    X Axis Stopped funtioning
    axis grinds axis stopped cant home x axis skipping stepps x axis not moving
    • enix
      enix last edited by
      I'm new to the duet, but have been in 3D printing for about 4-5 years now. I moved from RAMPs and similar controllers running Marlin FW. I love the board and, while different, it was quite easy to get up and running. I did all the normal calibrations and such and have been printing for over a week now, with great results, but then all the sudden, in the middle of a print, the X axis skips several steps (usually in the negative direction).
      I re-homed the axis and it functioned fine, so I considered that maybe it caught a blurb on the print and skipped. So I started a new print and it didn't even finish the first layer before skipping a lot. I cleared the area and tried to move the X axis on its own from the web interface and it was very loud and choppy. I verified the belt is not loose and that it is just the motor humming like it is missing the steps. I shut off the idle hold to the printer and moved the axis by hand and it moved easily as it always has. So then I tried homing it and the axis just made the grinding noise I had been hearing and barely moved. At this point, I am thinking that the motor burnt or had an issue, so I swapped it with a new one. I made sure the coils are correctly wired and connected and tried again but got the same result. I double checked all wires were good and coils connected correctly again but can't seem to find the issue. Is it possible the driver has gone out? As I said, it had been printing fine for over a week straight (at least 10 hours a day on 1.75 hr prints), and now I can't do simple 10mm movements or home the axis. Any help would be appreciated.
      • T3P3Tony
        T3P3Tony administrators @enix last edited by
        @enix can you post M122 results please, while the X axis is causing issues.
        • enix
          enix last edited by
          6:04:11 PMM122
          Used output buffers: 3 of 32 (9 max)
          RepRapFirmware for Duet 2 WiFi/Ethernet version 1.21 running on Duet WiFi 1.02 or later
          Board ID: 08DGM-956GU-DJ3SN-6J1FA-3SJ6Q-KAN3F
          Static ram used: 16152
          Dynamic ram used: 100408
          Recycled dynamic ram: 2224
          Stack ram used: 1224 current, 4400 maximum
          Never used ram: 7888
          Last reset 00:04:31 ago, cause: power up
          Last software reset at 2018-06-07 21:00, reason: User, spinning module GCodes, available RAM 7888 bytes (slot 1)
          Software reset code 0x0003 HFSR 0x00000000, CFSR 0x00000000, ICSR 0x0441f000, BFAR 0xe000ed38, SP 0xffffffff
          Error status: 0
          Free file entries: 10
          MCU temperature: min 29.7, current 35.7, max 36.0
          Supply voltage: min 12.2, current 12.3, max 12.4, under voltage events: 0, over voltage events: 0
          Date/time: 2018-06-08 18:04:10
          Slowest main loop (seconds): 0.014005; fastest: 0.000046
          MaxReps: 1, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm 239, MaxWait: 3670778439ms, Underruns: 0, 0
          Scheduled moves: 2, completed moves: 2
          Bed compensation in use: none
          Heater 1 is on, I-accum = 0.0
          Segments left: 0
          Movement lock held by null
          http is idle in state(s) 0
          telnet is idle in state(s) 0
          file is idle in state(s) 0
          serial is idle in state(s) 0
          aux is idle in state(s) 0
          daemon is idle in state(s) 0
          queue is idle in state(s) 0
          Code queue is empty.
          === Network ===
          Responder states: HTTP(1) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
          HTTP sessions: 1 of 8
          • WiFi -
            Network state is running
            WiFi firmware version 1.21RC4(08b3)
            WiFi MAC address 5c:cf:7f:76:69:b6
            WiFi Vcc 3.33, reset reason Turned on by main processor
            WiFi flash size 4194304, free heap 16064
            WiFi IP address 192.168.1.101
            WiFi signal strength -38dBm, reconnections 0, sleep mode modem
            Socket states: 2 0 0 0 0 0 0 0
            === Expansion ===
          • enix
            enix last edited by
            I got that just after trying to home the X axis only. A window popped up with "Error: G0/G1: insufficient axes homed" after it stopped making the grinding noise.
            • enix
              enix last edited by
              And here is my config.g file. In case it helps...
              ; generated by RepRapFirmware Configuration Tool on Sun Jun 03 2018 15:43:28 GMT-0400 (Eastern Daylight Time)
              M550 PBob ; Set machine name
              M551 Preprap ; Set password
              M552 S1 ; Enable network
              M586 P0 S1 ; Enable HTTP
              M586 P1 S0 ; Disable FTP
              M586 P2 S0 ; Disable Telnet
              M569 P0 S0 ; Drive 0 goes backwards
              M92 X100 Y100 Z405.887 E150.96 ; Set steps per mm
              M566 X720 Y720 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
              M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
              M201 X1000 Y1000 Z250 E250 ; Set accelerations (mm/s^2)
              M906 X1000 Y1000 Z1000 E1000 I30 ; Set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              M208 X250 Y250 Z320 S0 ; Set axis maxima
              M574 X1 Y1 S1 ; Set active high endstops
              M558 P1 H4 F120 T6000 ; Set Z probe type to unmodulated and the dive height + speeds
              G31 P500 X-2 Y-19 Z0.35 ; Set Z probe trigger value, offset and trigger height
              M557 X15:235 Y15:235 S20 ; Define mesh grid
              M143 H0 S85 ; Set temperature limit for heater 0 to 85C
              M143 H1 S260 ; Set temperature limit for heater 1 to 260C
              M106 P0 S0.5 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
              M106 P2 S1 I0 F500 H1 T80 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on
              M563 P0 D0 H1 ; Define tool 0
              T0 ; Select first tool
                The most like causes are a bad crimp connection in the motor cable, or a faulty driver. It's rare for stepper motors to develop electrical issues, although occasionally they seize up due to swarf.
                To test this, with power off swap the X and Y motor connectors over where they plug into the Duet. Power up and send M564 H0 to allow jogging before homing. Then try jogging the X and Y motors:
                • When you ask to jog X, it will jog the Y motor, which is plugged into the X output. If that works, the problem is the X motor cable. If it shows the same problem, then the problem is most likely with the driver.
                • When you ask to jog Y, it will jog the X motor. If that doesn't work, the problem is the cable.
                If it looks like a driver problem, you can use M564 X4 Y1 Z2 E3 in config.g (before any M906 or M350 commands) to map the X motor to the E1 driver, and plug the X motor cable into the E1 output.
                If these tests confirm that the X driver is faulty, please ask your supplier to repair or replace the Duet under warranty.
                • enix
                  enix last edited by
                  Thank you very much for the reply. I don't know why I didn't think to try that, probably the frustration of the issue. Either way, that helped me solve it. Turns out it was a wire issue. I couldn't get any sort of continuity variance, but changing it out for a new one fixed the issue. Thanks again.
