    Message From Duet Firmware - OMG - How do I make it stop !
    • SputnikOC3dundefined
      SputnikOC3d
      Crazy ….
      Getting a layer by layer message from Duet as i created a Cura Z Tweek for temp tower and temp changes at 100 Layer increments - but Duet is alerting me about every layer ...
      How do i make this stop and for future reference
      • darookeeundefined
        darookee
        Check the gcode file if it contains 'M117' commands like 'M117 Printing… tw@L 120'. If it does you should check your slicer settings (layer change script for example) if there is something that will make the slicer add these.
