Z axis not stopping at Endstop
My z axis keeps going through the min endstop and going into the bed.
Here is my Homez
; homez.g
; called to home the Z axis
G91 ; relative mode
G1 S1 Z-250 F300 ; move Z towards the switch until it triggers
G1 Z5 F100 S2 ; move Z back 5mm
G1 S1 Z-10 F100 ; move Z slowly towards the switch until it triggers
G90 ; back to absolute mode
Here is my homeall
; homeall.g
; called to home all axes
; generated by RepRapFirmware Configuration Tool on Thu Mar 29 2018 21:22:13 GMT-0400 (Eastern Daylight Time)
G91 ; relative positioning
G1 S1 X-843.2 Y767 F1800 ; move quickly to X or Y endstop and stop there (first pass)
G1 S1 X-843.2 ; home X axis
G1 S1 Y767 ; home Y axis
G1 X5 Y-5 F6000 ; go back a few mm
G1 S1 X-843.2 F360 ; move slowly to X axis endstop once more (second pass)
G1 S1 Y767 ; then move slowly to Y axis endstop
G90 ; absolute positioning
G91 ; relative mode
;G1 X15 Y15 F6000 ; go to first bed probe point and home Z
;G30 ; home Z by probing the bed
;G1 Z5 F100 S1 ; uncomment this line to lift the nozzle after homing -
what type of end stop is it ?? a switch, piezo probe \ bltouch ? have you tried manually 'switching' the end stop ?
its a switch and i have tried manually pressing it when the printer was lowering while it was homing but it still didn't do anything.
Does the light on the Duet board light up or turn off when the switch is clicked?
@phaedrux it lights up
Is this a new setup or did it just stop working recently?
Can you post your config.g so we can see how the endstop is configured?
What kind of switch is it?
@phaedrux here are the switches Gowoops 5 PCS of Mechanical Endstop Switch with Cable for 3D Printer Makerbot Prusa Mendel RepRap CNC Arduino Mega 2560 1280.
the setup is new and i have not printed anything yet.
config.g:
; Configuration file for Duet WiFi (firmware version 1.17 to 1.19)
; Custom settings
M584 X0 Y1:4 Z5:9:7:8 E3; General preferences
M83 ; ...but relative extruder movesM667 S0 ; Select CoreXY mode
M550 PUnderground Printing- Jumbo ; Set machine name
M552 S1 ; Enable network
M587 S"KQVQM" P"SVLFBZMC3PK8893X" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M569 P4 S0 ; Drive 4 goes back
M569 P5 S0
M569 P6 S0
M569 P7 S0
M569 P8 S0
M569 P9 S0
M350 X32 Y32 Z32 E16 I1 ; Configure microstepping with interpolation
M92 X160 Y160 Z4000 E1750 ; Set steps per mm
M203 X6000 Y6000 Z220 E1200 ; Set maximum speeds (mm/min)
M201 X500 Y20 Z250 E250 ; Set accelerations (mm/s^2)
M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 X723 Y762 Z1117.6 S0 ; Set axis maxima; Endstops
M574 X2 Y1 S1 ; Set active low endstops
M574 Z0 S1
M558 P0 H5 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
M557 X15:823.2 Y15:747 S20 ; Define mesh grid; Heaters
M140 H-1 ; Disable heated bed
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P1 S1 I0 F500 H T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C -
@puppet172 said in Z axis not stopping at Endstop:
M574 Z0 S1Where you have that, try this:
M574 X2 Y1 Z1 S0
That's assuming you have the X end stop at the high end of travel and the Y and Z end stop at the low end of travel. S0 sets them to active low switches which should work with those makerbot switches.
