    It's out! Firmware 1.21 released
    Firmware installation
    25
    73
    13.1k
      That timeout is triggered when you have a very large gcode file on the SD card and your SD card is formatted with a small cluster size. You can send M39 to find the cluster size if you are running firmware 1.21.
      Get a new SD card, format it using FAT16 it is 4Gb or smaller, else FAT32 with 64kb clusters. Then copy all the files and folders over from the old SD card.
      Upgrading to firmware 1.21 may also help, if you are running an older version.
      • zerspaner_gerdundefined
        zerspaner_gerd
        three questions:
        1. what is meant by this?
          [c]For Duet 06 or 085: RepRapFirmware.bin and iap.bin[/c]
          Where do I see my version?
        2. Is the pressure range with nozzle offset checked during simulation?
        3. [c]When beginning a print from SD card, macro /sys/start.g is run if it is present[/c]
          Is there such a thing for the printing end?
        greeting
        Board: Duet WiFi 1.03 | Firmware Version: 3.1.1 | WiFi Server Version: 1.23 | Web Interface Version: 3.1.1
          1. The Duet 06 and Duet 085 are older boards that pre-date the Duet WiFi and Duet Ethernet. The PCB revision is printed on the board. For those boards it is 0.6 or 0.8.5. For Duet WiFi or Ethernet it is 1.0, 1.01, 1.02 or 1.03.
          2. Please explain what you mean by "pressure range".
          3. Yes, stop.g.
          • rpolteraundefined
            rpoltera
            Unable to adjust z hight with my IR probe I have raised and lowered over 5mm what worked before is no longer working it doesn't seem to change it is over 2mm of the build pate now
            have tried
            G31 P500 X0 Y0 Z-5.9
            all the way to
            G31 P500 X0 Y0 Z5.9
            with no change in the hight I have read the notes on the new version but not seeing it am I missing something?
            as I mentioned this used to work flawlessly and now I cant use my probe please advise.
              Is there a G31 command in config-override.g that is overriding the one in config.g? Prior to version 1.20, M500 used to save the G31 settings; now it does so only if you provide an extra parameter.
                zerspaner_gerd
                @dc42:
                3. Yes, stop.g.
                1. I have version "Duet2 V1.03" that means I would not need these files at all?
                2. Sorry, meant "print area" which was defined with M208.
                3. "Stop.g" not with me executed automatically at the end of the print, like "start.g" at the beginning of the print.
                  1. So you need the files listed for the Duet WiFi or Duet Ethernet (whichever board you have).
                  2. Yes, movement limits are applied during simulation. So G0/G1 moves that would go to outside the bed are modified to remain inside the bed, and G2/G3 moves that would go outside the bed cause the simulation to be aborted.
                  3. stop.g is only executed if your end gcode finishes with command M0.
                  • rpolteraundefined
                    rpoltera
                    no g31 in the config-override.g I added the config-override.g I also checked to make sure there was not a second g31 somehow
                    ; Heater model parameters
                    M307 H0 A90.0 C700.0 D10.0 S1.00 V0.0 B1
                    M307 H1 A272.0 C158.9 D3.3 S1.00 V23.7 B0
                    M307 H2 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H3 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H4 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H5 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H6 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                    M307 H7 A340.0 C140.0 D5.5 S1.00 V0.0 B0
                      zerspaner_gerd
                      @dc42:
                      1. Have DuetWifi.
                        So I only need these files:
                        [c]DuetWiFiFirmware.bin or Duet2CombinedFirmware.bin (which are the same file), DuetWiFiServer.bin and iap4e.bin[/c]
                        I do not need these:
                        [c]RepRapFirmware.bin and iap.bin[/c]
                      2. There is no message if G0/G1 is outside the print area?
                        So it does not come to a collision but my part is dan for the trash can, Mhh????
                        1. Correct.
                        2. In FDM printer mode, that is correct. The reason is that it is quite common for a skirt to exceed the bounds of the bed. In laser and CNC mode the print will be terminated. If you want this changes, please suggest what you would like instead in the Firmware Wishlist section.
                        • rpolteraundefined
                          rpoltera
                          I figured out my issue with the IR probe well got it working anyways must have been a bad update I guess formatted my sd card and added all my files back, and now it is working correctly.
