    New firmware 1.21RC3 available
    Firmware installation
    31
    159
    23.9k
    • lolorcundefined
      lolorc
      @lolorc:
      ttyACM3 16°> M115
      SENDING:M115
      FRMWR_NAME: epapirwae orDut WiF ad ue Ethene FRMAR_VERSON 121C2ELRNIS:Dut ii .0or101FIMWRE_AT: 01-0-1 bil 2
      o T170 0. B16.7 /00
      this was an serial issue I was not able to reproduce hopefully.
      However I can't manage to upgrade to 1.21rc3, Duet2CombinedFirmware.bin been renamed to DuetWiFiFirmware.bin, uploaded through webui, copied to sdcard (+M997) M115 still reports 1.21rc2.
      • SputnikOC3dundefined
        SputnikOC3d
        @kraegar:
        @SputnikOC3d:
        @kraegar:
        The bltouch / multi-tap fix works great.
        Probe configuration:
        M558 P9 X0 Y0 Z1 H5 F50 T6000 A5 S0.02
        3 point leveling result:
        Leadscrew adjustments made: 0.004 -0.008 -0.000, points used 3, deviation before 0.005
        is there a link to guide or tute or dozuki page outlining the implementation of this newly supported feature? My BL Touch bed leveling has been giving me fits and I think its due to inconsistent probing results - this would be rather nice
        If you're referring to the multi-tap, the relevent bits there are the S0.02 (max deviation between two sequential taps) and A5 (allow up to 5 attempts). I never see it tap more than twice, though.
        The new probe type, P9, is to specify it's a BLTouch specifically, and so you no longer need to manually deploy the probe, it does it automatically.
        Thanks very much for this … appreciated - but there must be some documentation for this somewhere right? How did you learn of these settings / features?
        I will try and implement. Im also desperateyl trying to find some data on the sensititivty setting for the BL Touch - docs just said to use a low setting - it was default at 500 - I modded that to 25 - wondering if that is impacting my results ... I cant find jack in docs on that issue
        • okerchoundefined
          okercho
          @SputnikOC3d:
          You can check in the Gcode documentation 🙂
          https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
          Regards
          Okercho
          Custom Prusa i3 Hephestos with Duet Wi-Fi
          E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
          Rebuilding Hypercube Evolution
          • T3P3Tonyundefined
            T3P3Tony administrators
            Also see:
            https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_BLTouch
            I have linked a helpful tutorial for BL Touch by BeTrue3d.dk
            www.duet3d.com
              SputnikOC3d
              @T3P3Tony:
              Also see:
              Thank you …
              Now i get ... Error: M997: Firmware binary "DuetWiFiFirmware.bin" is not valid for this electronics ????
                SputnikOC3d
                no blue light on wifi module … wth ... So doing some reading it stated on some docs that sometimes you need to make sure your wifiserver .bin and your firmware .bin are upload before executing the firmware update .... because Im getting M997 error - as stated above ... After upload of the new 1.21RC3 wifi server bin ... it asked if I wanted to upgrade or whatev's it calls it I hit YES.
                It went thru some activity - showed me a green progress bar ... then now i get nothing no connection via wifi - no blue lights next to the wifi module on the board ... So now I have 1.20 firmware still and 1.21rc3 wifi server and no wifi connectivity - now what ?
                release notes said it didnt matter if wifi bin or firmware bin done first ...
                • T3P3Tonyundefined
                  The blue light on the wifi module comes on only when uploading the wifi server firmware.
                  It looks like that is successful as you say the wifi server firmware version is 1.21rc3? Sounds like an issue with the main firmware upload. Try downloading the DuetCombinedFirmware.bin again (make sure you download the raw .bin file) then rename it to DuetWifiFirmware.bin then upgrade. You will need to comply it onto the SD card by putting it into your PC.
                  www.duet3d.com
                    SputnikOC3d
                    @T3P3Tony:
                    TY … yes I agree. I did make sure and actually downloaded the main fw file again and renamed it as per instructions - before moving over the wifi server .bin file via the gui. But I will do as indicated - i have to go get a micro sd card adapter/reader for this pc - never use them in real life ... but now do.
                    Will report back ... Im following
                    https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware#Section_How_to_recover_if_the_main_firmware_and_WiFi_firmware_versions_get_out_of_step_on_your_Duet_WiFi
                    please advise if there is a better guide to follow for my situation than the one linked to above.
                    TY again …
                    • T3P3Tonyundefined
                      That guide is the right one for this situation
                      www.duet3d.com
                        SputnikOC3d
                        Any ideas why I got the M997 error at the onset ? Did i need to be running a more recent firmware version than 1.20 ?
                          @SputnikOC3d:
                          @T3P3Tony:
                          Also see:
                          Thank you …
                          That normally means you downloaded the html page describing the firmware file, instead of the firmware file.
                            SputnikOC3d
                            @dc42:
                            @SputnikOC3d:
                            @T3P3Tony:
                            Also see:
                            Thank you …
                            well valuable lesson learned there … compare bytes and drill down into the github into the page where the actual files reside ... so ive followed the guide- run out and got a micro sd card reader - and moved the files and commented out the line in config .g ...
