    2nd FAULTY DUET ETHERNET BOARD
    • micktol
      micktol last edited by micktol
      I have received a replacement for the board which had misplaced components, the replacement also has the same problem. C111 is misplaced it has one end connected to the resister beside it.
      I do not know if this is safe to use, but it is a manufacturing fault!
      The details of the first board are here https://forum.duet3d.com/topic/5482/new-board-faults
      • T3P3Tony
        T3P3Tony administrators @micktol last edited by
        @micktol Hi we are currnetly investigating this, either the manufacturer had a systematic issue that has only come to light now or you have been incredibly unlucky! We are checking all our stocks. Your supplier should be in touch (If they have not been already) to arrange a further replacement. For info this capacitor is used to debounce the E1 endstop input so the board is safe to use with this capacitor not present.
        • micktol
          Thank you third time lucky, can I use this board until the replacement arrives?
          • T3P3Tony
            @micktol yes you can.