                          • alclonkyundefined
                            alclonky
                            i tried to adjust my homing files for my Cartesian Printer
                            Homing X and Y works again, but home z just moves the 5 up and then stops with
                            G28 Z
                            Error: G0/G1: insufficient axes homed
                            myhomez.g:
                            G91
                            G1 Z5 F6000 S2
                            ; Back to absolute positioning
                            G90
                            ; Go to first bed probe point and home the Z axis
                            G1 X0 Y0 F6000
                            G30
                              Read the upgrade notes for firmware 1.21.
                              • alclonkyundefined
                                alclonky
                                I did, otherwise i couldn't home X and Y
                                or did I miss something else?
                                • deckingmanundefined
                                  deckingman
                                  Looking at the above, I'd have thought that your home Z will work but only if you have homed X and Y first. If you haven't, then this line G1 X0 Y0 F6000 will cause the problem. So to be safe, add S2 to it then it won't matter if X and Y have been homed.
                                  • alclonkyundefined
                                    alclonky
                                    i tried adding S2 to this line and without that line, but in both cases Z wont home
                                      Please confirm: are you saying that even if you have homed X and Y first, you get that message if you try to home Z?
                                      If you try to home Z without homing X and Y first, then that message is expected, because the firmware doesn't know where X0 Y0 is.
                                      • alclonkyundefined
                                        alclonky
                                        Yes, thats what i am saying
                                        i can home X and Y first and when i home z it failes
                                        if i home all it homes X and Y and failes with z
                                          Odd. In your homez.g you have the S2 parameter on the G1 Z5 command, which is the change you needed to make to homez.g. Please double check that the homez.g file in /sys on the SD card really does have that parameter, and what you posted isn't a copy on the PC that didn't make it to the printer.
                                          The other possibility is that homing X or Y has failed. After you home X and Y, the X and Y homing buttons in DWC should be blue, and Z will still be orange because it hasn't been homed. Is that what you see?
                                          Bogey55undefined 1 Reply Last reply Reply Quote 0
                                          • alclonkyundefined
                                            alclonky
                                            yes after homing X and Y the buttons get blue
                                            i copied the files from the /sys folder on the SD
                                            ; homeall.g
                                            ; called to home all axes
                                            ; Relative positioning
                                            G91
                                            ; Lift Z
                                            G1 Z5 F6000 S2
                                            ; Course home X and Y
                                            G1 X-200 Y-210 F1800 S1
                                            ; Move away from the endstops
                                            G1 X5 Y5 F6000
                                            ; Fine home X and Y
                                            G1 X-200 Y-210 F360 S1
                                            ; Absolute positioning
                                            G90
                                            ; Go to first bed probe point and home Z
                                            G1 X0 Y0 F6000 S2
                                            G30
                                            ; homey.g
                                            ; called to home the Y axis
                                            ; Lift Z relative to current position
                                            G91
                                            G1 Z5 F6000 S2
                                            G90
                                            ; Move quickly to Y axis endstop and stop there (first pass)
                                            G1 Y-210 F1800 S1
                                            ; Go back a few mm
                                            G91
                                            G1 Y5 F6000
                                            G90
                                            ; Move slowly to X axis endstop once more (second pass)
                                            G1 Y-210 F360 S1
                                            ; Lower Z again
                                            G91
                                            G1 Z-5 F6000 S2
                                            G90
                                            ; homex.g
                                            ; called to home the X axis
                                            G91
                                            G1 Z5 F6000 S2
                                            G90
                                            ; Move quickly to X axis endstop and stop there (first pass)
                                            G1 X-200 F1800 S1
                                            ; Go back a few mm
                                            G91
                                            G1 X5 F6000
                                            G90
                                            G1 X-200 F360 S1
                                            ; Lower Z again
                                            G91
                                            G1 Z-5 F6000 S2
                                            G90
                                            ; homez.g
                                            ; called to home the Z axis
                                            ; Lift Z relatively to current position
                                            G91
                                            G1 Z5 F6000 S2
                                            G90
                                            ;G1 X0 Y0 F6000 S2
                                            G30
