    [3.6.0-rc.2] Code 3 move error
    Beta Firmware
    390
    • MaxGyverundefined
      MaxGyver
      I got the following error 15min into a printjob
      Error: Code 3 move error: new: start=966631163 overlap=951 time now=966595179, existing: s=966587720 t=44394 d=1.24 u=2.7822e-5 a=0.0000e+0 f=08
      M122
      RepRapFirmware for Duet 3 MB6HC version 3.6.0-rc.2 (2025-03-31 12:17:13) running on Duet 3 MB6HC v1.01 (SBC mode)
      Board ID: 0JD2M-999AL-D25S4-7J1D2-3SJ6K-T51V3
      Used output buffers: 1 of 40 (18 max)
      Error in macro line 101 while starting up: in file macro line 101: M591: Switch-type filament monitor must be connected to same CAN board as extruder driver or to main board
      Static ram: 137420
      Dynamic ram: 98656 of which 16 recycled
      Never used RAM 85548, free system stack 150 words
      Tasks: LASER(5,nWait 7,0.0%,167) SBC(2,nWait 7,0.9%,801) HEAT(3,nWait 6,0.0%,365) TMC(4,nWait 6,3.0%,375) CanReceiv(6,nWait 1,0.1%,770) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,352) MAIN(1,running,95.6%,500) IDLE(0,ready,0.3%,29) USBD(3,blocked,0.0%,149), total 99.9%
      Owned mutexes: HTTP(MAIN)
      Last reset 00:21:56 ago, cause: power up
      Last software reset at 2025-04-01 13:22, reason: MemoryProtectionFault mmarValid daccViol, Platform spinning, available RAM 108732, slot 1
      Software reset code 0x0160 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x00000000 SP 0x20415c18 Task MAIN Freestk 2282 ok
      Stack: 00000000 40826fe0 20412118 00000001 003ffff0 0049b499 0049b498 21070200 0049b499 20432f84 00000000 20432f84 00000000 204252a0 a5a5a5a5 204262a0 20420b94 00486a7b 20426390 00003466 00000001 00000184 00000065 00412ea9 00000000 00000000 003ffff0
      === Storage ===
      Free file entries: 20
      Segments created 934, maxWait 128061ms, bed comp in use: mesh, height map offset 0.000, hiccups added 0/0 (0.00/20.52ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
      Pos req/act/dcf: 91326.00/91430/-0.83 63682.00/63354/0.28 1788.00/1785/0.41
      Next step interrupt due in 203 ticks, disabled
      Driver 0: standstill, SG min n/a, mspos 8, reads 11665, writes 22 timeouts 1
      Driver 1: standstill, SG min n/a, mspos 8, reads 11665, writes 22 timeouts 1
      Driver 2: standstill, SG min n/a, mspos 8, reads 11665, writes 22 timeouts 1
      Driver 3: standstill, SG min n/a, mspos 8, reads 11665, writes 22 timeouts 1
      Driver 4: standstill, SG min n/a, mspos 8, reads 11665, writes 22 timeouts 1
      Driver 5: standstill, SG min n/a, mspos 8, reads 11665, writes 22 timeouts 1
      Phase step loop runtime (us): min=0, max=60, frequency (Hz): min=236, max=10000
      === DDARing 0 ===
      Scheduled moves 3922, completed 3885, LaErrors 0, Underruns [0, 0, 0]
      Segments left 1, axes/extruders owned 0x80000007, drives owned 0x80000007
      Code queue is empty
      === DDARing 1 ===
      Scheduled moves 0, completed 0, LaErrors 0, Underruns [0, 0, 0]
      Segments left 0, axes/extruders owned 0x00000000, drives owned 0x00000000
      Code queue is empty
      Bed heaters -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters 2 -1 -1 -1 -1 -1 -1 -1, ordering errs 0
      Telnet is idle in state(s) 0
      File* is idle in state(s) 3
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Queue* is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      === Filament sensors ===
      Driver 31: no filament
      === CAN ===
      Messages queued 19452, received 86251, lost 0, ignored 0, errs 0, boc 0
      Longest wait 4ms for reply type 6061, peak Tx sync delay 384, free buffers 50 (min 46), ts 6241/6240/0
      Tx timeouts 0,0,0,0,0,0
      === SBC interface ===
      Transfer state: 5, failed transfers: 0, checksum errors: 0
      RX/TX seq numbers: 50065/50065
      SPI underruns 0, overruns 0
      State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x27a7c
      Buffer RX/TX: 1600/2632-0, open files: 0
      === Duet Control Server ===
      Duet Control Server version 3.6.0-rc.2 (2025-03-31 10:50:27, 32-bit)
      HTTP+Executed:
      > Executing M122
      File 0:/gcodes/LARGE SOFIA LAMPSHADE.gcode is selected, processing
      File:
      Buffered code: G1 X495.945 Y664.02 E358.16503
      Buffered code: G1 X495.564 Y664.136 E358.92333
      Buffered code: G1 X494.023 Y664.389 E361.89667
      Buffered code: G3 X493.237 Y664.311 I-0.249 J-1.495 E363.41372
      Buffered code: G1 X491.775 Y663.761 E366.38782
      Buffered code: G1 X491.424 Y663.573 E367.14595
      Buffered code: G1 X457.275 Y639.076 E447.1649
      Buffered code: G3 X456.100 Y635.169 I2.028 J-2.740 E455.47636
