    BLTouch working
    266
    80.2k
    • Hey_Allenundefined
      Hey_Allen
      @Sniffle:
      according to the bltouch people, to work with 3.3v logic electronics you only need a 240ohm resistor in line with the 2-wire endstop. that could be where your not getting a response.
      I am feeling a little slow here, but is this in series with one of the wires, or bridging the IN and GND wires at the PROBE connector on a DuetWifi?
      I finally got the +5VDC, COM, and H3 connections correct, and the probe deploying/retracting, but am not getting any input from the probe, and am really starting to doubt my wiring of the sensor portion.
      Currently I have a 240 Ohm resistor across the two wires, crimped into Dupont pins with the wires from the hall sensor output, but it shows up as 0 on the Z-Probe on the web control screen when tested with the auto-test macro that was posted in this thread, nor if pressed directly. If it is unplugged, I see a value of 1000 on the Z-probe, and the field is shaded red.
      • Syko_Symaticundefined
        Syko_Symatic
        @Hey_Allen:
        @Sniffle:
        Spot on, you need to bridge the In and GND on the Z probe pins with the resistor.
        • Sniffleundefined
          Sniffle
          @Hey_Allen:
          @Sniffle:
          ok, due to the refresh rate of the website, it doesnt always capture the tiny pulse of the pin being triggered. that doesnt mean that the trigger isnt happening. If you put the bltouch(genuine, clones unknown) in an error state(blinking), an M119 should show the endstop triggered. Once you verify that use:
          M280 P3 S10 I1
          ```and manually trigger the pin over and over until you see it display in the web control. It wont display all the time but it will occasionally. It may not show a trigger(color change) on the web control, but you may get a value change on the signal value displayed. you need to put your tigger value below that number(or just use 25)
            Hey_Allen
            Thank you for the confirmation on the wiring of the 240 Ohm resistor, and the instructions for testing it prior to trying to use it in automatic tests.
            I finally figured out that I had the probe wires reversed on the PROBE header, and once that was corrected was able to get it working.
            I'm not sure that I have everything working as it is best possible to do, but it has probed a grid on the bed, using G29, and can view the heightmap.csv file, but not the graph of it (loading screen, for >10 minutes in Chrome).
            edit: I eventually found that FireFox would load the graphic, no idea why Chrome won't on my machine. It also showed that my mechanical level was off again.
            • Etznabundefined
              Etznab
              Good evening. I am very new to 3D printing and even newer to the Duet WIFI. I have the BLTouch connected and deploying and retracting. My problem is that I don't fully understand where and what to put into the System Directory XXX.g files and Macro files. Could someone please break this down barney style for me? Thanks in advance.
                Syko_Symatic
                @Etznab:
                You should put all config and home files in the system editor tab. Macros such as mesh level or anything that you might want to call during or before a print that are not going to be called in the config can go in the macro part. Any print files can be placed in the gcode files tab.
                I have an issue with the mesh level code.
                I have defined the BLTouch position: G31 X-25 Y58 Z0.73 P1
                I have defined my mesh size: M557 X15:300 Y15:160 S30
                My issue is I am not sure just what I am defining in the M557 command is it the probe position/head position? It works but I am curious as I want to cover as much bed as possible and am currently a little conservative with the positions. I also assume the firmware accounts for the probe offset when creating/using the height map?
                Thanks
                  @Etznab, for where the files go, see https://duet3d.com/wiki/SD_card_folder_structure.
                  @Sylo_Symatic, the coordinates you put in M557 are the points you want to probe, so they are probe position not head position. The firmware will subtract the probe offset from them when positioning the head, and will leave out any points that would place the head outside the limits set by M208.
                  • redcurseundefined
                    redcurse
                    Hi Everyone,
                    I've been attempting to get my bltouch working on my duet wifi for a couple days now. I've gotten to the point where if I deploy the pin and manually push it up I can see in the web interface that its being triggered. I usually see something like 68 or 180 and the colour of the field is red. This will happen maybe once or twice every 30 or so times I push the pin.
                    My issue is that it doesn't trigger when running auto calibration, the head just crashes into the bed every time. I'm new to reprapfirmware, coming from marlin, so I'm not sure if there is some configuration that I might be missing. I've tried following this thread as best as I can but nothing seems to be solving this issue.
                    Any help is appreciated. Thanks!
                    • InSanityundefined
                      InSanity
                      Sounds like you have the same problem I did. Make sure your config-override.g file doesn't have G31 .. P500 … It should have P25 or lower. I use P1. P500 will crash it into the bed and behave as you describe. If you don't have a config-override.g file make sure your config file has the G31 P1 (or P25).
                      What is happening is the pulse from the BLTouch isn't being seen most of the time because of P500
                      Jeff
                      Duet WiFi Powered FFCP with E3D legends hotend system. BLTouch grid leveling.
                      • redcurseundefined
                        redcurse
                        Thanks for the response!
                        This is something I actually looked into. Originally I didn't have a config-override.g file so I used M500 to create it and noticed that there were some extra G31 commands in there so I commented them out and copied the G31 line in my config.g file into the config-override.g. Unfortunately this didn't solve my problem.
