Fixed IP??? How???
i d'like Duet Wifi, ever has the same IP…. if when reading the wiki, I have not misunderstood, if i put this in [c]config.g[/c]….
[[language]] ; Network M550 PTLM Duet Wifi ; Set machine name M552 S1 ; Enable network M587 S"Dlink-869L.2,4" P"a1b2c3d4" I192.168.1.99 ; Configure access point and IP addresses. You can delete this line once connected M586 P0 S1 ; Enable HTTP M586 P1 S1 ; Enable FTP M586 P2 S1 ; Enable Telnet
its supposed that DWI, must be in [c]192.168.1.99[/c], outside the IP reservation for DHCP…. No?
but, with this [c]config.g[/c], in this moments is in [c]192.168.1.104[/c], in DHCP zone…
I have to see, my network hardware, not is standart, i have:
INTERNET –--> Modem Router Internet Provider (Asigns IP to LAN) --> [LAN Connexion] –> Router serves WIFI -->[WIFI] –> Duet Wifi
I simply created a DHCP reservation in my router configuration for the Duet. Can you do the same?
mmmm… think i have see anithing....
thanks for the tip
You only need to add the network using M587 once, it does not need to be in your config.g
You can send M587 from the console to confirm that your network is added correctly ( I think it is as you are getting a DHCP address). Check the network is not in their twice once without an IP address, also probably worth having a netmask in there as well.
On reset the Duet should use the configured IP.