      Buffered code: G1 F1290.183
      Buffered code: G1 X456.143 Y634.924 E455.9573
      Buffered code: G1 F1270.82
      Buffered code: G1 X456.187 Y634.68 E456.44398
      Buffered code: G1 F1252.029
      Buffered code: G1 X456.23 Y634.436 E456.93761
      Buffered code: G1 F1234.896
      Buffered code: G1 X456.237 Y634.328 E457.15623
      Buffered code: G1 F1218.226
      Buffered code: G1 X456.245 Y634.22 E457.37798
      Buffered code: G1 F1201.999
      Buffered code: G1 X456.252 Y634.112 E457.60258
      Buffered code: G1 F1186.199
      Buffered code: G1 X456.259 Y634.004 E457.83017
      Buffered code: G1 F1170.809
      Buffered code: G1 X456.266 Y633.896 E458.06076
      Buffered codes: 1056 bytes total
      Code buffer space: 1600
      Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 1
      Full transfers per second: 24.81, max time between full transfers: 225.7ms, max pin wait times: 58.0ms/7.7ms
      Codes per second: 2.09
      Maximum length of RX/TX data transfers: 4604/1092
      config.g
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.15 on Fri Dec 09 2022 19:49:12 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                              ; send absolute coordinates...
      M83                                              ; ...but relative extruder moves
      M550 P"Duet 3"                                   ; set printer name
      ;/// Global variables ///
      global minPrintX=0
      global maxPrintX=950
      global minPrintY=0
      global maxPrintY=1200
      ; Wait a moment for the CAN expansion boards to start
      G4 S1
      M80 C"pson"                                      ; allocates the pin and sets the pin in the power on state.
      M569 P123.0 S1 R1 T5                             ; physical drive 121.0 goes forwards
      M569 P124.0 S0 R1 T5                             ; physical drive 122.0 goes forwards
      M569 P125.0 S0 R1 T5                             ; physical drive 123.0 goes forwards
      M569 P10.0 S1 D2                                 ; driver 0.4 goes backwards (Extruder)
      M569 P1.0 S1 D2
      ; Closed-Loop Drivers
      ;M569.1 P10.0 T3 E1000:100 R100 I2000 D0.1 V0 A0  ; Extruder
      M584 Y123.0 X124.0 Z125.0 E1.0                  ; set drive mapping
      M350 X1 Y1 Z1 E16 I0                             ; configure microstepping without interpolation
      M92 X193.05 Y100 Z800.00 E490                    ; set steps per mm
      M906 E2500                                       ; set motor currents
      M201 X500 Y500 Z250 E3000                        ; set maximum accelerations
      M203 X24000 Y24000 Z3000 E6000                   ; set maximum speeds (mm/min)
      M205 X8 Y8 Z2 E10                                 ; M205 X5 Y5 Z2 E3 P0                              ; set jerk;M566 X125 Y125 Z60 P0 ;set jerk
      M204 P250 T500                                   ; set printing and travel acceleration
      M84 S30                                          ; Set idle timeout
      M208 X0 Y0 Z0 S1                                 ; set axis minima
      M208 X960 Y1500 Z1005 S0                         ; set axis maxima
      M574 X1 S1 P"1.io1.in"                           ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 1.io1.in
      M574 Y1 S1 P"0.io0.in"                           ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io2.in
      M574 Z2 S1 P"1.io0.in"                           ; configure switch-type (e.g. microswitch) endstop for high end on Z via pin io3.in
      M558 P8 C"1.io5.in" H5 S0.03 A5 R0.5 F300 T12000 ; set Z probe type to switch and the dive height + speeds
      G31 P1000 X-74 Y+17 Z0.8                         ; set Z probe trigger value, offset and trigger height
      M557 X0:1000 Y0:1500 S200                        ; define mesh grid
      ; Sensors
      M308 S0 P"1.temp0" Y"pt1000" A"Heizzohne 1"
      M308 S1 P"1.temp1" Y"pt1000" A"Heizzohne 2"
      M308 S2 P"1.temp2" Y"pt1000" A"Einzug"
      M308 S3 P"2.temp0" Y"thermistor" A"Gebläse" T100000 B3950 C7.06e-8
      M308 S4 P"2.temp1" Y"thermistor" A"Luftheizung" T100000 B4725 C7.06e-8
      M308 S5 P"2.temp2" Y"thermistor" A"Trockenluft" T100000 B4725 C7.06e-8
      M950 H0 C"1.out0" T0                             ; create nozzle heater output on out0 and map it to sensor 0
      M307 H0 R1.120 K0.193:0.000 D10.84 E1.35 S1.00 B0 V23.0
      M143 H0 S300                                     ; set temperature limit for heater 0 to 280C
      M950 H1 C"1.out1" T1                             ; create nozzle heater output on out1 and map it to sensor 0
