    Berd-Air pump configuration notes for Duet users
    46
    7158
    • MSquared
      MSquared administrators last edited by
      I have seen a lot of questions about setting up a Berd-Air pump on the Duet and since I have done just that recently I figured I would post some of my experiences.
      1. If you are running a newer Duet you can wire the pump directly to the board so long as you are using an appropriate flyback diode, and follow @dc42's recommendations in this thread to make sure you are protecting the fan MOSFET adequately. I believe on older Duets you will in fact need to use the e-switch or an equivalent external relay / mosfet / opto-isolating circuit. I have an e-switch which I used initially and it requires some soldering skills to build, but worked really well. I also used the YJ-Pad which simplified the wiring somewhat.
      2. Running the pump at an adequate PWM frequency will DRAMATICALLY reduce the noise and vibration from the pump. I run mine at 25500khz with no issues. I find that the pump/tube combination is noticeably quieter than my old axial fan /shroud setup and I really barely notice the pump noise over the sound of my extruder most of the time.
      3. Running the pump at an adequate PWM frequency will DRAMATICALLY reduce the amount of heat that the motor generates. When running at a low PWM frequency my motor was often too hot to touch after running for only a few minutes. Once I bumped that up the motor gets only slightly warm after running for a few hours.
      4. If you are planning on mounting it to the frame of your printer vibration dampening is essential. I found that my piezo probe was quite helpful in this regard as I was able to test several different strategies and monitor the results by looking at the piezo sensor level. I ended up using the 3mm larger standard mount with some pieces of 1/4" ID rubber vacuum tube from an automotive shop as "insulation" between the mount and the motor, and the mount and the frame. To accomplish this I cut some lengths of tubing and then cut that tubing in half across it's diameter, this gave me a nice "arch" of tubing that I then wedged into the mount to act as a dampener as shown in this picture:
      I used three pieces of tubing in the mount, and one between the mount and the frame. Ideally I would have also isolated the screws going into the frame as they are still quite capable of conducting vibrations but I have not yet designed that mount.
      I run the Berd-Air from about 20% - 75% in my slicer for PLA and it works great, I plan on dialing that in a little bit more but thats a good starting range.
      Hope this helps someone!
      -M
      hurzhurz Hergonoway 2 Replies Last reply Reply Quote 3
      • ShadowX
        ShadowX last edited by
        You're not going to be able to dampen the motor with just soft mounts if your holder is rigid. There is a floating mount for berd air motors on Thingiverse. If your fan runs hot, you can search eBay or AliExpress for "540 motor heatsink" to get a heatsink and fan combo to cool the motor down. I use an aluminum heatsink with a constant fan that is always on as soon as I turn the machine on. I also got a panel meter to give me the voltage reading based on the PWM duty cycle and the current going through the motor. The current on the stock motor fluctuates from 0.8A to 2.1A. It may need a good break-in period to stabilize.
        • ShadowX
          I ended up using a heatsink like this one to help it cool down. Its not so bad now that its running at around 0.9A at around 8V with the PWM set at around 60-70%. I have a 12V motor.
          • MSquared
            Seriously...check the PWM frequency on the fan port you are using to drive it. Once I bumped the PWM freq up to 20k the temp on the motor dropped like a rock.
            ShadowX 1 Reply Last reply Reply Quote 0
            • Dougal1957
              Dougal1957 last edited by
              just to add to this we found that the 12V motors run a lot hotter than the 24V ones also the 12V ones are quite able to take out the Mosfets on the Duet (We had this happen to a friend of mine) on testing we found that the coil resistance on the 12V pumps was quite low and they could possibly draw an inrush current of around 9 amps (Coil resistance measured between 2.7 and 3.2 ohms depending on where in the rotational arc it was). The onboard fan misfit recommended max current is 1.5 amps.
              the 24V pumps are also much quieter than the 12V ones and they use 550 series motors not 540 ones (A bit larger they both use the 555 series motors.
              So I would suggest if useing 12V systems then def use a external Set board (I used the Power Expander from Reprap.me) and maybe even a separate PSU for them. I swapped mine out to 24V but still kept the power expander for a little bit of additional safety.
              Doug
              • gen2eng
                gen2eng last edited by
                Thanks for this!
                I've confirmed much improved noise level and less heat running at the higher frequency both on 12V and 24V Berd-Airs.
                • ShadowX
                  ShadowX @MSquared last edited by ShadowX
                  @msquared The PWM had nothing to do with my high temps and high current. I was running it directly from my variable bench power supply at a fixed DC level and it was still overheating. It has stopped doing it now, but it was not related to the PWM frequency. I did run my motor through a break-in and cleaned all the residue out. It has functioned fine since. I have been running the motor at different voltage levels and I know it randomly goes up in current. It may have been due to friction on the sleeve bearings. Its running at around 8.2V at 0.85A, which is very good. It runs very cool and quiet.
                  • DaveA
                    DaveA last edited by
                    I'm a bit confused about PWM. I have a Berd-Air pump on fan 0 through an e-switch mosfet.
                    If I add an F25500 parameter to the M106 I have very little control over fan speed.
                    If I leave off the F parameter I can vary pump speed from 0 to full speed. It seems that the higher the PWM frequency the less control over fan speed.
                    When you run with a high PWM frequency are you still going through an e-switch?
                    MSquared 1 Reply Last reply Reply Quote 0
                    • MSquared
                      MSquared administrators @DaveA last edited by
                      @davea said in Berd-Air pump configuration notes for Duet users:
                      I was not. I still have my e-switch lying around and I may get a chance to test that later tonight or tomorrow and let you know my results. It is very possible that the e-switch may not respond to high PWM values as well as the pump does directly. If that is the case I have a DC-DC SSR lying around and I may give that a shot to see if it makes a difference.
