Using regular threaded pushfit possible?
My recent problem is, that the ptfe bowden slips out of the build-in pushfit of the smart effector. I dont know where to get the black inserts so i thought about remove the insert and drill and tap it so a normal m6 pushfit can be used.
Anyone had similar problems? even a new bowden tupe slips out after short time.
you can get the collet clips from E3D or any of there re-sellers should also be able to supply them
@barracuda72
yes, that is why I am using aftermarket radiator on original heatbreak, block and nozzles
I think screw in pushfits are better
I have never had any problems with the E3D pushfit collets. Whereas I have had one of the metal teeth of a screw-in pushfit fitting break off and wreck the hot end.
Perhaps the OD of your Bowden tube is under-sized? You might want to buy some new collects and some Capricorn tubing from E3D.
