Upgrading Duet 2 WiFi to latest
@jay_s_uk Ah, OK. Tedious, but not a big deal. Will try now. Thanks.
@jay_s_uk Only problem is I can't find 2.05.01...
@jay_s_uk OK, thanks for that. I am now upgraded to 3.5.4
However, I am getting this error on connect:
I checked config.g and I can't see anything obvious (the configuration worked fine before the update).
I remember seeing something about RRF 3 having some configuration differences with respect to v2. Do I need to rebuild my config from scratch using the configurator? It'd be nice if a conversion utility exists.
Thanks.
In case the numbers look weird...it's a custom ballscrew 3d printer.
@martincho best to start a fresh with the config tool and then put your numbers in
@martincho said in Upgrading Duet 2 WiFi to latest:
Sorry, no conversion utility. See https://docs.duet3d.com/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
@droftarts Will do. Thanks.
@jay_s_uk said in Upgrading Duet 2 WiFi to latest:
On it. I backed-up the SD card before the upgrade, so I have all the data and customization settings.
Thanks for the help, Everything is up and running after the update. Now looking to experiment with input shaping.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