                      • MSquared
                        For reference here is a DB monitor of the pump running at very near full speed during a print. This is with the phone about 1" from the pump.
                        klcjr89 1 Reply Last reply Reply Quote 0
                        • klcjr89
                          klcjr89 @MSquared last edited by
                          @msquared
                          Brushless? ☺
                          • MSquared
                            MSquared administrators @klcjr89 last edited by
                            @klcjr89 said in Berd-Air pump configuration notes for Duet users:
                            @msquared
                            Brushless? ☺
                            This was actually the brushed version. I will put up something with the brushless in a day or so.
                            • hurzhurz
                              hurzhurz @MSquared last edited by
                              @msquared About the flayback diode, your link points to a 1N4007.
                              I have first tried this one, but it got pretty hot.
                              After some googling I think the reason is that the diode is just too slow for a high frequency of 25kHz (reverse recovery time of 30us).
                              I have replaced it by a schottky diode that doesn't get warm.
                              And I would like to know what motors temperatures you observed with the standard pump?
                              For example, mine has reached about 50°C after a while running at 50%... I don't know if this is good or not...
                              coredump 1 Reply Last reply Reply Quote 0
                                If you are using a high PWM frequency (you mentioned 25kHz), please check also that the mosfet isn't getting hot.
                                hurzhurz 1 Reply Last reply Reply Quote 0
                                • gen2eng
                                  I've been using:
                                  • The flyback diode provided with the eSwitch kit, sans the rest of the kit.
                                  • The current limiting thermistor DC42 linked to.
                                  I'm getting great results at 25kHz freqency. Prior to changing the frequency, my minimum operating range was about 25%. I'm now able to operate at 20%, and my understanding is the current limiting thermistor is dropping voltage a touch based on the ~30 Ohm resistance I measured when checking my circuit.
                                  Hergonoway 1 Reply Last reply Reply Quote 0
                                  • hurzhurz
                                    hurzhurz @dc42 last edited by
                                    @dc42 Yeah, the mosfet gets indeed a bit hot.
                                    Hard to measure that tiny thing with a thermometer, but from touching it, I would say roughly around 60°C as I can still touch it for at least a couple of seconds.
                                      Duet boards with PCB revision 1.02 and later have flyback diodes already included on all fan outputs.
                                      • Hergonoway
                                        Hergonoway @gen2eng last edited by
                                        @gen2eng
                                        So you've set M106 with F25500 as PWM frequency parameter? I've got the same configuration and mofset is well cooled, just asking before changing the configuration.
                                        gen2eng 1 Reply Last reply Reply Quote 0
                                        • gen2eng
                                          gen2eng @Hergonoway last edited by
                                          @hergonoway said in Berd-Air pump configuration notes for Duet users:
                                          @gen2eng
                                          Correct, I'm using F25500 on a 24V (1.03 Duet Wifi) and 12V (0.85 Duet) without issue. I've got a flyback on both. The 0.85 needs the external flyback, but the 1.03 does not. I am not using the eSwitch module.
                                          • klcjr89
                                            @MSquared Any progress with the brushless pump? 🙂
                                            • ayudtee
                                              ayudtee last edited by
                                              Ive got 2 Berd air systems that only need to be at 25% or so to give great part cooling. The sound of air whoosing out is louder than the pump. I am using a brass tube that is 3.75 mm outside diameter with a flattened tip and is positioned to point at the tip of the extruder. This size tube and opening is less restrictive on the pump than the supplied 2.4 mm tube so it runs quieter and supplies more air. Initial positioning of the tube took some trial and error (was quite fiddly as some would say), but once you've got it the results are impressive. My Duets are 0.85 and Wifi 1.0 or 1.01 and both are on 12v. I am not willing to risk running the Berd air pumps on my Duets without the eswitch and hope that no one who does regrets it.
                                              • Hergonoway
                                                Hergonoway @ayudtee last edited by
                                                @ayudtee
                                                Thinking about getting a bigger tube, for the same obvious reasons, air flow. 3,75mm is kind of uncommon did you have to flattened the tube (I think of using 1/8" because 4mm seems to big) ? And did you use a jig to bend the "circle" part?
                                                ayudtee timcurtis67 2 Replies Last reply Reply Quote 0
                                                • ayudtee
                                                  ayudtee @Hergonoway last edited by
                                                  @hergonoway 1/8" is an improvement to the stock tube and is close to 3.75 (3.18). I flattened the tube by stripping a length of #12 AWG stranded and inserting as many wires as possible into one end. I flattened the end with a small hammer and pulled out each wire with pliers afterward. I am not using a circle, only the flattened tip.
                                                  • timcurtis67
                                                    timcurtis67 @Hergonoway last edited by
                                                    @ayudtee
                                                    One way to bend soft tubing is to fill it with salt (table salt) and tape the ends shut. Pack it pretty tight and then you can bend it to as tight a circle as you need.
                                                    Then remove the tape and tap it until all the salt comes out. I blow air thru it as well afterwards.
                                                    • Hergonoway
                                                      @ayudtee said in Berd-Air pump configuration notes for Duet users:
                                                      @timcurtis67 said in Berd-Air pump configuration notes for Duet users:
                                                      @ayudtee
                                                      Thanks I'll give a shot then !
                                                      One last question, did you choose a specific angle for the holes ? some people keep the same 90° angle but others use a 45° angle toward the hotend, is there really a benefit from one to another ? the current problem I have with Berdair are on overhang, I've gain airflow by directly connecting the 1/8" tube to the aluminium tube, and I'll certainly gain more air flow by increasing the metal tube, but does orientation in this little space will change anything, I don't know.
                                                      ayudtee 1 Reply Last reply Reply Quote 0
