    eSwitch mount for Duet Wifi (for Berd Air system)
    • Hergonowayundefined
      Hergonoway
      I wanted to share with you a design I've made to install the eSwitch board from Makerhive onto the Duet Wifi. I've search a way to carry the board on my printer while installing the Berd Air system, I finally ended up by designing this mount.
      It plugs in an IDC connector and was designed to coexist with a PT100 daughter board 🙂
      Here's the link : https://www.thingiverse.com/thing:2879778
      Hope it'll help few guys around here.
      Delta goes BrrrRRRRrrrrrRRRRrrr
      • timcurtis67undefined
        timcurtis67
        Sweet! Thank you. I'll print one up and try it out.
        • uk25undefined
          uk25
          Very clever design, thanks!
            Hergonoway
            Note : If you make terrible bridges just add support, but only for the bottom plane, groove slots are made with a 45 degrees angle so no bridge are required since it's not an extrem overhang.
