    Posting Pictures and Video on the forum
    17
    1984
    • ronnien59
      ronnien59 last edited by
      Can someone help with posting media. Trying to post pictures of my printer running with the DuetWiFi.
      • Qdeathstar
        Qdeathstar last edited by
        upload the images to postimg.org, there is bar in the right, switch to "direct link", then put
        [img]https://s17.postimg.org/d3cw7sw3z/IMG_0743.jpg[/img]
        subing that link for yours…
        • roboduet
          roboduet last edited by
          Seems like we should ask forum administrators to enable picture uploads to this forum instead of other sites 🙂
          • T3P3Tony
            I have it in my list to investigate
            www.duet3d.com
            • ronnien59
              @Qdeathstar:
              Does that apply to video as well using the "address here"
              • Qdeathstar
                I'm not sure, but you could post a link to YouTube…
                Personally I think it's better (reduces server load) to have people use image hosting... And
                • iDevelo
                  iDevelo last edited by
                  @Qdeathstar:
                  True but bandwidth and space are cheap and don't forget postimage very nearly shut down last month https://blog.postimage.org/2016/10/30/postimage-needs-your-help/ so you always risk a forum without images if you don't host your own.
                    Hosting images on Dropbox also works but when pasting the link you need to replace the ?dl=0 at the end by ?raw=1.
                    • T3P3Tony
                      For video YouTube is the way to go…I will look at different image options.
                      www.duet3d.com
                      • Simspeed
                        Simspeed last edited by
                        What did we come up with for including images into our posts? I see them on post in the new printers section but can't figure it out for myself. Thanks for the help…
                        Custom C-Beam H-Bot - Hard mount 560mm x 800mm MIC 6 bed plate - 3mm PEI print surface- 120v mains silicone bed heater (3 zones) - 800mm Z axis - polycarbonate enclosure - (4) .09° Nema 23s (Z) - .09° Nema 17s (XY) - Bondtech extruders - E3D Cyclops hotend, 24V power supply
                        • T3P3Tony
                          The best bet for images is to use an external service like imgur, dropbox, etc then use the image tags to insert it eg:
                          [[language]]
                          [img] http://i.imgur.com/example.jpg [/img]
                          tag to insert them
                          Its on my to do list to add secure, abuse safe image impload to this forum but its that high on the list right now I am afraid.
                          www.duet3d.com
                          • Simspeed
                            @T3P3Tony:
                            [[language]]
                            tag to insert them
                            OK, got it figured out. Thanks for the help.
                            • ronnien59
                              I will try
                              • iDevelo
                                Tony. Give me access 🙂 my main job is software development so I kinda know what I'm doing.
                                • ronnien59
                                  Thanks Admin
                                  • DjDemonD
                                    DjDemonD last edited by
                                    The only problem with dropbox (or onedrive etc..) is that you really need to be prepared to host the image forever, otherwise very useful posts with vital diagrams within them will not exist if you close your account, move the files etc…
                                    Whilst postimage is very useful and seems to work it would also be a great shame if it disappeared for the same reasons.
                                    This forum ought to be able to accept image uploads, and perhaps like reprap.org could limit the image size to keep the storage requirements reasonable (although if possible some automatic means of resizing or lowering image quality would save users a great deal of time). Ps. On reprap to resize quickly, I got this program for windows http://www.bricelam.net/ImageResizer/ which gives you a right click option to resize images to a size you know will be accepted, and can automatically replace the original image or save it as a copy.
                                    www.precisionpiezo.co.uk
                                    • T3P3Tony
                                      Let's chat more about this over email.
                                      www.duet3d.com
