    40mm cooling fan duct for Smart Effector - thoughts?
    11
    39
    6.8k
    • RGN01undefined
      RGN01
      Update:
      I have now finalised the design for the duct and it works well on both my Smart Effectors using 40 x 10mm Noctua fans.
      I decided to go with the BerdAir type approach as the Smart Effector became too cluttered with the layer fans on it. I'm still working on the piping and mounts for these.
      See the 40mm fan duct here https://www.thingiverse.com/thing:2844881
      Richard
      • Mystaundefined
        Mysta
        @RGN01:
        Update:
        Richard
        I commented on the thingiverse post as well but wanted to mention here I printed the berd adapter and the 40*20 fan duct, everything went well(though leveling them was a pain) used supports. The cylinder around the heatsink was a little brittle - slightly broke it when I was removing supports but could be my PETG print settings.
        Here was my orientation(tested the other adapter too) https://i.imgur.com/mXVaazo.png
        • RGN01undefined
          RGN01
          Thanks for reporting back. Try printing with the feet on the bed - mine prints perfectly like that with support only on the bed.
          I've also uploaded a STL file for the combination of the duct and BerdAir tube mount.
          Richard
          • RGN01undefined
            RGN01
            I've uploaded an improved version for the BerdAir type cooling. It only needs support on the bed - I've included sacrificial support for the rest of it.
            Mine prints perfectly in PETG with only minimal support plastic to remove.
            Richard
            Hergonowayundefined 1 Reply Last reply Reply Quote 0
            • benkayundefined
              benkay
              Looks great. With the new easy-print version for berd-air….is this file universal for standard v6 and volcano?
              Tevo Little monster with Duet Wifi and Smart Effector / magball arms upgrades.
              Original Prusa i3 Mk3
              • benkayundefined
                benkay
                • RGN01undefined
                  RGN01
                  Yes, I use the same for both.
                  Richard
                  • Hergonowayundefined
                    Hergonoway @RGN01
                    @rgn01
                    Hi love your design, could you share the stp/step files ? at least for the "Duct_-_no_accessories_v1.00" part ?
                    I'm struggling right now in Fusion 360 with the stl, there more than 45k meshes
                    Delta goes BrrrRRRRrrrrrRRRRrrr
                    RGN01undefined 1 Reply Last reply Reply Quote 0
                    • RGN01undefined
                      RGN01 @Hergonoway
                      @hergonoway Unfortunately the CAD package I use does not support STP files so I can't do that.
                      Richard
                      • BenDieselundefined
                        BenDiesel
                        That fan I a cool idea. I used this one for a 40mm noctua on mine
                          Hergonoway @RGN01
                          @rgn01 I was sad at first because working with this amount of mesh kill my Fusion360... and working from mesh is really not my cup of tea... but your idea of using a 40mm fan made its way into my mind 🙂 I've ended up designing my version from scratch in order to handle 3mm holes for fan with hexa nut lock and working as a shield with berdair support (for original tube size but also 1/8" tube size), so thank you !!
                          Chipsa82undefined RGN01undefined 2 Replies Last reply Reply Quote 0
                          • Chipsa82undefined
                            Chipsa82 @Hergonoway
                            @hergonoway that is pretty much the ultimate mount for the effector ;)) would you mind sharing the model? thanks!
                            • Chipsa82undefined
                              Chipsa82 @RGN01
                              @rgn01 Cool! is that a 40/20 blower fan?
                              • RGN01undefined
                                RGN01 @Hergonoway
                                @hergonoway that looks very good. Sorry I couldn't help directly and save you the trouble of redesigning it!
                                • RGN01undefined
                                  RGN01 @Chipsa82
                                  @chipsa82 on the early photos with a blower, yes. The Noctua on the later version is a 40 x 10. I have shared my version on Thingiverse https://www.thingiverse.com/thing:2844881
                                    Hergonoway @Chipsa82
                                    @chipsa82 I'll post it on thingiverse in few days, need to rework some clearance for that damn screw under the fan duct 🙂
                                    First prototype print works like a charm
                                      Hergonoway @RGN01
                                      @rgn01 did you encountered some issue with a noctua? In terms of CFM I mean.
                                      I was a bit concerned to the amount of air during first prints. Didn't try ABS or more exotic high temp materials.
                                      I swapped recently to adda fan (because 24v) (réf AD0424HB-G7, but ad0424hs-g70 works almost the same) works really well if you managed to find one under 10$.
                                      • RGN01undefined
                                        RGN01 @Hergonoway
                                        @hergonoway No, I've used the same 40x10 Noctua on my other printer with a e3d Chimera printing two colour with ABS and it works just fine.
                                        • Mystaundefined
                                          Mysta
                                          @Hergonoway I wasn't able to find your file on thingiverse, mind linking it?