      M307 H1 R1.120 K0.193:0.000 D10.84 E1.35 S1.00 B0 V23.0
      M143 H1 S300                                     ; set temperature limit for heater 0 to 280C
      M950 H2 C"2.out2" T4 A"Luftheizung"              ; create chamber heater output on out2 and map it to sensor 2
      M307 H2 R2.598 K2.549:0.000 D3.91 E1.35 S1.00 B0 ; disable bang-bang mode for the chamber heater and set PWM limit
      M141 H2                                          ; map chamber to heater 2
      M143 H2 S120                                     ; set temperature limit for heater 2 to 100C
      M950 F0 C"1.out6" Q10000
      M106 P0 H2 S0 B1 L0.5 T50:60  C"Extruder Cooling Fan"
      M950 F1 C"1.out3+out3.tach"
      M106 P1 S0 H-1 C"Part Cooling Fan"
      M950 F2 C"!2.out3+out3.tach" K3 Q25000           ; create fan #2
      M106 P2 S0 B0 H-1 L0.4 C"Granulat Trockner Gebläse"
      M950 F3 C"1.out7"                                ; create fan #2
      M106 P3 S1 H-1 B1 C"Extruder Motor Kühlung"
      M563 P0 S"Extruder" D0 H0:1 F0:1                 ; define tool 0
      G10 P0 X80 Y0 Z0                                 ; set tool 0 axis offsets
      G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
      M309 P0 S0.002                                   ;set heat feed forward
      M207 S6 R1.8 F8000 Z3
      ;M572 P0 S0.005 ; set extruder 0 pressure advance to 0.1 seconds
      ;Valves
      M950 P0 C"2.out0" A"Ventil-Trichter"
      M950 P1 C"2.out1" A"Ventil-Schlauch"
      ; Filament monitor
      ;M591 P3 C"1.io4.in" S0 D0 R90:110 L28.8 ; filament monitor connected to 1.io.3 , pin is high when filament is present
      M591 D0 P1 C"1.io2.in" S1                       ; Material monitor connected to 1.io.0 , pin is low when material is present
      ; Input/Output
      M950 J0 C"!io3.in"                               ; Input 3 uses io3.in.iso pin
      M581 P0 S1 T2 R0                                 ; run trigger2.g when io.3.in goes high
      M581 P0 S0 T3 R0                                 ; run trigger3.g when io.3.in goes low
      T0
      ; /// Input Shaping ///
      ;M955 P20.0 I45                                   ; ACC Z+ -> X+ Axis, ACC X+-> Y- Axis                                                    ; configure accelerometer
      M593 P"EI3" S0.05 F8.7
      M569 P10.0 S1 D4
      M501                                             ; load saved parameters from non-volatile memory
      ;M595 P120                                        ;Set movement queue length
      jay_s_ukundefined dc42undefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @MaxGyver
        @MaxGyver can you also, just for completeness, provide the M122 output from your connected toolboard etc?
        MaxGyverundefined 1 Reply Last reply Reply Quote 0
          dc42 administrators @MaxGyver
          @MaxGyver said in [3.6.0-rc.2] Code 3 move error:
          I noticed the above in your M122 report. Do you know what provoked it?
          • MaxGyverundefined
            MaxGyver @dc42
            @dc42 said in [3.6.0-rc.2] Code 3 move error:
            Unfortunately not. I had the same error again while printing the firts layer.
            M122
            Static ram: 137420
            Dynamic ram: 98656 of which 0 recycled
            Never used RAM 86548, free system stack 130 words
            Tasks: LASER(5,nWait 7,0.0%,167) SBC(2,nWait 7,0.9%,809) HEAT(3,nWait 6,0.0%,343) TMC(4,nWait 6,3.0%,375) CanReceiv(6,nWait 1,0.1%,770) CanSender(5,nWait 7,0.0%,327) CanClock(7,delaying,0.0%,348) MAIN(1,running,95.9%,500) IDLE(0,ready,0.1%,29) USBD(3,blocked,0.0%,149), total 100.0%
            Last reset 00:51:27 ago, cause: software
            Last software reset at 2025-04-01 13:56, reason: User, Platform spinning, available RAM 85548, slot 2
            Software reset code 0x2000 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
            === Storage ===
            Segments created 893, maxWait 1145489ms, bed comp in use: mesh, height map offset 0.000, hiccups added 0/0 (0.00/22.42ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
            Pos req/act/dcf: 98537.00/98253/0.34 62047.00/62132/-0.86 2388.00/2389/-0.87
            Next step interrupt due in 142 ticks, disabled
            Driver 0: standstill, SG min n/a, mspos 8, reads 15179, writes 22 timeouts 1
            Driver 1: standstill, SG min n/a, mspos 8, reads 15179, writes 22 timeouts 1
            Driver 2: standstill, SG min n/a, mspos 8, reads 15179, writes 22 timeouts 1
            Driver 3: standstill, SG min n/a, mspos 8, reads 15179, writes 22 timeouts 1
            Driver 4: standstill, SG min n/a, mspos 8, reads 15179, writes 22 timeouts 1
