Connecting External Servo Drive for Linear Motion Axis
i want to create the following setup:
2x Duet 6HC
2x Jenny ScienceLxs F60
2x Xvi 75V8S
5x Stepper
6x PT1000
4x 50W Heater for 2x Extruder with each 100WI am building a machine in industrial enviorment. Thus i need very high speeds.
I need some advice for connecting the external servo controllers. Documentation can be found here: https://www.jennyscience.com/asset/2492/f2e4570f5b5c032132612bf16abb228a?origin=/en/download
I cant find a documentation on how to connect 2x DUET3 and several external CAN servo controller. Would be very greatful for help! -
@simplesimson you can't connect steppers with external drivers to a 6HC when used in step/dir mode
You would need to use a 6XD or a 1XD. The 6XD is recommended over the 1XD.You can't connect CAN controlled stepper drivers to duet boards as it's not supported and CAN isn't really fast enough for the high step rates required
