    Noobs questions.
    • cabal2000undefined
      cabal2000
      Hi guys. Very new to Duet. I just put an order in for the Maestro. BUT I do have a few questions. 1. Bltouch, I am guessing that it is compatible. 2. Marlin, can you install it or just the supplied firmware?
        Yes the BLTouch is compatible.
        https://duet3d.dozuki.com/Wiki/Choosing_a_Z_probe
        https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe
        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
        Once you get used to RepRapFirmware you won't want to install Marlin even if you could. The power, simplicity and speed of being able to edit a config file or send a command and instantly see the result is hard to describe when you're used to recompiling and uploading. And the macros system opens up a whole new way to customize and automate your printer.
        cabal2000undefined 1 Reply Last reply Reply Quote 0
          cabal2000 @Phaedrux
          @phaedrux Thanks!!
