    slic3r heatbed location start issue
    968
    • mlaustin6undefined
      mlaustin6
      I'm using the latest version of Slic3r 1.3 dev. I recently changed hotends and have not had this issue before the change. But nothing has changed in firmware or software. When I pick reprap as the gcode flavor, the print starts offset from where it should. I'd guess it's 10-20mm off. What would cause that? And how do I fix it?
        Does your bed dimensions in Slic3r match what you have set for axis limits in config.g?
          mlaustin6
          I did not. I just had it at 200x200. I hav a cartesian printer, so I set it no to 220x226. The reason being is my offset z origin is 16, 30. It doesn't look like anything has changed. My guess is the offset would matter. The current print started towards the front just like that last have rather than more in the middle as I specified in Slic3r.
            mlaustin6
            It is still not working correctly after setting the parameters in Slic3r. Simplify 3d does the same. Is it possible it's something in the home all file?
            Here are the parameters:
            ; homeall.g
            ; called to home all axes
            ; generated by RepRapFirmware Configuration Tool on Mon May 21 2018 09:59:36 GMT-0500 (Central Daylight Time)
            G91 ; relative positioning
            G1 Z2 F6000 S2 ; lift Z relative to current position
            G1 S1 X-235 Y-205 F2400 ; move quickly to X and Y axis endstops and stop there (first pass)
            G1 X5 Y5 F6000 ; go back a few mm
            G1 S1 X-235 Y-205 F900 ; move slowly to X and Y axis endstops once more (second pass)
            G1 Z-230 S1 F100 ; move Z down until the switch triggers
            G1 Z2 F6000 ; go back a few mm
            G1 S1 Z-230 F900 ; move slowly to Z axis endstop once more (second pass)
            G90 ; absolute positioning
            G92 Z0.2 S2 ; tell the firmware that we are at z=.2mm
            G1 X16 Y30 F6000 ; go to first bed probe point
            ;G1 Z2 F100 S2 ; uncomment this line to lift the nozzle after homing
              can you also post your config.g?
                mlaustin6
                M555 P1 ; Set firmware compatibility to look like RepRapFirmare
                M550 PP3Steel ; Set machine name
                M552 S1 ; Enable network
                M587 S"Gemini" P"0102030405066ml" I192.168.1.100 J192.168.1.254 K255.255.255.0 ; Configure access point and IP addresses. You can delete this line once connected
                M586 P0 S1 ; Enable HTTP
                M586 P1 S1 ; Enable FTP
                M586 P2 S1 ; Enable Telnet
                M350 X128 Y128 Z128 E128 I0 ; Configure microstepping without interpolation
                M92 X640 Y640 Z32000 E2386 ; Set steps per mm
                M203 X12000 Y12000 Z180 E12000 ; Set maximum speeds (mm/min)
                M201 X1400 Y1400 Z50 E9000 ; Set accelerations (mm/s^2)
                M906 X1000 Y1000 Z800 E1200 I30 ; Set motor currents (mA) and motor idle factor in per cent
                M84 S30 ; Set idle timeout
                M208 X220 Y226 Z230 S0 ; Set axis maxima
                M574 X1 Y1 Z1 S0 ; Set active low endstops
                M558 P0 H2 F120 T6000 ; Disable Z probe but set dive height, probe speed and travel speed
                M557 X15:185 Y15:185 S20 ; Define mesh grid
                M301 H0 S1.00 P10 I0.1 D200 T0.4 W180 B30 ; Use PID on bed heater (may require further tuning)
                M305 P0 T100000 B4066 C9.264103e-8 R4700 ; Set thermistor + ADC parameters for heater 0
                M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
                M143 H1 S300 ; Set temperature limit for heater 1 to 300C
                M106 P1 S1 I0 F500 H1 T35 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M106 P2 S1 I0 F500 H1 T100 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
                M563 P0 D0 H1 ; Define tool 0
                T0 ; Select first tool
                  @mlaustin6 said in slic3r heatbed location start issue:
                  Please explain what you mean by that.
                  mlaustin6undefined 1 Reply Last reply Reply Quote 0
                    mlaustin6 @dc42
                    @dc42 said in slic3r heatbed location start issue:
                    I meant that when it hits the x endstop it travels 16 and y endstop it travels 30. That would then be the origin of 0,0. I'm sure something is wrong in the home all file.
                    whosrdaddyundefined 1 Reply Last reply Reply Quote 0
                    • whosrdaddyundefined
                      whosrdaddy @mlaustin6
                      @mlaustin6 : that means that your axis minima are X:-16 and Y-30, update your M208 command in config.g to get the correct 0,0 position
