    Cold extrusion override
    • 3DPMicro
      3DPMicro last edited by
      I would like to run the extruder motor without a heater hooked up (I do have a thermistor plugged in) through DWC "extruder control", through the command line and ultimately a "dry run" g-code program but I get an error "heater temp not high enough or heater fault". How do I override this failsafe? thanks
      • tjb1
        tjb1 last edited by
        Use M302 - https://duet3d.dozuki.com/Wiki/Gcode#Section_M302_Allow_cold_extrudes
        • 3DPMicro
          thank you
