    M558 - questions in regards to A parameter
    1891
    • garyd9
      garyd9 last edited by
      The M558 gcode command is documented (for the duet board) here:
      https://duet3d.dozuki.com/Wiki/Gcode#Section_M558_Set_Z_probe_type
      The "A" parameter offers a multi-probe functionality, with it defaulting to "1" (single tap.) If A is >1, it's the "maximum number of times to probe…" Being a maximum, it implies that less than A probes might occur. However, nothing explains that. Does it always probe the max times? Under what circumstances would it probe less than the max times?
      The "S" parameter is documented as "tolerance when probing multiple times." However, there's no default value shown. What is the default tolerance? (It appears it's 0.03 based on the source. I've submitted an edit to the wiki to show that.)
      How do the A and S parameters influence each other?
      From the latest RC builts, I think that a probe will occur UP TO "A" times unless 'x' probes are within a specific tolerance of each other. I'm not sure what 'x' is. (2? 2 consecutive?) In builds prior to RC2, if 'x' probes weren't within the specific tolerance, the probe would be reported as a failure, but in RC2, it was changed so that the probe would just return an average? If this "average" fallback is used, is anything reported to the console log?
      Thanks
      Gary
      "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
      • mortn
        mortn last edited by
        Thank YOU! I have just been wondering about the same thing for an hour! It would be great if someone can tell a bit more about the exact behaviour of M558 in conjunction with parameters A and S.
          dc42 administrators @mortn last edited by
          I have expanded the description of M558 on the GCodes wiki page. Let me know if it isn't clear.
          Nxt-1 1 Reply Last reply Reply Quote 0
          • Dougal1957
            Dougal1957 last edited by
            David
            The A Param is still not clear when it says maximum number of probes at what point does the Firmware stop probing early I assume it is once a certain number of probes are within the tolerance range but a bit more clarity may be in order here?
              dc42 administrators @Dougal1957 last edited by
              @dougal1957, see the new paragraph that I added at the end.
              • Nxt-1
                Nxt-1 @dc42 last edited by
                @dc42 said in M558 - questions in regards to A parameter:
                This explanation helped me as well, thanks 🙂
                Duet3D and delta printer enthousiast. Buildlog
                Looking for Duet3D configuration support, check out Nxt-3D
                  Phaedrux Moderator @dc42 last edited by
                  @dc42 Will P10 probe type for stall detection be added to the documentation? Or is it a little too experimental for broad distribution?
                    dc42 administrators @Phaedrux last edited by
                    @phaedrux said in M558 - questions in regards to A parameter:
                    Good point, I will add it.
                    • T3P3Tony
                      T3P3Tony administrators @dc42 last edited by
                      @dc42 I have added it here too:
                      https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Mode_Num_10
                      www.duet3d.com
                        Phaedrux Moderator @T3P3Tony last edited by
                        @t3p3tony would it be a good idea to link to the forum thread discussing implementation of z stall probing?
                        • T3P3Tony
                          T3P3Tony administrators @Phaedrux last edited by
                          @phaedrux yes - which one is it?
                          www.duet3d.com
                            @t3p3tony I'd say this one
                            https://forum.duet3d.com/topic/4772/motor-stall-detection-as-z-probe
                            • T3P3Tony
                              @phaedrux thanks, done.
                              www.duet3d.com
