    Refitting Wired Duet with Allegro A5984 drivers?
    1.8k
    • W3DRKundefined
      W3DRK
      Has anyone considered refitting a Duet 0.8.5 or 0.6 with the new A5984 stepper drivers? They're pretty much pin-compatible and offer 1/32 micro-stepping along with a new "Adaptive Percent Fast Decay" that supposedly quiets the motors down. I found a video of someone testing them on a Delta and the motors seem to be extremely quiet…
      I'm seriously considering ordering a set to retrofit one of my "wired" Duets...
      EDIT: I just found a thread on Google groups regarding this exact question and it does indeed look to be possible with some minor board rework. I just ordered a set and will be sure to update when I get a chance to try it.
      https://www.youtube.com/watch?v=UHzWhp8dHSg
      • T3P3Tonyundefined
        T3P3Tony administrators
        Saw your reply on the thread:
        https://groups.google.com/forum/m/#!topic/deltabot/qLXtEWB9v4Y
        Very interested to see how you get on.
        www.duet3d.com
        • W3DRKundefined
          W3DRK
          From the looks of it, since MS3 has an internal pull-down resistor I think the only modification I'll need to do is remove the VDD decoupling caps and cut the traces connecting VDD to +3.3v. I suppose another option would be to simply lift that leg and insulate it from the pad with a tiny piece of kapton…
          In any event, I'll be sure to let you know how it works out.
          • W3DRKundefined
            W3DRK
            Success!
            https://youtu.be/s29fZLVaI8Y
            • bonduraundefined
              bondura
              How did you go about replacing the drivers? I made a mistake and burned two of mine out… Looking to get them replaced.
