    Trouble setting up Resume after power failure
    1.3k
    • pogo1213undefined
      pogo1213
      I have been trying to get the resume after power failure to work. I have followed the setup at https://duet3d.dozuki.com/Wiki/Setting_up_to_resume_a_print_after_a_power_failure.
      Im using a standard endstop for the Zmax and an IR probe at the Zmin. When I run a print it homes then goes to zmax and states that it has finished one layer, raises to 200mm then back to zmax and states it has done another layer. Im not sure what to do from here, any help will be appreciated.
      Config
      ; generated by RepRapFirmware Configuration Tool on Tue Mar 27 2018 01:16:55 GMT-0500 (Central Daylight Time)
      M667 S1 ; Select CoreXY mode
      M550 P**** ; Set machine name
      M552 S1 ; Enable network
      M586 P0 S1 ; Enable HTTP
      M586 P1 S0 ; Disable FTP
      M586 P2 S0 ; Disable Telnet
      M569 P0 S0 ; Drive 0 goes backwards
      M92 X80 Y80 Z400 E814 ; Set steps per mm
      M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
      M201 X500 Y500 Z250 E250 ; Set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X300 Y300 S0 ; Set axis maxima
      M208 Z491.3 S1
      M574 X1 Y1 S1 ; Set active high endstops
      M574 Z2 S1
      M574 Z1 S1 ; Set endstops controlled by probe
      M558 P1 H5 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z1.8 ; Set Z probe trigger value, offset and trigger height
      M557 X25:275 Y25:275 S65 ; Define mesh grid
      M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
      M305 P0 T100000 B3974 C0 R4700 ; Set thermistor + ADC parameters for heater 0
      M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
      M563 P0 D0 H1 ; Define tool 0
      M911 S21.0 R23.0 P"M913 X0 Y0 M83 G1 Z3 E-5 F1000" ; Automatic saving after power loss is enabled
      Home Z
      G91 ; relative positioning
      G90 ; absolute positioning
      G1 X25 Y25 F6000 ; go to first probe point
      ;G91 ; relative positioning
      ;G1 Z5 F100 S2 ; lift Z relative to current position
      ;G90 ; absolute positioning
      resurrect-prologue.g
      M116 ; wait for temperatures
      G28 X0 Y0 ; Home X and Y to min
      G1 S1 Z500
      M83 ; Relative Extrusion
      G1 E4 F3600 ; Undo the retraction that was done in the M911 Power Fail Script
        1. To be clear: the problem occurs when you run a normal print? Or did you mean it occurs when you resurrect a print?
        2. Was the printer working before you added the M911 line? If so, does it work again if you comment out the M911 line? If so, at the end of a print if you run M122, what values are shown for the minimum and maximum VIN voltage?
        3. The M911 line is not quite right, it should be:
        M911 S21.0 R23.0 P"M913 X0 Y0 M83 G91 G1 Z3 E-5 F1000" ; Automatic saving after power loss is enabled
        because you want the axes to be in relative mode when you execute the G1 Z3.
        4. In your resurrect-prologue.g file you need to home Z to Z max with something like this:
        G1 S1 Z500 Fnnn
        with a suitable F parameter for your machine. Then if you want, back off a few mm and home again at a slower speed.
        • pogo1213undefined
          pogo1213
          It was happening with a normal print, Ill make these adjustments and give it a try.
          Thank You!
          • pogo1213undefined
            pogo1213
            I have tried your changes with the same result, I also commented out the M911 command and it did the same thing. THe only thing that is changing between the working config and the not working config is the endstop setup.
            Working Config
            M208 X300 Y300 Z500 S0 ; Set axis maxima
            Not Working
            M208 Z491.3 S1
            M574 Z2 S1
              Why do you have the line M574 Z1 S1 in config.g if you are using a Z max endstop switch?
              • pogo1213undefined
                pogo1213
                I used the reprap config and it was in there from that, ill remove it and test it again.
                • pogo1213undefined
                  pogo1213
                  Removed the M574 code
                  M550 P***** ; Set machine name
                  M208 Z491.3 S1
                  M574 Z2 S1
                  The print begins, reaches temp, homes zxy to min and runs a four point bed probing. Then the printer lowers the bed to the max and once it reaches max begins to move up to 200mm and then goes back down to the max. It continues this cycle and counts each cycle as a layer. This Gcode has been ran successfully before implementing the M911 code and adding the Zmax endstop.
                    Your M291 M208 Z491.3 command should have S0 not S1 because it is setting the upper limit.
                    • pogo1213undefined
                      pogo1213
                      M208?
                      Ill try out M208 Z491.3 S0