            Driver 5: standstill, SG min n/a, mspos 8, reads 15179, writes 22 timeouts 1
            Phase step loop runtime (us): min=0, max=46, frequency (Hz): min=205, max=10000
            === DDARing 0 ===
            Scheduled moves 4906, completed 4846, LaErrors 0, Underruns [0, 0, 0]
            Segments left 10, axes/extruders owned 0x80000007, drives owned 0x80000007
            Code queue is empty
            === DDARing 1 ===
            Code queue is empty
            === CAN ===
            Messages queued 30786, received 201368, lost 0, ignored 0, errs 0, boc 0
            Longest wait 2ms for reply type 6013, peak Tx sync delay 386, free buffers 50 (min 46), ts 14635/14634/0
            RX/TX seq numbers: 53220/53220
            Buffer RX/TX: 864/2072-0, open files: 0
            HTTP+Executed:
            > Executing M122
            File:
            Buffered code: G3 X595.405 Y624.085 I-4.314 J1.866 E59.03433
            Buffered code: G1 X595.555 Y625.451 E61.65082
            Buffered code: G1 X595.363 Y626.871 E64.3791
            Buffered code: G1 X595.253 Y627.261 E65.15063
            Buffered code: G1 X594.762 Y628.389 E67.49298
            Buffered code: G1 X594.557 Y628.731 E68.25217
            Buffered code: G1 X593.692 Y629.799 E70.86893
            Buffered code: G1 X530.615 Y691.023 E238.23745
            Buffered code: G1 X529.101 Y692.304 E242.01349
            Buffered code: G1 X527.47 Y693.353 E245.70575
            Buffered code: G1 X525.685 Y694.194 E249.46271
            Buffered code: G1 X523.985 Y694.745 E252.86527
            Buffered code: G1 X522.022 Y695.116 E256.66898
            Buffered code: G1 X520.059 Y695.221 E260.41187
            Buffered code: G1 X518.125 Y695.07 E264.1054
            Buffered code: G1 X516.185 Y694.66 E267.88074
            Buffered code: G1 X444.689 Y674.356 E409.39167
            Buffered code: G3 X442.260 Y671.078 I0.979 J-3.264 E417.70323
            Buffered code: G1 F1290.186
            Buffered code: G1 X442.218 Y670.833 E418.18384
            Buffered code: G1 F1270.827
            Buffered code: G1 X442.176 Y670.589 E418.66983
            Buffered code: G1 F1252.039
            Buffered code: G1 X442.134 Y670.344 E419.16508
            Buffered code: G1 F1234.906
            Buffered code: G1 X442.104 Y670.24 E419.38373
            Buffered code: G1 F1218.236
            Buffered codes: 1248 bytes total
            Code buffer space: 2024
            Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
            Full transfers per second: 38.54, max time between full transfers: 362.2ms, max pin wait times: 73.7ms/16.9ms
            Codes per second: 1.65
            Maximum length of RX/TX data transfers: 4604/1352
            • MaxGyverundefined
              MaxGyver @jay_s_uk
              I just upgraded the printer to a RPI5 with a clean install...still the same error
              @jay_s_uk said in [3.6.0-rc.2] Code 3 move error:
              Sure, here are the diagnostics of all boards including the mainboard:
              M122 B0
              Static ram: 137420
              Dynamic ram: 98632 of which 0 recycled
              Never used RAM 106540, free system stack 132 words
              Tasks: LASER(5,nWait 7,0.0%,167) SBC(2,nWait 7,0.9%,825) HEAT(3,nWait 6,0.0%,367) TMC(4,nWait 6,3.1%,375) CanReceiv(6,nWait 1,0.1%,782) CanSender(5,nWait 7,0.0%,329) CanClock(7,delaying,0.0%,350) MAIN(1,running,95.6%,500) IDLE(0,ready,0.4%,29) USBD(3,blocked,0.0%,149), total 100.0%
              Last reset 00:18:15 ago, cause: software
              Last software reset at 2025-04-01 16:42, reason: User, Gcodes spinning, available RAM 96348, slot 2
              Software reset code 0x6003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
              === Storage ===
              Segments created 61, maxWait 260198ms, bed comp in use: mesh, height map offset 0.000, hiccups added 0/0 (0.00/12.06ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
              Pos req/act/dcf: 74103.00/69052/0.53 48913.00/48970/-0.49 902.00/900/0.64
              No step interrupt scheduled
              Driver 0: standstill, SG min n/a, mspos 8, reads 28346, writes 11 timeouts 0
              Driver 1: standstill, SG min n/a, mspos 8, reads 28346, writes 11 timeouts 0
              Driver 2: standstill, SG min n/a, mspos 8, reads 28346, writes 11 timeouts 0
              Driver 3: standstill, SG min n/a, mspos 8, reads 28346, writes 11 timeouts 0
              Driver 4: standstill, SG min n/a, mspos 8, reads 28346, writes 11 timeouts 0
