    Can I home to Z max?
    • Artyundefined
      Arty
      Hello. I have one simple question. I have custom diy h-bot with endstop in the bottom of my machine. Duet wifi guide suggests using z probe for homing Z axis to Z min and I didn't find information how to home to Z max endstop. Is it possible? How can I setup this?
      • gen2engundefined
        gen2eng
        I home to max and then probe the bed at the start of the print. I'm using a Precision Piezo20 for the probing.
        Relevant parts of my startup gcode
        G28 ; home
        G1 X200 Y200 Z5 ; Move close to center of the bed
        M109 S160 ; set the hotend temperature for probing and wait
        G30 ; Simple probe of the bed to set 0 and squish any drool
        G30 ; do it again rule out any squish
        G29 S1 ; Load the bed height map
        My Config
        ; generated by RepRapFirmware Configuration Tool on Sat Feb 17 2018 18:30:50 GMT-0500 (EST)
        M111 S0 ; Debugging off
        G21 ; Work in millimetres
        M555 P1 ; Set firmware compatibility to look like RepRapFirmare
        M550 PCoreXY ; Set machine name
        M552 S1 ; Enable network
        M586 P0 S1 ; Enable HTTP
        M586 P1 S0 ; Disable FTP
        M586 P2 S0 ; Disable Telnet
        M667 S1 ; Select CoreXY mode
        M208 X0 Y0 Z-5 S1 ; Set axis minima
        M208 X400 Y400 Z444 S0 ; Set axis maxima
        M574 X1 Y2 Z2 S0 ; Set active low endstops
        ; Z Probe
        M558 P5 I1 R0.9 F360 T1000 A3 ; Set Z probe type to switch and the dive height + speeds
        G31 X0 Y0 Z-0.15 P600 ; Set Z probe trigger value, offset and trigger height
        ; Define mesh grid
        M557 X40:360 Y40:360 S32
        M569 P0 S0 ; Drive 0 goes backwards
        M92 X80 Y80 Z1600 E838 ; Set steps per mm // 1.8 stepper 419
        M566 X500 Y500 Z12 E1200 ; Set maximum instantaneous speed changes (mm/min)
        M203 X18000 Y18000 Z1250 E3600 ; Set maximum speeds (mm/min)
        M201 X1600 Y1600 Z300 E1500 ; Set accelerations (mm/s^2)
        M906 X1480 Y1480 Z1500 E1200 I15 ; Set motor currents (mA) and motor idle factor in percent (1.8 stepper extruder E600)
        M84 S30 ; Set idle timeout
        ; Heated Bed
        M307 H0 A202.0 C457.0 D1.6 S0.80 V24.0 B0 ; PID settings
        M305 P0 T99904 B3932 C8.791829e-8 R4700 ; Set thermistor + ADC parameters for heater 0
        M143 H0 S140 ; Set temperature limit for heater 0 to 140C
        ; Hotend
        M307 H1 A472.5 C292.1 D5.2 S0.95 V24.0 B0 ; PID settings
        M305 P1 X200 ; Use RTD 0
        M207 S0.80 F2400 Z0.30 ; Firmware retraction .8mm, 40 mm/s, z hop of 0.30
        M563 P0 D0 H1 ; Define tool 0
        ;M106 P1 S255 I0 F20 H1 T55 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P1 S255 I0 F500 H1 T55 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
        M106 P2 S0 I0 F500 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned off
        ; Load the bed mapping file automatically
        G29 S1
        M912 P0 S-7.1 ; Offset CPU temperature
        T0 ; Select Extruder
