    It's out! Firmware 1.21 released
    Firmware installation
    25
    73
    13.2k
      Get it from https://github.com/dc42/RepRapFirmware/releases/tag/1.21 and be sure to read the upgrade notes at https://github.com/dc42/RepRapFirmware/blob/dev/WHATS_NEW.md. If you want the full list of changes since release 1.20, for now you will have to read all of the 1.21RC release notes too, but in a few days I'll delete the 1.21RC releases and consolidate the change lists.
      • pabomanundefined
        paboman
        last touch ups to the pulse filament detector are also included ?
        • JohnOCFIIundefined
          JohnOCFII
          @paboman:
          Looks like it:
          New features and changed behaviour since 1.21RC5:
          The rr_status and M408 reports now include the spindle speed
          M106 now also reports the current fan PWM for thermostatically-controlled fans
          Machine coordinates are always used when running system macros automatically.
          Bug fixes since 1.21RC5:
          Pulse-type filament monitors are now working
          WiFi sockets whose connections abort are now terminated to make them available for re-use
          DWC Machine Properties page shows the correct state of active low endstops
          • pabomanundefined
            paboman
            great! thank you
            • pabomanundefined
              paboman
              great! thank you
                Not sure if this is intended or not, but when trying to simulate a file I get various error messages if the axes are not homed first.
                [c]2:02:49 PMM37 P"z-motors_fixed.gcode"
                Simulating print of file z-motors_fixed.gcode
                Cancelled simulating file z-motors_fixed.gcode after 0h 0m simulated time
                Error: G0/G1: insufficient axes homed
                2:02:16 PMWarning: Tool 0 was not driven because its heater temperatures were not high enough or it has a heater fault
                2:02:16 PMM37 P"lm2596_case_fixed.gcode"
                Simulating print of file lm2596_case_fixed.gcode
                Error: SetPositions called when DDA ring not empty
                Cancelled simulating file lm2596_case_fixed.gcode after 0h 0m simulated time[/c]
                  That's a known issue.
                  • Nengermanundefined
                    Nengerman
                    I have updated the firmware from 1.20 to 1.21. Now the printer does not work anymore.
                    When I upload a print file, the bed and the extruder are heated, then the printer stops as if it is ready.
                    At Home All I get the error message G0 / G1: insufficient axes homed.
                    • resamundefined
                      resam
                      Nengerman: you have to read the release notes! Homing on a Cartesian/CoreXY printer changed.
                      • Doc_Penguundefined
                        Doc_Pengu
                        Does you'r homing script 1st lower/raise bed before it homes X and Y ? If so you need to add S2 parameter to you'r Z axis movement and then X and Y can be homed and Z axis after that 🙂
                        • Knaudlerundefined
                          Knaudler
                          @dc42:
                          Hello
                          there ist webcontrol 1.21 out
                          https://github.com/chrishamm/DuetWebControl
                          Ingo
                            Thanks, I've updated the release to include it.
                            • appjawsundefined
                              appjaws
                              I was running rc4 and have today updated to 1.21. I expected this to just work.
                              I uploaded the Duet2CombinedFirmware.bin, DuetWiFiServer.bin, iap4e.bin and DuetWebControl.zip files. When the duet rebooted it could not connect.
                              The USB printer interface connected to the printer so I tried to run M997 S0 to install the firmware again but this did not work.
                              I then erased and reset the board and used BOSSA 1.18 to install, so device manager shows Duet 2 WiFi or Duet 2 Ethernet 3D printer control electronics (COM5)
                              Then reset the board and connected the USB again. The printer is online but when I send M997 S0 I get the error Can't read from printer (disconnected?).
                              I have followed the Fallback procedure instruction on https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware
                              I am now stumpted How can I resolve this?
                              appjaws - Core XYUV Duet Ethernet Duex5
                              firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
                              Ormerod 1-converted to laser engraver, Duet wifi
                              OpenSCAD version 2024.03.18
                              Simplify3D 5.1.2
                              • appjawsundefined
                                appjaws
                                This is the result of M122.
