    It's out! Firmware 1.21 released
    Firmware installation
    25
    73
    13.1k
      Looks like Windows is displaying the filename in a local code page. DWC should handle Unicode if the installed font supports the particular characters. PanelDue supports Unicode characters up to 0x17F only.
      • jnolan72undefined
        jnolan72 @dc42
        Yes, It is related to what slicer created the file
        If sliced with Repetier Host Cura, shown in the Generated by Cura_SteamEngin 15.01.
        The error happens when calculation Object Height/Layer Height/ and Filament Usage.
        Onec calculation is done only Object Height that has any data, Layer Height/ and Filament Usage has n/a
        All other slicers I tried worked just fine Slic3r 1.2.9, Slic3r 1.34.1-prusa3d-win64, Sl1c3r 1.37.1-prusa3d-win64
          Have you tried a recent version of Cura?
          • jnolan72undefined
            jnolan72
            Yes, I Forgot to put that in the info. Cura 3.2.1 works fine also
            • BenDieselundefined
              BenDiesel
              I tried updating last night to 1.21. Got the firmware to go but the webserver is still at 1.19.2. And I can't seem to get the duettest.local to work any more. I uploaded a the files that the gethub said I should for the duetwifi.
              • vonGreezlyundefined
                vonGreezly
                SOLVED! See Below!
                Hey all, Just updated to 1.21 from 1.18. Having issues with Homing (yes it's a corexy!, and yes I put an S2 after my G1 Z lines). Machine attempts to home, but the endstops no longer seem to trigger properly. The LEDs turn off when the endstop is hit on the board itself, but the printer keeps moving =~~
                Also, confirmed w/ M119 that they're being seen when triggered...
                Not sure what I need to do, but i'm losing the battle! Help! 😄
                /code
                G91 ; relative mode
                G1 Z10 S2 ; Lift Z 10mm CYA!
                G1 S1 X-382 Y-382 F3000 ; course home X or Y
                G1 S1 X-382 ; course home X
                G1 S1 Y-382 ; course home Y
                G1 X4 Y4 F600 S2 ; move away from the endstops
                G1 S1 X-10 ; fine home X
                G1 S1 Y-10 ; fine home Y~~
                -VG
                NEVERMIND! Somehow, the Firmware update reversed the direction of my X and Y motors o.O; SUPER STRANGE AND SLIGHTLY FRUSTRATING!
                  Phaedrux Moderator @vonGreezly
                  @vongreezly There was a bug fix between 1.18 and 1.21 which reversed the direction of a motor in the CoreXY kinematics.
                  Gotta read all the release notes for all the versions between your current version and the latest update to catch all the little tidbits.
                  vonGreezlyundefined 1 Reply Last reply Reply Quote 0
                    vonGreezly @Phaedrux
                    @phaedrux Fair enough! it was a big jump heh 1.18 was just so lovely, and my printer was busy... was just a little panicked at the sudden state of borkedness =P
                    • Zesty_Lykleundefined
                      Zesty_Lykle
                      Absolutely flawless!
                      Did the whole upgrade, 3 files at once and it just did what it was supposed to do. Perfection!
                      Thanks David.
                      Lykle
                      Design, make and enjoy life
                      Co Creator of the Zesty Nimble
                      • Bogey55undefined
                        Bogey55
                        @alclonky Did you ever resolve this? I think I have the same problem. Even after X and Y are homed when I try to home Z I get movement to the desired movement up 5, x and y move to center of bed, and then I get the error message... G28 Z
                        Error: G0/G1: insufficient axes homed
                        (Have looked at the FAQ's topic 1, etc...)
                        • Bogey55undefined
                          Bogey55 @dc42
                          @dc42 Do you by chance know if @alclonky issue (G28 Z Error G0/G1: insufficient axes homed even if X and Y are homed / blue) was ever resolved? It sounds like I am having the same problem (on Firmware 2.01, have read FAQ#1, etc.) Thanks!
                          @dc42 said in It's out! Firmware 1.21 released:
                          Odd. In your homez.g you have the S2 parameter on the G1 Z5 command, which is the change you needed to make to homez.g. Please double check that the homez.g file in /sys on the SD card really does have that parameter, and what you posted isn't a copy on the PC that didn't make it to the printer.
                          The other possibility is that homing X or Y has failed. After you home X and Y, the X and Y homing buttons in DWC should be blue, and Z will still be orange because it hasn't been homed. Is that what you see?
                          Bogey55undefined 1 Reply Last reply Reply Quote 0
                          • Bogey55undefined
                            Bogey55 @Bogey55
                            @bogey55 @dc42 @alclonky ...okay figured it out reading a recent thread on G30...removed the deploy probe and retract probe files...problem solved
                              @bogey55 said in It's out! Firmware 1.21 released:
                              See the release notes for firmware 2.0. But as it comes up quite often, I'll add an FAQ about it.
