    Duet WiFi stopped connecting randomly
    1069
    • samthomas
      samthomas last edited by
      A few days ago my Duet WiFi disconnected from the network and wouldn't reconnect. After reflashing the firmware, running a number of diagnostics, formatting the SD card, etc, I have gotten it to connect, but Duet Web Control doesn't really work. I can get it to sort of show up for a half second, albeit in plain text, with none of the buttons or links working, but then the web server will crash again. I'm not sure what's wrong. It also won't automatically connect to WiFi anymore either. Is it possible I'm looking at a warranty claim?
      • norbs12
        norbs12 last edited by
        So I've had one bug that "kills" my config.g and seems to result in similar issue you're describing.
        If I edit my config.g and save it, the GUI will ask if I want to reboot. Many of the times when I click "yes". I end up losing my config.g and have to take the SD card out and plug into my laptop. The fix is just to rename config.g.bak to config.g in the /sys directory.
        Not sure if your issue is that simple but I thought I'd share.
          dc42 administrators @samthomas last edited by
          @samthomas said in Duet WiFi stopped connecting randomly:
          The most likely causes of those symptoms are:
          • WiFi signal too weak
          • IP address clash
          • Faulty SD card
          • 3.3V power rail too low (possibly due to induvvidient 5V power)
          • Faulty WiFi module
          • samthomas
            M122 output, again, not sure why but wifi doesn't automatically connect on startup even though my config is correct. So had to manually connect it.
            Used output buffers: 1 of 32 (9 max)
            RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
            Board ID: 08DDM-9FAM2-LW4SD-6J9FA-3S86R-KMWVX
            Static ram used: 16152
            Dynamic ram used: 100408
            Recycled dynamic ram: 2224
            Stack ram used: 3576 current, 4928 maximum
            Never used ram: 7360
            Last reset 00:09:41 ago, cause: power up
            Last software reset time unknown, reason: User, spinning module GCodes, available RAM 7776 bytes (slot 1)
            Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
            Error status: 0
            Free file entries: 10
            MCU temperature: min 36.4, current 37.0, max 37.2
            Supply voltage: min 11.9, current 12.0, max 12.1, under voltage events: 0, over voltage events: 0
            Slowest main loop (seconds): 0.200588; fastest: 0.000047
            MaxReps: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 240, MaxWait: 0ms, Underruns: 0, 0
            Scheduled moves: 0, completed moves: 0
            Bed compensation in use: none
            Heater 1 is on, I-accum = 0.0
            Segments left: 0
            Movement lock held by null
            http is idle in state(s) 0
            telnet is idle in state(s) 0
            file is idle in state(s) 0
            serial is ready with "M122" in state(s) 0
            aux is idle in state(s) 0
            daemon is idle in state(s) 0
            queue is idle in state(s) 0
            Code queue is empty.
            === Network ===
            HTTP sessions: 0 of 8
            • WiFi -
              Network state is running
              Failed messages: pending 0, notready 0, noresp 1
              WiFi firmware version 1.21
              WiFi MAC address 60:01:94:33:e4:1b
              WiFi Vcc 3.36, reset reason Turned on by main processor
              WiFi flash size 4194304, free heap 16648
              WiFi IP address 192.168.1.131
              WiFi signal strength -75dBm, reconnections 0, sleep mode modem
              === Expansion ===
              ok
            • samthomas
              This is what appears if I go to the IP my Duet is hosting from, the full DWC won't load and nothing works. If you refresh it it will simply no longer load at all.
                That's too low for a reliable connection. See https://duet3d.dozuki.com/Wiki/WiFi_disconnections_and_AJAX_timeout_errors.
                samthomas 1 Reply Last reply Reply Quote 0
                • samthomas
                  samthomas @dc42 last edited by
                  @dc42 said in Duet WiFi stopped connecting randomly:
                  I got it lowered to -62dBm with no improvement in symptoms, but it has ALWAYS had a -60-70dBm signal strength for the past six months with only the occasional disconnection.
                  • samthomas
                    Regardless, even when I move it downstairs for a massive improvement in signal strength, I still have the same issue.
                    • samthomas
                      OK update, I went ahead and swapped it with my spare Duet WiFi that is going into the HEVO I'm building. I used the same SD card as the one having issues. It has the same firmware. Connected right off the bat. Working fine. I think there is further testing to be done though.