              Driver 5: standstill, SG min n/a, mspos 8, reads 28346, writes 11 timeouts 0
              Phase step loop runtime (us): min=0, max=30, frequency (Hz): min=1102, max=9868
              === DDARing 0 ===
              Scheduled moves 181, completed 176, LaErrors 0, Underruns [0, 0, 0]
              Code queue is empty
              === DDARing 1 ===
              Code queue is empty
              HTTP* is doing "M122 B0" in state(s) 0
              Queue is idle in state(s) 0
              === CAN ===
              Messages queued 5971, received 71111, lost 0, ignored 0, errs 0, boc 0
              Longest wait 9ms for reply type 6024, peak Tx sync delay 372, free buffers 50 (min 46), ts 5193/5192/0
              RX/TX seq numbers: 42674/42674
              Buffer RX/TX: 776/2296-0, open files: 0
              Duet Control Server version 3.6.0-rc.2 (2025-03-31 10:53:52, 64-bit)
              HTTP+Executed:
              > Executing M122
              File:
              Buffered code: G1 X559.936 Y489.031 E95.74515
              Buffered code: G1 X562.242 Y489.426 E97.48178
              Buffered code: G1 X564.283 Y490.57 E99.21853
              Buffered code: G1 X565.909 Y492.472 E101.07594
              Buffered code: G1 X626.069 Y596.422 E190.22657
              Buffered code: G1 X626.881 Y598.616 E191.96309
              Buffered code: G1 X626.911 Y600.956 E193.70017
              Buffered code: G1 X626.077 Y603.314 E195.55672
              Buffered code: G1 X566.134 Y707.39 E284.70781
              Buffered code: G1 X564.639 Y709.19 E286.44466
              Buffered code: G1 X562.628 Y710.386 E288.18143
              Buffered code: G1 X560.168 Y710.843 E290.03869
              Buffered code: G1 X440.064 Y710.969 E379.18981
              Buffered code: G1 X437.758 Y710.574 E380.92644
              Buffered code: G1 X435.717 Y709.43 E382.66319
              Buffered code: G1 X434.091 Y707.528 E384.5206
              Buffered code: G1 X373.931 Y603.578 E473.67123
              Buffered code: G1 X373.119 Y601.384 E475.40775
              Buffered code: G1 X373.089 Y599.044 E477.14483
              Buffered code: G1 X373.923 Y596.686 E479.00138
              Buffered code: G1 X433.866 Y492.61 E568.15247
              Buffered code: G1 X435.074 Y491.156 E569.55563
              Buffered code: G1 E566.55563 F6000
              Buffered code: G92 E0
              Buffered code: G1 Z2 F18000
              Buffered code: G1 X488.207 Y581.793
              Buffered code: G1 Z1
              Buffered code: G1 E3 F6000
              Buffered code: G1 F3360.595
              Buffered codes: 1344 bytes total
              Code buffer space: 1800
              Full transfers per second: 39.19, max time between full transfers: 40.8ms, max pin wait times: 38.7ms/0.5ms
              Codes per second: 0.21
              Maximum length of RX/TX data transfers: 5240/1072
              M122 B1
              Diagnostics for board 1:
              Duet EXP3HC rev 1.01 or earlier firmware version 3.6.0-rc.2 (2025-03-31 12:21:29)
              Bootloader ID: not available
              All averaging filters OK
              Never used RAM 168744, free system stack 182 words
              Tasks: Move(3,nWait 7,0.0%,134) TMC(2,nWait 6,7.3%,95) HEAT(2,nWait 6,0.1%,110) CanAsync(5,nWait 4,0.0%,66) CanRecv(3,nWait 1,0.0%,73) CanClock(5,nWait 1,0.0%,63) MAIN(1,running,91.5%,295) IDLE(0,ready,0.0%,39) AIN(2,delaying,1.1%,261), total 100.0%
              Owned mutexes:
              Last reset 00:12:31 ago, cause: software
              Last software reset at 2023-05-24 22:19, reason: StackOverflow, available RAM 158036, slot 1
              Software reset code 0x0100 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0048180e BFAR 0xe000ed38 SP 0x2002ffbc Task HEAT Freestk 44648 ok
              Stack: 200045c0 200045f4 00026599 00000000 20003c94 000000fa 00025c45 200047cc 20003c94 00000000 00f00000 e000e000 c0000000 00000006 00025d81 00025b00 21000000 ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff ffffffff
              Moves scheduled 5, hiccups 0 (0.00/12.06ms), segs 18, step errors 0 (types 0x0), maxLate 0 maxPrep 53, ebfmin 0.00 max 0.00
              Peak sync jitter -7/5, peak Rx sync delay 212, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 4167254009 ticks, disabled
              VIN voltage: min 22.7, current 24.0, max 24.0
              V12 voltage: min 12.3, current 12.3, max 12.3
              MCU temperature: min 28.1C, current 30.4C, max 30.8C
              Driver 0: pos 10497, 490.0 steps/mm, standstill, SG min 0, mspos 1016, reads 21243, writes 19 timeouts 0
