    Duetwifi and paneldue 7“
    PanelDue
    1118
    • tkamsker
      tkamsker last edited by
      Hi
      I Build an hypercube 300x 300 with an different Z axis and have tested now some Hardware
      Smoothieboard Rads 1.5 and now the duet wifi ,.
      I use 0.9 degreees Steppers and it works Fine ( i just Need to tweak the sensorless Homing )
      But the 7“ Panel is Lightning but Shows nothing
      I found somewhere a hin5 That they ned same Speed 56700 ok granted
      Question 1
      Where do i find the Info how to verify that ?
      Q2
      Is there a way to get Both up to 25000 ?
      Q3
      Do others have Same issue ?
      Thx in advance
      Thomas
        Is the screen showing the buttons etc. But stuck at status "Connecting", or is it blank? Or something else?
        • tkamsker
          Wow that is fast
          It Shows just a Kind of dark screen backlithed
          So i use Pronterface to kick the wlan on and Then i use the Web Browser ...
          That is why i think no handshake and all Pixels Are in Same State
          Thx
          Thomas
            Even if it is not connected to a Duet, PanelDue should display the printer status screen (without real values of course) if it is supplied with power. So I suspect that either it was not programmed, or the Erase button has been pressed. You can try uploading firmware to it if you wish, see the installation instructions page.
            • tkamsker
              Ok
              I am Roaming Next dass but Then i search for the Article how to Flash the Panel
              And respond success or failure
              Thx
              Thomas
              • tkamsker
                Hello
                I now feel a little dumb because i found https://duet3d.dozuki.com/Wiki/Installing_and_Updating_Firmware which i s quite clear but i didn't find how to flash the panel due ? I have a lot of Arduino experience i do programs Granite devises Delta Servos so i have a good chance to achieve it but somehow i didn't find the panel please push me to the right direction thx thomas
                • Alex9779
                  Alex9779 last edited by
                  No idea if there is some other source but I referred to https://miscsolutions.wordpress.com/paneldue/ when updateing the PanelDue FW...
                    Yes, see the link that Alex provided. For the 7.0 integrated version, use file PanelDue-v3-7.0i.bin from https://github.com/dc42/PanelDueFirmware/releases/tag/1.20.