                            Issuing M997 S0 and M997 S1 ...
                            M115 gives me ...
                            FIRMWARE_NAME: RepRapFirmware for Duet 2 WiFi/Ethernet FIRMWARE_VERSION: 1.21RC3 ELECTRONICS: Duet WiFi 1.02 or later FIRMWARE_DATE: 2018-02-28 build 4<lf>ok <lf>Im really not clear by looking at this whether the Wifi Server firmware part is the right version?
                            M122 gives me :
                            <lf>Used output buffers: 1 of 32 (9 max)
                            <lf>=== Platform ===
                            <lf>RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21RC3 running on Duet WiFi 1.02 or later
                            <lf>Board ID: 08DGM-9568A-F23SD-6JTDD-3SJ6R-9ARZH
                            <lf>Static ram used: 16144<lf>Dynamic ram used: 100384
                            <lf>Recycled dynamic ram: 2256<lf>Stack ram used: 3568 current, 4528 maximum<
                            LF>Never used ram: 7760<lf>Last reset 00:14:41 ago, cause: power up
                            <lf>Last software reset at 2018-02-24 09:30, reason: User, spinning module GCodes, available RAM 11896 bytes (slot 3)
                            <lf>Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                            <lf>Error status: 0<lf>Free file entries: 10<lf>SD card 0 detected, interface speed: 20.0MBytes/sec<lf>SD card longest block write time: 0.0ms<lf>MCU temperature: min 37.6, current 37.8, max 38.1<lf>Supply voltage: min 0.5, current 0.6, max 0.6, under voltage events: 0, over voltage events: 0<lf>Driver 0: ok, SG min/max not available<lf>Driver 1: ok, SG min/max not available<lf>Driver 2: ok, SG min/max not avai<warning: maximal="" number="" of="" bytes="" per="" line="" exceeded!="" check="" the="" end-of-line="" settings="" or="" increase="" limit="" in="" advanced="" terminal="" settings.=""></warning:></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf></lf>
                              SputnikOC3d
                              M552 S0
                              M587 S"SSID" P"PWD"
                              M552 S1
                              Viola …
                              new firmware and wifi server and new DWC all synced up ... sorry for the trouble guys - im back and with just a bit more gcode and duet firmware savvy - 1 Bite at a time ...
                              • nytundefined
                                nyt
                                So any way to do G30 homing with doubletap?
                                • T3P3Tonyundefined
                                  @SputnikOC3d:
                                  M552 S0
                                  M587 S"SSID" P"PWD"
                                  M552 S1
                                  Viola …
                                  Glad you are up and running!
                                  www.duet3d.com
                                  • robmundefined
                                    robm
                                    Thanks for the work on the rotating magnet filament monitor. I can confirm that the output looks better.
                                    Please will you review briefly how the configuration is supposed to work? Perhaps post in the filament monitor section…
                                    It seems like it auto-calibrates now the mm extruded per revolution of the magnet? In the previous version this was specified in the S parameter, but now its not clear to me as the documentation says '1 to enable' and later gives an example of 'S1.05 R30' meaning 'sensitivity 1.05, +/-30% error detection tolerance'. Also there's still the query about the Raa:bb form of the R parameter. My initial results (just running out the door so not much time to test!) are:
                                    [[language]]
                                    2:01:00 PM
                                    M591 D0
                                    Duet3D rotating magnet filament monitor on endstop input 3, disabled, sensitivity 26.68mm/rev, allowed movement 0% to 10%, check every 3.0mm, current position 284.4, measured sensitivity 24.92mm/rev, measured minimum 85%, maximum 132% over 273.1mm
                                    [[language]]
                                    2:14:14 PM
                                    M591 D0
                                    Duet3D rotating magnet filament monitor on endstop input 3, disabled, sensitivity 26.68mm/rev, allowed movement 0% to 10%, check every 3.0mm, current position 22.5, measured sensitivity 25.06mm/rev, measured minimum 85%, maximum 131% over 272.6mm
                                    my sensor hob groove diameter measured 7.75mm so calculated circumference at the bottom of groove is 24.3mm
                                    Thanks!
                                    Rob.
                                      I have corrected the example given for firmware 1.21 and later.
                                      • kraegarundefined
                                        kraegar
                                        The new "no moving Z before homing" is kind of a pain. I put the S2 in my config files, but the paneldue can't jog down in Z, which I occasionally would do without homing for testing, giving some clearance, whatever. Not the end of the world, I can make a macro to work around it. Just some general feedback.
                                        Co-Creator of the RailcoreII CoreXY printer
                                        https://www.thingiverse.com/thing:2407174
                                        • joestefanoundefined
                                          joestefano
                                          David, I'm running RC2 on my Ethernet board. I downloaded RC3, renamed it according to the notes and when I upload it all it does is install in the config folder. The error message is M997 S0 cant find WifiFirmware. Not sure what to do with that. It installed and updated fine on my WiFi Boards
                                            Did you rename it to exactly DuetWiFiFirmware.bin? Use the System Editor page of DWC to check that it is there.
