    D3 magnetic encoder/1hcl max rpm
    • 3DPMicroundefined
      3DPMicro
      What would be the maximum motor rpm and are there factors that contribute to it?
      Thanks
      Duet controlled Jet Lathe, scratch built micro mill and 3d printer. 1992 Haas VF2 VMC retrofit
        dc42 administrators @3DPMicro
        @3DPMicro the maximum motor RPM in closed loop mode is generally lower than in open loop mode and is heavily influenced by the motor inductance (lower is better) and supply voltage (higher is better).
        3DPMicroundefined 1 Reply Last reply Reply Quote 0
        • 3DPMicroundefined
          3DPMicro @dc42
          @dc42 thank you.
