    Homed Height
    1388
    • bulka
      bulka last edited by bulka
      this is my config.g (Duet3D wiffi + Smart effector):
      ; generated by RepRapFirmware Configuration Tool on Fri Apr 20 2018 11:48:27 GMT+0200 (W. Europe Summer Time)
      M555 P1 ; Set firmware compatibility to look like RepRapFirmare
      M665 R190 L375 B85 H600 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them
      M92 X80 Y80 Z80 E663 ; Set steps per mm
      M566 X2400 Y2400 Z2400 E1200 ; Set maximum instantaneous speed changes (mm/min)
      M203 X36000 Y36000 Z36000 E1200 ; Set maximum speeds (mm/min)
      M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
      M906 X1200 Y1200 Z1200 E700 I60 ; Set motor currents (mA) and motor idle factor in per cent
      M84 S15 ; Set idle timeout
      M208 Z0 S1 ; Set minimum Z
      M574 X2 Y2 Z2 S1 ; Set active high endstops
      M558 P5 R0.4 H5 F120 T6000 ; Set Z probe type to effector and the dive height + speeds
      G31 P100 X0 Y0 Z-0.1 ; Set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; Define mesh grid
      M143 H0 S100 ; Set temperature limit for heater 0 to 100C
      M305 P1 X200 ; Configure thermocouple for heater 1
      M143 H1 S330 ; Set temperature limit for heater 1 to 330C
      M106 P1 S1 I0 F500 H1 T40 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M106 P2 S1 I0 F500 H1 T40 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
      M563 P0 D H1 ; Define tool 0
      I'm trying to go down and see with M114 the value....increment value H on M665 ....homing all axis and try again...
      but the value seems to be more than the expected....now is 600 and when I go down...at 0 there is space...
      I measured the distance between the hotend and the bed....and is less the 600mm....and I don't now how to fix this...
      I never used autocalibration ( why? ..because I thought that before to do that...I need to fix the height....I'm wrong? because I'm thinking that if the height is not correct....when autocalibration start...can touch the bed with more force then needed and break the glass )
      what can I do?
      Thx
      Giulio
      • bulka
        I think of my misunderstanding about absolute/relative positioning
        • bulka
          I found a value that seems to works.
          Now I followed this:
          Measuring the trigger height
          The Z probe trigger height must not vary significantly with XY position. Measure the trigger height of your Z probe at various XY positions and make sure it is consistent. To measure the trigger height:
          1. Make sure there is no filament stuck to the nozzle (you may want to do this test with the nozzle hot)
          2. Cancel any existing bed compensation by sending M561
          3. Send M208 S1 Z-3 to temporarily allow Z moves down to Z=-3mm. This is to ensure that you can lower the nozzle all the way to the bed in step 5.
          4. Command the print head to the XY coordinates you want to probe
          5. Command the print head down in small steps until the nozzle just touches the bed or just grips a sheet of paper. You may need to send M564 S0 to allow movement lower than where the firmware thinks Z=0 is. You may also wish to create a macro to lower the head by e.g. 0.02mm to get greater accuracy (G91 followed by G1 Z-0.02).
          6. Send G92 Z0 to define that height as Z=0
          7. Command the nozzle up 5mm (G1 Z5)
          8. Send G30 S-1 to probe the bed without resetting the Z=0 position
          9. Read off the Z height from the web interface. That is the trigger height.
          10. Repeat the previous two steps a couple of times to make sure you are getting a consistent result
          11. Repeat steps 4-10 for the other XY positions you want to check
          When you have established what the trigger height is, set the Z parameter og the G31 command in config.g to that value.
          and found Z-probe height -0.37 and I decided to run an auto delta calibration.
          this is the step of autocalibration:
          G30 P0 X0 Y84.9 H0 Z-99999
          G30 P1 X49.9 Y68.69 H0 Z-99999
          G30 P2 X80.74 Y26.24 H0 Z-99999
          G30 P3 X80.74 Y-26.24 H0 Z-99999
          G30 P4 X49.9 Y-68.69 H0 Z-99999
          G30 P5 X0 Y-84.9 H0 Z-99999
          G30 P6 X-49.9 Y-68.69 H0 Z-99999
          G30 P7 X-80.74 Y-26.24 H0 Z-99999
          G30 P8 X-80.74 Y26.24 H0 Z-99999
          G30 P9 X-49.9 Y68.69 H0 Z-99999
          G30 P10 X0 Y42.4 H0 Z-99999
          G30 P11 X36.72 Y21.2 H0 Z-99999
          G30 P12 X36.72 Y-21.2 H0 Z-99999
          G30 P13 X0 Y-42.4 H0 Z-99999
          G30 P14 X-36.72 Y-21.2 H0 Z-99999
          G30 P15 X-36.72 Y21.2 H0 Z-99999
          G30 P16 X0 Y0 H0 Z-99999 S3
          the steps in bold are steps where nothing triggered...and...this is the result:
          Error: Compensation or calibration cancelled due to probing errors
          • bulka
            I need to adjust only H parameter on the steps where the probe not triggered and run autocalibration again or I'm following a wrong way?
