    Failed to initialise WiFi module
    Duet Web Control
    2.8k
    • CreateAndCarveCNCundefined
      CreateAndCarveCNC @jay_s_uk
      @jay_s_uk The one I have is Duet2 Main W51596. It has an external aerial.
        jay_s_uk @CreateAndCarveCNC
        @CreateAndCarveCNC then you would need a ESP-WROOM-02U
        CreateAndCarveCNCundefined 1 Reply Last reply Reply Quote 0
          @jay_s_uk said in Failed to initialise WiFi module:
          ESP-WROOM-02U
          Thank you, can you recommend a reliable place to purchase at all please?
            @CreateAndCarveCNC amazon, aliexpress, ebay, RS. depends how long you want to wait to get one
              @jay_s_uk thank you, I need it asap to be honest, I have orders building up
              jay_s_ukundefined 1 Reply Last reply Reply Quote 1
                @CreateAndCarveCNC don't forget you can still run commands from USB so you can operate the machine
                  @jay_s_uk can I? I didn't know that?
                    @CreateAndCarveCNC yes. Any of the gcode commands will work, such as G28 to home, M23 to pick a file from the sd card and M24 to run the job. https://docs.duet3d.com/en/User_manual/Reference/Gcodes
                      @jay_s_uk thank you for this. This helps a lot. So I just send the commands via YAT bypassing the problem for now?
                        CreateAndCarveCNCundefined 2 Replies Last reply Reply Quote 0
                          @jay_s_uk thank you very much for the help, really appreciate it
                            @jay_s_uk Sorry to pester, but I have ben running a job and it now keeps cutting out with this code
                            Warning: VIN under-voltage event (9.2V)
                              @CreateAndCarveCNC that shows that you probably have an issue with your main power supply and that the board thinks the voltage is dropping below 9.2V (unless its an issue with the reference 3.3v supply on the board)
                                Phaedrux Moderator @CreateAndCarveCNC
                                @CreateAndCarveCNC said in Failed to initialise WiFi module:
                                December last year with my CNC machine from Ooznest.
                                Meaning December 2024, a few months ago? If so, we can do a warranty replacement.
                                  CreateAndCarveCNC @Phaedrux
                                  @Phaedrux yeah December 2024 I purchased. This would be perfect if it can be replaced
                                    Please send an email to warranty@duet3d.com and CC your reseller. Include a link to this forum thread and the details of your original purchase. You'll receive a reply with a form to fill out.
                                      @Phaedrux Thank you very much.
                                      Just a quick question, is there code to set the work XYZ to 0?
                                        @CreateAndCarveCNC G92
                                          @jay_s_uk Thank you 😄
