    Kossel XL
    • Captain_sq
      Captain_sq last edited by
      Hi Guys,
      I'm looking to build a Kossel XL. Either from a good quality kit or from a BOM list. Last years fall, I bought myself a half finished, customized Kossel mini from a guy on a 3D site in Sweden and completed the build to find an absolutely mind-blowing performance compared to my cartesian budget printers. Now I want to build bigger parts going delta style.
      Can you recommend a kit or a well tested custom build with reasonably good building instructions?
      I have four previously builds behind me so I'm not a total rookie. I will use Duet a board/w Paneldue wich I already have in stock. I also have most of the hardware required such as hammerhead nuts, assorted 2020, 2040, 2080 profiles, NEMA 17 motors and E3D V6 hotend + fans etc. I will be needing a heated bed for this build. I also have a Diff IR probe from Escher but leans towards a precision piezo probe instead. Apart from this the budget is about 500 €.
      TIA
      /Thom
      • DjDemonD
        DjDemonD last edited by
        I think its quite doable. I really like the TevoLM frame, although I am not sure they are easy to just buy.
        I don't know if you can do it for $500, but good luck. My full build log is here: http://forums.reprap.org/read.php?178,702599,page=1
          500 Euro for everything isn't enough for a good Kossel XL. You might want to look at my build details at https://miscsolutions.wordpress.com/dc42s-large-kossel-build/ which includes a link to a costed bill of materials.
          • Captain_sq
            Ok, interesting. Remember that I already have a lot of stuff on my shelves. In short, I will need material partly for the frame and towers, corner joints, PSU, buildplate+heater, rails, carriages, belts, rods and effector.
            I was think about putting my money where precision really matters, moving parts such as effector, rails + carriages, rods /w magnetic ball joints, pulleys and idlers. The rest I have in stock and some parts can probably be salvaged from old decomissioned printers or manufacture myself. I will study both solutions closer the coming days.
            • SM3D
              SM3D last edited by
              Hi Captain Sq,
              I have a large delta, with reasonably stout mechanics and it is working well for the past 6 months. Here is my semi build log:
              https://3d-generative.com/
              By the way, Tjena! Jag också från Göteborg. You can PM me if you want more details. Will be happy to share the details.
              Best Regards,
              Vasan
              • Captain_sq
                @SM3D:
                Hi Captain Sq,
                Best Regards,
                Vasan
                Tjena, kul att se andra Göteborgare här!
                I've been studying your design and like the triangular 120° tower profiles you found on the German site. However, I have a lot of standard 2020, 2040 and 2080 profiles that I want to use (preferably). The rest can probably be made by myself or bought from Robotdigg and the German sites.
                I guess I'll be starting the design work in Fusion any day now once I chosen the parts to use. I have an idea on a direct extruder á lá Nimble but with different drive mechanism that I want to try out in a real prototype. Simulating in fusion seems to work well but reality is a completely different thing.
                Thanks for all tips!
                /Thom
