    Compact power box to mount on vertical 2040 (delta)
    791
    • Hergonoway
      Hergonoway last edited by Hergonoway
      I've Just wanted to share my new design for crazy people like me with all electronics in the top triangle of a Delta 🙂
      It's a compact powerbox to be installed at the bottom of the printer on a vertical 2040.
      https://www.thingiverse.com/thing:2954710
      wilriker 1 Reply Last reply Reply Quote 1
      • Alex.cr
        Alex.cr last edited by
        Thanks for sharing. This is exactly what I was looking for a couple weeks ago and was too lazy to draw it up...
        Nice job!
        • Hergonoway
          Same story here, but I've finally decided to draw it 🙂
          • wilriker
            wilriker Moderator @Hergonoway last edited by
            @hergonoway Thanks for sharing. I think I will remix this to fit my power connector but this will definitely solve a lot of issues with the PSU shroud I am currently designing (or trying to 😄 ). 👍
            Hergonoway 1 Reply Last reply Reply Quote 0
            • Hergonoway
              Hergonoway @wilriker last edited by
              @wilriker
              Show me your power connector, I'm currently making an alternative version for a friend, maybe its the same.
              wilriker 1 Reply Last reply Reply Quote 0
              • wilriker
                @hergonoway I could not find some good pictures quick, so here is the link to the shop:
                https://shop.bohrers.de/kaltgeraetebuchse-3in1.html
                also they have a readily wired version which I link down below just because it has pictures from other angles:
                https://shop.bohrers.de/kaltgeraetebuchse-3in1-verkabelt.html
                • ShadowX
                  ShadowX last edited by ShadowX
                  Looks safe...
                  I love my exposed AC power outlet right next to a conductive chassis without a shield. It should have a printable cover between the box and the frame for safety.
                  • Hergonoway
                    Hergonoway @ShadowX last edited by Hergonoway
                    @shadowx
                    Well you can always put a 1 or 2mm cover since its flat against the 2040, it's a good idea I'll add the stl. (EDIT : I've added a lid to the project)
                    Everything depends of how you wire everything right like the rest of the printer.
                    Pg7 connexion cancel movement if you pull the wire and outlet is fixed on the frame.
                    For my part, printer's frame is link to ground and wires are solder to the outlet and cover with shrinkable tube. Exposed part are then finished with nail polish. Connection with the breakout cable are made with a 3 way nylon terminal block within wires crimped with insulated connector.
