    Ajax error after bed probe
    1351
    • bendy
      bendy last edited by
      Hi All,
      When ever I run a bed probe (via G32 S2), once the probe completes, I get an AJAX error on the web interface and am unable to reconnect.
      The error I get is:
      [[language]]
      Communication Error
      An AJAX error has been reported, so the current session has been terminated.
      Please check if your printer is still on and try to connect again.
      Error reason: SyntaxError: Unexpected token a in JSON at position 65
      ```I am running 1.16 firmware with 1.13 web interface.
      If I restart the controller, I can get back in.
      Any ideas?
      • bendy
        Note that this issue also occurs after using the "Auto Bed Correction" button from the Machine control page (which I am guessing just does some flavour of a G32 in the background)
        • Sniffle
          Sniffle last edited by
          the "Auto Bed Correction" enacts your Bed.g file so yes it does whatever you set it to.
          • StephenRC
            StephenRC last edited by
            @bendy:
            Check your bed.g file, there may be a bad gcode in there.
              What we really need to see is the json message that provoked the error. Can you provide a Wireshark pcap file?
              • bendy
                Here are the contents of my bed.g -
                [[language]]
                ; bed.g
                ; generated by RepRapFirmware Configuration Tool on Sun Nov 27 2016 09:59:20 GMT+1100 (AEDT)
                ; Clear any bed transform
                M561
                ; Probe the bed at 4 points
                G30 P0 X75 Y110 H0 Z-99999
                G30 P1 X345 Y110 H0 Z-99999
                G30 P2 X345 Y355 H0 Z-99999
                G30 P3 X75 Y355 H0 Z-99999 S
                I will get a packet trace done later on and post it up.
                • bendy
                  Quick update - I have manually executed the commands in bed.g and the first 4 commands work fine, it is only when the last line -
                  [[language]]
                  ```Is executed that the system crashes. The probe works as expected but I am guessing when the calculation of the Z plane is done it is causing an issue. I have tried it with both S and S4 with the same result. Packet trace still to come.
                  • Jackal
                    Jackal last edited by
                    Your probe points have to been in a clockwise order, starting nearest to 0,0
                    • bendy
                      OK, Another update - the Ajax error is masking some other error here related to z plane calculation by the looks of it - If I run the probe for 3 points it works fine, it only fails if I do it for 4 points (am running a cartesian setup so 4 points should be supported?)
                      • Qdeathstar
                        Qdeathstar last edited by
                        @Jackal:
                        Is that true? DC42's calibration calculator suggestions points starting at the z-tower, then moving clockwise moving towards 0,0 with the last probe being 0,0…. should i rearrange the probes?
                        • lignumaqua
                          lignumaqua last edited by
                          Your sequence is anti-clockwise instead of clockwise, I suggest trying:
                          G30 P0 X75 Y110 Z-99999		; Bottom Left
                          G30 P1 X75 Y355 Z-99999		; Top Left
                          G30 P2 X345 Y355 Z-99999	; Top Right
                          G30 P3 X345 Y110 Z-99999	; Bottom Right
                          G30 P4 X210 Y232 Z-99999 S0	; centre, and calibrate compensation
                          • Jackal
                            @Qdeathstar:
                            @Jackal:
                            The calibration calculator is for Deltas. For Cartesian machines, you need them in clockwise order.
                            I stumbled upon a similar discussion before, you can find them by searching 'clockwise' in the forum.
                            • bendy
                              OK, looks like going clockwise fixed it
