    Power connector floating
    • trayracing
      trayracing last edited by trayracing
      Hi. My Duet wifi just arrived. Build quality looks very nice, except the power connector wasn't fully inserted before soldering. This makes it mechanically vulnerable to cracked traces down the road. Easy enough to fix up front with a soldering iron. Mostly wanted to give your assembly team an alert, as well as any owners out there.alt text
      • T3P3Tony
        Thanks for the notification, I will let our assemblers know.
        • denke
          denke last edited by
          Since every other connector on the board is pluggable, have you considered something like an xt30 for input, bed and heaters?
          • T3P3Tony
            T3P3Tony administrators @denke last edited by
            @denke Yes, considered XT30 however future hardware designs will most likely use a terminal block (like we have used on the Duet Maestro and are used on most 24V power supplies). XT30 is tricky for some people to terminate properly.
            denke 1 Reply Last reply Reply Quote 0
            • denke
              denke @T3P3Tony last edited by
              I just brought it up because they are pluggable, and the polarity is clearly indicated.
              If it's not convenient, then it doesn't matter, i just wanted to ask.