                        I'll double check this though when I get home from work.
                        • InSanityundefined
                          InSanity
                          Not sure which endstop you connected to , Try G31 T1 or G31 T3 at the console and see what it spits out. Should have P25 or P1 (whichever you used). T1 would be the normal z-probe and T3 should be the E1 endstop I believe. Might be off the that one. In any event this will help you verify your settings are making it end to end. If you still seeing P500 then issue G31 T1 (or T3) P25 and then do M500.
                          Also make sure you are loading the config.override in the config.g toward the very bottom of the file.
                          M501 ; Load saved values
                          • redcurseundefined
                            redcurse
                            So it turns out what I thought was the first probe of the bed was actually just the head positioning itself to begin the auto leveling process. I had my height set a little too high and that was causing the crash. I fixed that issue and its working!
                            Thanks again (In)Sanity. I was at least able to confirm a couple things were set up correctly with your help. I was able to focus on other things because of it to solve the issue. 🙂
                            • FrankNPrinterundefined
                              FrankNPrinter
                              Can someone please clarify the pin out below?duet wifi bl touch
                              BLTouch endstop leads are paralleled with a 240ohm resistor as documented by Antclabs to make it safe for 3.3v logic and connected to E0 endstop header
                              E0 end stop header? which pins? 3.3 v and (bltouch Orange?)
                              E0 end stop (groud to E0 ground black, white to E0 Stop?)
                              so close yet so confused lol
                                I suggest you use the GND and IN pins on the Z probe connector, not the E0 endstop.
                                  FrankNPrinter
                                  Thank you very much! Been scratching my head on this so long, i starting getting things mixed up. It took me forever to figure out I was looking at a different model board. the difference between the duet and duet wifi pin out was killing me LOL For those that follow, BL Touch pins 1=brown to Duetwifi expansion pin 2, Pin 2= red +5 v to Duetwifi expansion pin 1, Pin 3 Orange control to expansion pin 8 AKA Heater 3, pin 4 = Black to ground z probe 5=white to Z Probe IN. and don't forget the 240 ohm resistor between the z probe min and ground.
                                    FrankNPrinter
                                    This is what i have so far. I think the pin assignments may be off right? Since this is the duet wifi expansion pin 8 is heater 3 and pins 1 and 2 are +5 vdc and ground. is it pin# or sam pin that i am looking for z probe pin? Also, the config files for retract and deploy, do they go in the config folder or macro folder?
                                    ; BLTouch
                                    M307 H3 A-1 C-1 D-1
                                    M558 P4 X0 Y0 Z1 H3 F200 T5000
                                    G31 P200 X-4 Y40 Z2
                                    ##BLTouch Servo Settings thermistor ADC correction
                                    switch.servo.enable true
                                    switch.servo.input_on_command M280 S3.0 # M280 S7.5 Would be midway
                                    switch.servo.input_off_command M280 S7.0 # Same as M280 S0 0% duty cycle, effectivley off
                                    switch.servo.output_pin 1.23 # Must be a PWM capable pin
                                    switch.servo.output_type hwpwm # H/W PWM output settable
                                    switch.servo.pwm_period_ms 20 # Set Period to 20ms (50Hz) - Default is 50Hz
                                    ;gamma_min_endstop nc # normally 1.28. Change to nc to prevent conflict, not needed on Azteeg X5
                                    ;zprobe.enable true # set to true to enable a zprobe
                                    ;zprobe.probe_pin 1.28!^ # pin probe is attached to if NC remove the !, Azteeg X5 this is 1.29
                                    ;zprobe.slow_feedrate 5 # mm/sec probe feed rate
                                    ;#zprobe.debounce_ms 1 # set if noisy
                                    ;zprobe.fast_feedrate 100 # move feedrate
                                    ;zprobe.probe_height 5 # how much above bed to start probe NB only needed for G32 on delta
                                    ;zprobe.return_feedrate 0 # feedrate after a probe, default 0 is double of slow_feedrate (mm/s)
                                      The Z probe input pin is the one marked IN on the 4-pin Z-probe connector. You need to use P5 in the M558 command, not P4.
                                        FrankNPrinter
                                        thanks again, I cant read that pin out diagram to save my life!
                                        • claustroundefined
                                          claustro
                                          Are this connections right?
                                          Can someone make a step by step description of the firmware modifications required?
                                          • dintidundefined
                                            dintid
                                            Anyone know how to hook up BLTouch when using Duet WiFi + Duex5? meaning I do not have access to the expansion board pins?
                                            I have read this and guess I should use mode 4 or 5? Aside from that, it links back to this post, which doesn't answer my questions (I have read all, but might obviously have missed something - sometimes unclear wheter we talk about WiFi or not)
                                            https://duet3d.com/wiki/Connecting_a_Z_probe
                                            and
                                            https://duet3d.com/wiki/Setting_up_automatic_probing_of_the_print_bed which links to above page and talk about setting up in firmware, but I need to hook it up before I get here 🙂
                                            RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
