to drives 2, 3, 4, and E to drive 5
;Leadscrew locations
;M671 X-38:-38:340 Y62.5:247.5:139 S7.5 ;X -38, -38, 340
;M671 X-24:-24:325 Y32:287:159 S7.5 ;X -38, -38, 340 this was the setting on 3/28/25
M671 X-34:-34:344 Y50:206:167 S7.5 ;X --34, -34, 344 Y 50, 206, 167 as measured on 3/28/25M350 X16 Y16 Z16 E16 I1 ;set 16x microstepping for axes with interpolation
M906 X1600 Y1600 Z1200 E600 I60 ;Set motor currents (mA) reduced E to 600 for lgx extruder
M201 X2000 Y2000 Z100 E1500 ;Accelerations (mm/s^2)
M203 X24000 Y24000 Z900 E3600 ;Maximum speeds (mm/min) was Z1800 tr8*4
M566 X1000 Y1000 Z100 E1500 ;Maximum jerk speeds mm/minute E60 Z60
M208 X310 Y300 Z345 ;set axis maxima and high homing switch positions (adjust to suit your machine)
M208 X0 Y0 Z-0.9 S1 ;set axis minima and low homing switch positions (adjust to make X=0 and Y=0 the edges of the bed)
M92 X200 Y200 Z1600 E400 ;steps/mm 0.9 z; End Stops
M574 X1 S1 P"io3.in" ;Map the X endstop to io3.in
M574 Y2 S1 P"io1.in" ;May the Y endstop to io1.in; Filament Sentinel
M591 P1 C"io4.in" S0 D0 ; filament monitor connected to E0 endstop; Thermistors
M308 S0 P"temp0" Y"thermistor" A"bed_heat" T100000 B4240 H0 L0 ;Bed thermistor - duet 3, connected to temp0M308 S1 P"temp1" Y"thermistor" A"e0_heat" T100000 B4725 C7.06e-8 H0 L0 ;duet3 e3d
;Define Heaters
M950 H0 C"out0" T0 ;Bed heater is on out0
M950 H1 C"out1" T1 ;Hotend heater is on out1M307 H0 A154.6 C1043.8 D1.5 S1.00 B1 ;Bed Heater duet 3 configuration
M307 H1 A370.6 C134.5 D4.1 S1.00 B0 ;Hotend duet 3 configuration 2/22/25 PID tune dateM570 S360 ;Hot end may be a little slow to heat up so allow it 180 seconds
M143 S305 ;Set max hotend temperature; Fans
M950 F0 C"out4" ;Hotend fan on "out4" connector
M106 P0 S255 H1 T0 ;enable thermostatic mode for hotend fan
M950 F1 C"out5" ;Layer fan on "out5" connector
M106 P1 S0 ;Layer Fan
M950 F2 C"out6" ;Layer fan on "out6" connector
M106 P2 S0 ;Layer Fan; Tool definitions
M563 P0 D0 H1 F1:2 ;Define tool 0
G10 P0 S0 R0 ;Set tool 0 operating and standby temperatures;EZ ABL
M558 P5 C"!io7.in" I1 H10 F180 T3600 ; set Z probe type to EZ ABL and the dive height + speeds
; from th3d M558 P5 C"!io7.in" H3 F900 T12000
G31 X-9.25 Y63 Z1.75 P25 ;Z offset can be adjusted hereM575 P1 S1 B57600
;G29 S1
; M557 X30:280 Y66:300 S125:117 ; This was the stock settings on the machine 3/29/25
M557 X15:300 Y66:300 S95:117 ;Trial setting 3/28/25M501
M140 H0
T0 ;select first hot end -
@sportdoc have you tried reducing the M201 and M203 Z settings, in case the Z motor is losing steps when the Z axis reverses direction after the probe triggers?
