    Multiple motion system call macro in the second motion system
    • pouryatorabiundefined
      pouryatorabi
      I want to do something like this:
      M596 P0
      G1 X50 F100
      M596 P1
      G1 W10 F200
      G1 W-10 F200
      M98 P"/macros/Macro1"
      What I expected was that while the system was moving to X50, I could move W back and forth by 10mm and then run "Macro1." But the system waits for the X movement to finish before running Macro1. How can I tell the system not to wait for the X movement?
      Also, is it possible to run two macros at the same time?
      dwuk3dundefined 1 Reply Last reply Reply Quote 0
      • dwuk3dundefined
        dwuk3d @pouryatorabi
        @pouryatorabi For M596 the documentation says use P rather than S.
        Also to make things work in parallel if you have a lot of commands I have found sometimes M606 S1 is needed.
        pouryatorabiundefined 1 Reply Last reply Reply Quote 0
          pouryatorabi @dwuk3d
          @dwuk3d Thanks for the reply. You’re right, it should be 'P', that was a typo, and I’ve corrected it. I’ve tried using 'M606 S1' before, but everything stops when it reaches that command. Also, as far as I know, I have to run it as a job, I can’t call it from a macro.
          • dwuk3dundefined
            @pouryatorabi thought so - do you still get the problem?
            Macro's work ok for me in multiple motion systems - especially when you run them as job,
            What is in the macro?
            I found that without the M606 it will only run a few commands in parallel.
            I usually do T0 or T1 after most of my M596's
              dc42 administrators @dwuk3d
              @dwuk3d when you are running a job, you should be able to run many commands in parallel. When not running as a job, the number you can run in parallel is limited by the lengths of the motion queues. Motion system 2 has a very short queue after reset, so if you want to use the second motion system then you should increase it using the M595 command.
              @pouryatorabi did you increase the length of motion system 1 queue using M595?