                                SENDING:M122
                                Used output buffers: 1 of 32 (1 max)
                                RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.0 or 1.01 + DueX5
                                Board ID: 08DAM-999TL-NL5T8-6J1DL-3SJ6P-T65BJ
                                Static ram used: 16152
                                Dynamic ram used: 100440
                                Recycled dynamic ram: 2192
                                Stack ram used: 3576 current, 4456 maximum
                                Never used ram: 7832
                                Last reset 00:00:13 ago, cause: power up
                                Last software reset at 2018-03-12 17:04, reason: User, spinning module GCodes, available RAM 7768 bytes (slot 2)
                                Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
                                Error status: 0
                                Free file entries: 10
                                SD card 0 detected, interface speed: 12.0MBytes/sec
                                MCU temperature: min 18.1, current 21.3, max 21.4
                                Supply voltage: min 0.0, current 0.0, max 0.0, under voltage events: 0, over voltage events: 0
                                Driver 0: ok, SG min/max not available
                                Driver 1: ok, SG min/max not available
                                Driver 2: ok, SG min/max not available
                                Driver 3: ok, SG min/max not available
                                Driver 4: ok, SG min/max not available
                                Driver 5: ok, SG min/max not available
                                Driver 6: ok, SG min/max not available
                                Driver 7: ok, SG min/max not available
                                Driver 8: ok, SG min/max not available
                                Driver 9: ok, SG min/max not available
                                Expansion motor(s) stall indication: yes
                                Slowest main loop (seconds): 0.000242; fastest: 0.000047
                                MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
                                Scheduled moves: 0, completed moves: 0
                                Bed compensation in use: none
                                Heater 1 is on, I-accum = 0.0
                                Segments left: 0
                                Movement lock held by null
                                http is idle in state(s) 0
                                telnet is idle in state(s) 0
                                file is idle in state(s) 0
                                serial is ready with "M122" in state(s) 0
                                aux is idle in state(s) 0
                                daemon is idle in state(s) 0
                                queue is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                HTTP sessions: 0 of 8
                                • WiFi -
                                  Network state is disabled
                                  WiFi module is disabled
                                  Failed messages: pending 2779096485, notready 2779096485, noresp 2779096485
                                  === Expansion ===
                                  DueX I2C errors 0
                                Simplify3D 5.1.2
                                • appjawsundefined
                                  appjaws
                                  This is after re-enabling M552 S1 in config
                                  === Network ===
                                  • WiFi -
                                    Network state is starting
                                    === Expansion ===
                                    DueX I2C errors 0
                                  Simplify3D 5.1.2
                                  • appjawsundefined
                                    appjaws
                                    resolved
                                    For some reason it appears that the WiFi server had not started.
                                    re-installed and now all OK.
                                    Simplify3D 5.1.2
                                    • DunstonUKundefined
                                      DunstonUK
                                      It is alright changing stuff around, but how do you raise your Z when you have a bed crash, and all you get is
                                      M120
                                      G91
                                      G1 Z5 F6000
                                      M121
                                      Error: Pop(): stack underflow!
                                      and Yes I do have S2 in the files.
                                      Life’s bucket list is never ending. Remember someone else is always better than you.
                                        Those messages indicate that the printer was not homed when you ran that command. I guess you powered the machine down when you had the crash and then powered it up again. Possible actions in this situation include;
                                        • Home the printer. The homall file for a Cartesian or CoreXY printer normally raises the head a few mm before it does anything else.
                                        • Use M564 H0 to allow movement before axes are homed, either in config.g if you want it to be permanent, or temporarily
                                        • Use a macro to raise the head by 5mm, using S2 on the G1 Z command
                                        • jnolan72undefined
                                          jnolan72
                                          I am getting
                                          Request Timeout
                                          The last HTTP request has timed out. Please make sure the connection between your device and the board is not interrupted.
                                          Anytime I go into G-Code Files then into a Directory with lots of files. I get a spinney icon then
                                          request Timeout
                                          the files has a * infront of them.
                                          Looks like when I go into a directory that I have not gone into after the patch
                                          Some sort of processing is going on change the * to a page icon
                                          Same problem when I upload a large gcode file
                                          when I hit close after uploading
                                          the file show a * and the the Request Timeout
                                          • resamundefined
                                            resam
                                            jnolan72: try to reformat your SD card. I have similar issues from time to time. I think the filesystem on my card just gets fragmented or something - or my card is bad in general.
                                            Copy all your files to you PC. Format & wipe the cards. Make a clean FAT32 filesystem, and copy your files back.
                                            Also make sure to keep not too many files in one folder. There is a limit on how many files the Duet can handle. Less than 50 files per folder usually works for me.