              Driver 1: pos 0, 80.0 steps/mm, standstill, SG min n/a, mspos 8, reads 21251, writes 11 timeouts 0
              Driver 2: pos 0, 80.0 steps/mm, standstill, SG min n/a, mspos 8, reads 21252, writes 11 timeouts 0
              Last sensors broadcast 0x00000007 found 3 27 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 15645, send timeouts 0, received 6770, lost 0, ignored 0, errs 0, boc 0, free buffers 38, min 38, error reg 0
              dup 0, oos 0/0/0/0, rxMotionDelay 293, adv 35729/37075
              Interrupt 5726621 to 0us, poll 1 to 254us
              Driver 0: ok
              	M122 B2
              Diagnostics for board 2:
              Never used RAM 169692, free system stack 202 words
              Tasks: Move(3,nWait 7,0.0%,176) TMC(2,nWait 6,7.1%,95) HEAT(2,nWait 6,0.1%,117) CanAsync(5,nWait 4,0.0%,70) CanRecv(3,nWait 1,0.0%,73) CanClock(5,nWait 1,0.0%,63) MAIN(1,running,91.7%,321) IDLE(0,ready,0.0%,39) AIN(2,delaying,1.1%,261), total 100.0%
              Owned mutexes:
              Last reset 00:15:46 ago, cause: software
              Last software reset data not available
              Moves scheduled 0, hiccups 0 (0.00/12.06ms), segs 0, step errors 0 (types 0x0), maxLate 0 maxPrep 0, ebfmin 0.00 max 0.00
              Peak sync jitter -6/5, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 3584711043 ticks, disabled
              VIN voltage: min 23.8, current 23.9, max 23.9
              V12 voltage: min 12.2, current 12.2, max 12.2
              MCU temperature: min 29.9C, current 30.4C, max 30.6C
              Driver 0: pos 0, 80.0 steps/mm, standstill, SG min n/a, mspos 8, reads 59275, writes 11 timeouts 0
              Driver 1: pos 0, 80.0 steps/mm, standstill, SG min n/a, mspos 8, reads 59275, writes 11 timeouts 0
              Driver 2: pos 0, 80.0 steps/mm, standstill, SG min n/a, mspos 8, reads 59276, writes 11 timeouts 0
              Last sensors broadcast 0x00000038 found 3 11 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 18822, send timeouts 0, received 8247, lost 0, ignored 0, errs 0, boc 0, free buffers 38, min 38, error reg 0
              dup 0, oos 0/0/0/0, rxMotionDelay 0
              	M122 B123
              Diagnostics for board 123:
              Duet EXP1XD firmware version 3.6.0-rc.2 (2025-03-31 12:21:12)
              Bootloader ID: SAMC21 bootloader version 2.3 (2021-01-26b1)
              Never used RAM 9016, free system stack 75 words
              Tasks: Move(3,nWait 7,0.0%,92) HEAT(2,nWait 6,0.1%,124) CanAsync(5,nWait 4,0.0%,58) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) MAIN(1,running,64.9%,420) IDLE(0,ready,0.0%,40) AIN(2,nWait 2,34.9%,112), total 100.0%
              Owned mutexes:
              Last reset 00:14:27 ago, cause: software
              Last software reset at 2024-10-09 17:58, reason: OutOfMemory, available RAM 8, slot 0
              Software reset code 0x01c0 ICSR 0x00000000 SP 0x20004c98 Task Move Freestk 96 ok
              Stack: 20004ef8 00005a4b 00000000 36532722 00029e30 0000797b 00000000 000064ad 20007160 00000000 2fd75a5f b9b6dd11 fffffffd 00000496 b9b6ddaa 20004fe8 2000193f 20004d74 00029e30 20004a4c 20004990 bfa4c566 20004fe8 00000784 36532e2f 00006ab7 bf2a04ab
              Moves scheduled 29, hiccups 5 (0.25/12.06ms), segs 22, step errors 0 (types 0x0), maxLate 0 maxPrep 1245, ebfmin 0.00 max 0.00
              Peak sync jitter 2/7, peak Rx sync delay 256, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 4080735155 ticks, disabled
              VIN voltage: min 23.7, current 23.8, max 23.9
              MCU temperature: min 27.0C, current 27.2C, max 38.3C
              Driver 0: pos -4185, 100.0 steps/mm
              Last sensors broadcast 0x00000000 found 0 85 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 6966, send timeouts 0, received 10909, lost 0, ignored 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
              dup 0, oos 0/0/0/0, rxMotionDelay 337, adv 34992/37159
              	M122 B124
              Diagnostics for board 124:
              Never used RAM 9040, free system stack 75 words
              Tasks: Move(3,nWait 7,0.0%,90) HEAT(2,nWait 6,0.1%,124) CanAsync(5,nWait 4,0.0%,58) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) MAIN(1,running,64.8%,420) IDLE(0,ready,0.0%,40) AIN(2,nWait 2,35.1%,112), total 100.0%
              Owned mutexes:
              Last reset 00:14:47 ago, cause: software
              Software reset code 0x01c0 ICSR 0x00426000 SP 0x20004c98 Task Move Freestk 96 ok
