    VDE100 tool changer
    vde100 screw extruder indx tool changer
    1
    1
    188
    • o_lampeundefined
      o_lampe
      Hi guys,
      do you remember the VDE100 screw extruder?
      It was meant as a DD-extruder on a smarteffector without fouling the rods.
      Now the Bondtech INDX toolchanger is coming up and that inspired me to redesign the VDE100.
      I added a pair of bevel gears which allows me to use a NEMA-08 motor without hollow shaft.
      The gears are also the point where I split the extruder.
      • Fixed to the linear rail: the motor, filament switch and the hotend
      • a set of toolhousings each hosting a modified VDE100.
      Here's a rough first teaser
      A shout out to @tombrazier and @rqthree who did the major work on screw extruders especially the VDE100
      • o_lampeundefined o_lampe referenced this topic
