    Panel due suspended mode?
    PanelDue
    1.2k
    • peirofundefined
      peirof
      there is some form of config Panel Due that after a while, the screen goes off? I can not find that configuration, if it exits … If it does not exist through the menus ... can the screen be turned off after a while by console, with a gcode...?
      In long prints, 12 hours or more, I do not know that the screen is always on, only the times I check the print status ..., most of the time, I'm not in front of the printer ....
      Thank you
      • garyd9undefined
        garyd9
        Use the newest paneldue version (1.20). It will dim the display after 60 seconds of not being touched. It can be configured on the setup page to always dim like that, never dim, or only dim when the printer is "idle."
        "I'm not saying that you are wrong - I'm just trying to fit it into my real world simulated experience."
        • peirofundefined
          peirof
          Thanks
          • peirofundefined
            peirof
            hi,
            Where can find info for update Panel Due Firmware?
            I have downloaded de last file from Github
            https://github.com/dc42/PanelDueFirmware/releases/tag/1.20
            and them dowload the version for my PanelDue and LCD–-
            https://github.com/dc42/PanelDueFirmware/releases/download/1.20/PanelDue-v3-5.0.bin
            after, by DWI, i have uploaded firmware….but the version that show LCD, its the same 1.17....
            Can someone explain what its the process for update firmware? or pass a link where explain it, please
            Thanks
            • mloidlundefined
              mloidl
              Firmware update is described here: https://miscsolutions.wordpress.com/paneldue/
              Br,
              Martin
              • peirofundefined
                peirof
                thanks
                • peirofundefined
                  peirof
                  next… dude or problem....
                  i have follow the instructions on webpage.... and the process seems correct.... but when i press restart button on Panel Due, can see in the screen a calibration, that say me "Touch the spot"... and i have try to touch the spot with finger and stilus (from tablet), and nothing.... the screen dont detect the touch... watever i push, with finger or styus....
                  i have try reset the screen..... but nothig.
                  Ideas?
                  • peirofundefined
                    peirof
                    forget it….
                    i have unplug panel due from Duet, and works
                    • kuhnikuehnastundefined
                      kuhnikuehnast
                      Dimming is nice, but would it also be possible to integrate a "total off"- mode after for example 30 Minutes? Thinking about a print that lasts for a couple of hours, the display doesn't has to stay on all time?
                      • timcurtis67undefined
                        timcurtis67
                        A simple switch to cut the 5 volt power to the board can be used to turn it on and off.
                        • garyd9undefined
                          garyd9
                          @kuhnikuehnast:
                          If your normal "brightness" is low enough, the dimmed value will actually have the backlight as close of "off" as is possible while still powering it. I don't think it would be feasible to completely turn off the LCD without also powering down the entire PanelDue. (..and if only the LCD power was cut, I think it would also cut power to the electronics providing touch sensitivity, so you'd have no way to turn the LCD back on without rebooting the paneldue.)