              Stack: 20004ef8 00005a4b 00000000 365335b3 00029e30 0000797b 00000000 000064ad 20006c08 80000000 b021828c 3a08fff3 20004990 20006d28 365335b3 20006d28 00eedf29 20004d74 00029e30 20004a4c 20004990 3ff72819 20006d28 00000786 36533cc0 00006ab7 3f7f27c5
              Moves scheduled 49, hiccups 167 (8.24/12.06ms), segs 21, step errors 0 (types 0x0), maxLate 0 maxPrep 1592, ebfmin 0.00 max 0.00
              Peak sync jitter 1/6, peak Rx sync delay 265, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 4065336518 ticks, disabled
              VIN voltage: min 23.7, current 23.8, max 23.8
              MCU temperature: min 26.7C, current 26.9C, max 37.9C
              Driver 0: pos 6441, 193.1 steps/mm
              Last sensors broadcast 0x00000000 found 0 169 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 7130, send timeouts 0, received 11191, lost 0, ignored 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
              dup 0, oos 0/0/0/0, rxMotionDelay 471, adv 35006/37151
              M122 B125
              Diagnostics for board 125:
              Never used RAM 9064, free system stack 75 words
              Tasks: Move(3,nWait 7,0.0%,92) HEAT(2,nWait 6,0.1%,124) CanAsync(5,nWait 4,0.0%,58) CanRecv(3,nWait 1,0.0%,70) CanClock(5,nWait 1,0.0%,58) MAIN(1,running,64.2%,424) IDLE(0,ready,0.0%,40) AIN(2,nWait 2,35.6%,112), total 100.0%
              Owned mutexes:
              Last reset 00:15:11 ago, cause: software
              Moves scheduled 179, hiccups 71 (3.58/12.06ms), segs 20, step errors 1 (types 0x8), maxLate 0 maxPrep 1241, ebfmin 0.00 max 0.00
              Peak sync jitter 1/6, peak Rx sync delay 255, resyncs 0/0, no timer interrupt scheduled, next step interrupt due in 4046779478 ticks, disabled
              VIN voltage: min 24.0, current 24.1, max 24.2
              MCU temperature: min 26.3C, current 26.7C, max 36.9C
              Driver 0: pos -99650, 800.0 steps/mm
              Last sensors broadcast 0x00000000 found 0 24 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 7318, send timeouts 0, received 11690, lost 0, ignored 0, errs 0, boc 0, free buffers 18, min 17, error reg 0
              dup 0, oos 0/0/0/0, rxMotionDelay 324, adv 35305/37173
                Do you mean the same Code 3 error?
                • MaxGyverundefined
                  MaxGyver @dc42
                  Yes, I had the same Code 3 move error. I did not copy the error code tough.
                  • MaxGyverundefined
                    MaxGyver @MaxGyver
                    The issue is also present in 3.6.0-rc.1
                    Error: Code 3 move error: new: start=651528999 overlap=5623 time now=651492690, existing: s=651491803 t=42819 d=20.46 u=8.0975e-4 a=-1.5504e-8 f=18
                      @MaxGyver please provide the GCode file that provokes these errors.
                      • MaxGyverundefined
                        MaxGyver @dc42
                        Here you go:
                        dc42undefined 3 Replies Last reply Reply Quote 0
                          @MaxGyver thanks, I'll try to reproduce it. We haven't had any other reports of Code 3 errors since we released RC4.
                            @MaxGyver not related to the Code 3 errors, but I noticed this in your config.g file:
                            M205 and M566 no longer do the same thing with different units in 3.6. M566 sets the machine limits (in mm/min) while M205 sets the limits for the current print, if they are lower than the M566 limits when converted to the same units. See https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x-RC#upgrade-notes-from-354.
                              @MaxGyver I believe I have identified the cause of these errors. If I am right, they only occur when the input shaping frequency is below about 12Hz, which would explain why nobody else has reported Code 3 errors since we released beta4.
                              Please try the new 3.6.0-rc.2+2 main board firmware binary from https://www.dropbox.com/scl/fo/nlkfneaas1osgtdw37s17/AIS_H0KSAKCmfYSjSRTSOAE?rlkey=ad4omnq36zkdz3wl8i7kthqqt&dl=0. You may keep your expansion board binaries at 3.6.0-rc.2 or upgrade them to rc.2+1 from https://www.dropbox.com/scl/fo/kj7gwwzxg5lhe26twph5z/AAdwkPCTYi6bcogLmIIIup4?rlkey=8oo6z5il7wzk2u5b7qpykf3qv&dl=0.
                              • MaxGyverundefined
                                MaxGyver @dc42
                                I finally had a chance to test the latest 3.6.0-rc.3. When the input shaping frequency is set below 12Hz I still have a code 3 movement error always at the same code line early in the first layer. When the IS frequency is >12Hz it is working. I have attached the test pot.gcode file that is causing the error.