            • bulka
              corrected some values and autocalibration terminated correctly with this result:
              Calibrated 3 factors using 17 points, deviation before 2.173 after 2.069
                1. You should not need to use any H parameters on the G30 commands in bed.g when using the Smart Effector, or any other nozzle contact bed probe.
                2. When running auto calibration for the first time, increase the M558 H parameter as recommended in the wiki page on delta calibration.
                3. If your homed height has come out at 600mm but is in reality less than this, perhaps you have the wrong steps/mm set in config.g? 80 steps/mm is correct for 1.8deg motors used with 20-tooth GT pulleys.
                4. You should calibrate at least 4 parameters (not 3) and preferably 6.
                • bulka
                  ok ..my step motors are 0.9 ...I think I should double the value and use 160
                    dc42 administrators @bulka last edited by
                    @bulka said in Homed Height:
                    Yes, if you are using 20-tooth pulleys. If your pulleys are 16-tooth then it should be 200.
                    • bulka
                      yes is a pulley 20T. thx 🙂
                      I corrected the config file and now the H is what I measured:
                      M665 R55.41 L355.00 H366.75 B170.00
                      M666 X0 Y0 Z0
                      M92 X160 Y160 Z160 E663 ; Set steps per mm
                      G31 P100 X0 Y0 Z-0.252 ; Set Z probe trigger value, offset and trigger height
                      • bulka
                        I changed the calibration on bed config file using :http://www.escher3d.com/pages/wizards/wizardbed.php
                        • bulka
                          what I'm not sure about this command ... the parameter R and L ( don't kill me )
                          I don't understood perfectly how to calculate it... 😞
                          I changed the M558 as suggested in the wiki ( and by you ) to M558 P5 R0.4 H20 F120 T6000
                            L is the rod length measured between bearing centres. If you are using Haydn Huntley's magnetic rods, each rod carries a label on which its length is written, so use that figure.
                            R is the delta radius. The exact value will be found by calibration, so you need to provide only an approximate value. Use the horizontal distance subtended by any rod, measured between bearing centres, when the effector is central.
                            • bulka
                              ok.
                              changed to:
                              M665 R168 L360 H366.75 B170.00
                              M666 X0 Y0 Z0
                              I'll try to start auto calibration 🙂
                              • bulka
                                Calibrated 6 factors using 16 points, deviation before 1.322 after 0.029
                                • bulka
                                  change calibration to 7 factor:
                                  Calibrated 7 factors using 16 points, deviation before 1.201 after 0.016
                                  Dougal1957 1 Reply Last reply Reply Quote 0
                                  • Dougal1957
                                    Dougal1957 @bulka last edited by
                                    @bulka not wise to use 7 factor if you know your rod length properly use either 6 or 8
                                    • bulka
                                      ok, I read after your answer on wiki: " typical delta printer builds, 6-factor is best"
                                      Changed beg config file:
                                      13:21:29
                                      Calibrated 6 factors using 16 points, deviation before 0.017 after 0.014
                                      13:23:13
                                      M665
                                      Diagonal 363.663, delta radius 173.193, homed height 366.386, bed radius 170.0, X -0.034°, Y -0.209°, Z 0.000°
                                      13:23:09
                                      M666
                                      Endstop adjustments X0.20 Y0.83 Z-1.03, tilt X0.00% Y0.00%
                                      If I'm not wrong...after calibration....the Diagonal was changed....it's wrong to use 6 factors using 16 points?
                                      • Dougal1957
                                        @bulka the drag rod length was changed by the previous 7 factor cal you need to manually reset the rod length and run it again with either 6 or 8 factor cal
                                        • bulka
                                          done 🙂 thank you
                                          thank you DC 🙂
