    U axis sensorless homing
    • jmjcokeundefined
      jmjcoke
      I am have a problem with U axis not moving after I home the axis. I have setup sensorless homing for a U axis that is connected to the E0 position on a duet wifi. The axis moves as comanded via a macro for testing the sensorless homing settings. I adjusted the M915 S value and the U axis homes, I then home the delta xyz axis. Duet web interface show all axis homed but when I try to move the U axis via the jog buttons U does not move. Are any of the E parameters for the hotend temp active when you map an axis to E0?
      Joshua Coke
      Trick Laser Metal Max with Smart Effector
      Duet Wifi
      Zesty Nimble
      Mosaic Pallette+
      At work
      Renishaw AM250/400/ RenAM500M/500Q Powder Bed Fusion (Metal 3D Printers)
      • jmjcokeundefined
        jmjcoke
        The problem was in M208, I had no S1 for min travel.
        Joshua Coke
        Duet Wifi
        Zesty Nimble
        Mosaic Pallette+
        At work