                                Error: Code 3 move error: new: start=335135293 overlap=3753 time now=335099122, existing: s=335096227 t=42819 d=20.49 u=8.1090e-4 a=-1.5526e-8 f=18
                                M122
                                RepRapFirmware for Duet 3 MB6HC version 3.6.0-rc.3 (2025-04-30 14:43:53) running on Duet 3 MB6HC v1.01 (SBC mode)
                                Used output buffers: 1 of 40 (19 max)
                                Static ram: 137420
                                Dynamic ram: 98720 of which 0 recycled
                                Never used RAM 107844, free system stack 130 words
                                Tasks: LASER(5,nWait 7,0.0%,235) SBC(2,nWait 7,1.1%,813) HEAT(3,nWait 6,0.0%,368) Move(4,nWait 6,0.0%,209) TMC(4,nWait 6,3.0%,377) CanReceiv(6,nWait 1,0.1%,792) CanSender(5,nWait 7,0.0%,329) CanClock(7,delaying,0.0%,350) MAIN(1,running,83.7%,500) IDLE(0,ready,12.1%,29) USBD(3,blocked,0.0%,149), total 100.0%
                                Last reset 00:02:34 ago, cause: software
                                Last software reset at 2025-05-12 11:06, reason: User, Gcodes spinning, available RAM 82500, slot 1
                                Software reset code 0x2003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                                Error status: 0x00
                                MCU temperature: min 33.9, current 34.3, max 35.0
                                Supply voltage: min 23.4, current 23.5, max 23.6, under voltage events: 0, over voltage events: 0, power good: yes
                                12V rail voltage: min 12.0, current 12.1, max 12.1, under voltage events: 0
                                Heap OK, handles allocated/used 99/16, heap memory allocated/used/recyclable 2048/320/52, gc cycles 0
                                Events: 599 queued, 599 completed
                                Date/time: 2025-05-12 11:08:41
                                Slowest loop: 1545.84ms; fastest: 0.07ms
                                === Storage ===
                                SD card 0 not detected, requested/actual speed: 0.0/37.5MBytes/sec
                                Segments created 3, maxWait 68608ms, bed comp in use: none, height map offset 0.000, hiccups added 0/0 (0.00/0.05ms), max steps late 0, ebfmin 0.00, ebfmax 0.00
                                Pos req/act/dcf: -464285.00/-463726/-0.50 0.00/0/0.00 804000.00/804000/0.00
                                Next step interrupt due in 22 ticks, disabled
                                Driver 0: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0
                                Driver 1: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0
                                Driver 2: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0
                                Driver 3: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0
                                Driver 4: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0
                                Driver 5: standstill, SG min n/a, mspos 8, reads 47118, writes 11 timeouts 0
                                Phase step loop runtime (us): min=0, max=40, frequency (Hz): min=1744, max=2358
                                === DDARing 0 ===
                                Scheduled moves 6, completed 5, LaErrors 0, Underruns [0, 0, 0]
                                Segments left 0, axes/extruders owned 0x80000007, drives owned 0x80000007
                                Code queue is empty
                                === DDARing 1 ===
                                Code queue is empty
                                Heater 0 is on, I-accum = 0.0
                                Heater 1 is on, I-accum = 0.0
                                Movement locks held by Trigger, null
                                File is idle in state(s) 0
                                Trigger* is idle in state(s) 2 0 5 0, running macro
                                === CAN ===
                                Messages queued 1431, received 9757, lost 0, ignored 0, errs 0, boc 0
                                Longest wait 4ms for reply type 6061, peak Tx sync delay 379, free buffers 50 (min 49), ts 734/733/0
                                RX/TX seq numbers: 6084/6084
                                State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x27a24
                                Buffer RX/TX: 208/256-0, open files: 0
                                Duet Control Server version 3.6.0-rc.3 (2025-04-30 10:29:48, 64-bit)
                                HTTP+Executed:
                                > Executing M122
                                Trigger:
                                Buffered code: G1 H1 X-1205 F{global.homingspeed/2} ; move slowly to X axis endstop once more (second pass)
                                Buffered code: G90 ; absolute positioning
                                Buffered codes: 96 bytes total
                                >> Doing macro trigger2.g, started by system
                                >>> Doing macro homeall.g, started by G28
                                >>> Suspended code: M98 P"homey.g"
                                >>>> Doing macro homex.g, started by M98 P"homex.g"
                                Code buffer space: 3840
                                Full transfers per second: 40.77, max time between full transfers: 1750.1ms, max pin wait times: 39.5ms/4.0ms
                                Codes per second: 0.71
                                Maximum length of RX/TX data transfers: 4468/904
                                  @MaxGyver thanks for your report. When that error was reported, did you still have input shaping set to 8.7Hz EI3 in config.g?
                                  • MaxGyverundefined
                                    MaxGyver @dc42
                                    @dc42 Yes, Input shaping was Set to 8.7Hz EI3.
                                      @MaxGyver thanks.
                                      I found a bug in the previous fix. Please try the 6HC build from https://www.dropbox.com/scl/fo/dumsdufoej44q97ek9joo/AIBRnU-wtKfMrbWPzZwH_XY?rlkey=idmyinvvcuiwmycbb1l2obz38&dl=0.
