    Paneldue not allowing me to set temp on T2.
    866
    • timcurtis67
      timcurtis67 last edited by
      Is there a setting i am missing to allow my Paneldue to allow me to change the temp and switch on active status?
      https://photos.app.goo.gl/BX2DTOOHTQQKPUaw1
      See under the third tool no buttons to select?
        How many tool heaters are you using? Please share your config.g file.
        • timcurtis67
          I'm using 2 heaters. One for each head (IDEX).
          How do I upload files on here?
          whosrdaddy 1 Reply Last reply Reply Quote 0
          • whosrdaddy
            whosrdaddy @timcurtis67 last edited by
            @timcurtis67, there is an upload file button in the reply window (see icons above text you type)
              config.g. is short enough that you can include the text in your post.
              • timcurtis67
                timcurtis67 last edited by timcurtis67
                Config.g
                M111 S0 ; Debugging off
                G21 ; Work in millimetres
                M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                ; M558 P6 I1 X0 Y0 Z0 F175 T6000 H3 ; Probe Mode 6 Switch Type
                ; M558 P1 I1 R0.4 F300 X0 Y0 Z0 ; Piezo Board
                G31 X0 Y0 Z6.975 ; Set Z probe offset and trigger height Switch Type
                ; G31 X0 Y0 Z-.1 P600 ; Piezo Board
                M557 X-195:195 Y-190:190 S20 ; Define mesh grid
                M569 P4 S0 ; Drive 4 goes backwards
                M569 P5 S0 ; Drive 5 goes backwards
                M584 X0 Y1 Z2 U3 E4:5 ; Create U axis for second X carriage before we try to configure it
                M574 X1 Y2 U2 Z2 S0 ; Set active low endstops
                M208 X-255.3 Y-226 U-213 Z0 S1 ; Set axis minima
                M208 X214 Y250.1 U255.6 Z426.95 S0 ; Set axis maxima
                M350 X16 Y16 U16 Z16 E16:16 I1 ; Configure microstepping with interpolation
                M92 X80 Y80 U80 Z400 E837.0:837.0 ; Set steps per mm
                M566 X175 Y175 U175 Z12 E500:500 ; Set maximum instantaneous speed changes (mm/min)
                M203 X18000 Y18000 U18000 Z2500 E1200:1200 ; Set maximum speeds (mm/min)
                M201 X600 Y600 U600 Z250 E1000:1000 ; Set accelerations (mm/s^2)
                M906 X1000 Y1400 U1000 Z1800 E1100:1100 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                M305 P0 T100000 B3950 C0 R4700 ; Set thermistor + ADC parameters for heater 0
                M305 P1 T100000 B4725 C0.0000000706 R4700 ; Set thermistor + ADC parameters for heater 1
                M143 H1 S350 ; Set temperature limit for heater 1 to 350C
                M305 P2 T100000 B4725 C0.0000000706 R4700 ; Set thermistor + ADC parameters for heater 2
                M143 H2 S350
                M563 P0 D0 H1 ; Define tool 0
                G10 P0 X0 Y0 U0 Z-.25 ; Set tool 0 axis offsets
                M563 P1 D1 H2 X3 ; Define tool 1
                G10 P1 X0 Y.1 U0 Z-.25 ; Set tool 1 axis offsets
                G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C
                M563 P2 D0:1 H1:2 X0:3 ; Define tool 2 Ditto Printing
                G10 P2 X50 Y0 U-50 Z-.25 ; Set tool 2 axis Ditto Printing offsets
                G10 P2 R0 S0 ; Set initial tool 2 active and standby temperatures to 0C
                M576 P2 E1:1 ; Set mix rtio 100% on both extruders
                M550 P******* ; Set machine name
                M551 ******* ; Set password
                M552 S1 ; Enable network
                M587 S"EnolaRoad" P"******" ; Configure access point. You can delete this line once connected
                M586 P0 S1 ; Enable HTTP
                M586 P1 S0 ; Disable FTP
                M586 P2 S0 ; Disable Telnet
                M106 P1 S1 I0 F500 H1 T45; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M106 P2 S1 I0 F500 H2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M106 P3 H100:101 T35:45 L0.3 ; CPU Cooler later
                M80 ; turn on power supply
                T0 ; Select first tool
                • timcurtis67
                  Here is my tfree2 and tpost2 files as well
                  ; tfree2.g
                  ; called when tool 0 is freed
                  ; generated by RepRapFirmware Configuration Tool on Mon Nov 27 2017 08:32:27 GMT-0500 (Eastern Standard Time)
                  M83 ; relative extruder movement
                  G91 ; relative axis movement
                  G1 Z5 F1500 ; up 10mm
                  G90 ; absolute axis movement
                  G28 X U ; park the X & U carriages
                  ;M572 D0 S0.0
                  ;M572 D1 S0.0
                  ; tpost2.g
                  ; called after tool 0 has been selected
                  ; Wait for set temperatures to be reached
                  ;G91
                  ;G1 X1 F1500
                  ;G1 Z-10 F1500
                  M116 P2
                  M567 P2 E1:1 ; Set mixing ratio
                  M568 P2 S1 ; turn on mixing
                  ;M572 D0 S0.06 ; turn on pressure advance ext 1
                  ;M572 D1 S0.06 ; turn on pressure advance ext 2
                    You have 3 tools configured but only 2 heaters. PanelDue doesn't yet handle multiple tools very well when there isn't a 1:1 mapping between heaters and tools.
                    • timcurtis67
                      Any suggestions on how to map the third heater? I just followed the guides for IDEX on the Duet documents page but didn't see anything about mapping an additional heater?
                      Please advise or point me in the right direction,
                      Thank you David
                        Your tool configuration is correct, it's just that PanelDue doesn't handle the ditto printing tool properly.
                        • timcurtis67
                          Okay David, now I'm following you. Thank you for the info. It's not a big deal I just wanted to make sure I didn't miss something.
                          The new firmware is working great! I'm running 20 out of 24 hours per day for the next 10 days with the IDEX ditto printing. Thank you for all the amazing work you guys do with the Duet!
